Posted: Mon Mar 31, 2008 8:11 am Post subject: |
I'm still hoping someone will answer my question "Has anyone painted anything after using this stuff? I keep reading about paint failures after using soda blasting and I'm wondering if a similar problem results from using this stuff to remove paint. It's a base just like soda." |
ddarkraven Samba Member
Joined: March 06, 2008 Posts: 22 Location: South Gate, ca
Posted: Tue May 06, 2008 11:29 am Post subject: |
I would love to see pics of the cars after they were done. Oh and as mentioned before, If anybody has painted their car after using this stuff. |
substock Samba Member
Posted: Thu May 08, 2008 5:15 am Post subject: |
IT works!
I told my dad about the stuff....so he went out and bought some to remove lead based paint from woodwork in an older home. The stuff worked..it took off 3 coats but seems to have left the varnish below....which is ideal! (it would probably take the varnish with a longer soak).....I still haven't tried it on a car. I probably won't until I hear some feedback about paint adhesion after this stuff is used.
-j. |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
Posted: Sun May 25, 2008 12:39 pm Post subject: |
This stuff works awesome!
I found some at Meijer's. So I sprayed a stock wheel and put it in a black garbage bag, left it outback in the sun for a couple hours and the paint is already bubbling off.
I'm going to try some engine tin next.
We'll see how well paint sticks to the wheel after I repaint it. _________________ -Andy-
-1970 Ghia-
-1971 Bus 1776 Microsquirt EFI- |
ocdbeetle Samba Optimist
Joined: March 18, 2008 Posts: 1176 Location: South Carolina
Posted: Mon May 26, 2008 6:27 am Post subject: |
This is the craziest thing I've seen in a while...(with 5 kids I've seen a lot)
I used it for some seatbelt trim (old sash belts) and it worked incredibly...wish I could find some more...Got the 1 bottle Walmart had... _________________ 1967 Lotus White Beetle |
AJ Quick Samba Member
Joined: July 20, 2006 Posts: 539 Location: Minnetonka, MN
Posted: Mon Jun 02, 2008 9:36 pm Post subject: |
Bought 3 bottles trying to remove a cheap paint job that was done over the factory clear coat on a subcompact. So far very little paint has been removed. I am hoping that I can remove the cheap paint and get the normal paint and clear coat remaining.
Can't say it works too well. _________________ Read My Beetle Restoration Blog!
http://www.RideSpace.net/
http://www.AJQuick.com/ |
Posted: Tue Jun 03, 2008 7:38 pm Post subject: |
I used some to remove a touchup job done on a beetle hood. I gave it a few hours to work and kept it covered in plastic. It worked pretty well on the paint..but it didn't seem to permeate the factory coat...although it cleaned it well.
I found that the hood had bondo which the power remover wouldn't soften so I had to move over to aircraft remover...works MUCH faster, but I think power remover is probably a fair alternative for those who don't want to deal with fumes from strong paint strippers. Just gotta give it time....Since my garage isn't heated in winter, it sounds like this would be a great product for removing paint in my basement without flooding the house with toxic fumes. |
Posted: Thu Jun 05, 2008 2:11 pm Post subject: |
I just used some more to remove a PO paint job on decklid hinges...I told my wife "No, no, the power dissolver doesnt take skin off your hands thats the other stuff"... now i feel like Im wearing gloves 3 times too small..... _________________ 1967 Lotus White Beetle |
Bugs'n'Pugs Samba Member
Joined: July 18, 2004 Posts: 1453 Location: Charleston, South Carolina USA
bastardbus Samba Member
Joined: July 13, 2000 Posts: 1767 Location: Toledo, Ohio
Posted: Sun Jul 27, 2008 9:21 pm Post subject: |
I think the effectivness of this stuff depends on the paint being removed.
Seems if it is cheap spray paint or something like that it may work. But any decent overspray not.
I bought a couple bottles to use on a couple greasy transmissions...
no paint at all...just grease...guess what...barely did a thing to the grease....hmm not too impressed. Tried all the tricks leaving it sit
for hours and the plastic covering it...still barely touched the grease on 2 different trannys on two different occasions. _________________ Samba Member #95 |
racetearoffs.com Samba Member
Posted: Mon Jul 28, 2008 6:47 am Post subject: |
I am going to get some I have an MGB I need to strip great find !! was looking at sandpaper and grinding wheels and cost and labor this sounds good . |
duginabug Samba Member
Joined: June 06, 2007 Posts: 481 Location: Washington State
Posted: Mon Jul 28, 2008 9:39 am Post subject: |
bastardbus wrote: |
for hours and the plastic covering it...still barely touched the grease on 2 different trannys on two different occasions. |
If you need to degrease something, this is what you want.
GOOD STUFF...It's a detergent but don't get it on your hand as it dries out your skin.
I soaked some greasy parts in this stuff overnight and when I pulled the parts all I had to do was a quick rinse and "viola". _________________ 1960 Sedan. L349 Jade Green. |
Posted: Tue Jul 29, 2008 1:25 pm Post subject: |
Got digital cam out going to run it on the 65 mgb fr fender and cover with garbage bag and check in the morning . It s 4 20 in the afternoon i sure hope the fumes dont get to me with this test ! Test variables >>> Florida overcast / car outside // humid // temp 80 ish /// no sun /// double cover fender garbage bag then tarp //// using one full bottle |
Posted: Wed Jul 30, 2008 2:59 pm Post subject: |
http://s48.photobucket.com/albums/f246/racetearoffs/ I was very suprised at the way it ate the paint could not get u tube to load video but went down and got a couple of bottles and heres is the piks garbage bag bake sysytem for 2 night . gonna do video and some piks but I guess old junk british crap is no match for your wives miracle cure fvs labor and sandpaper . We got about 1/2 hr or so wrapping vehicle after giving it the juice . When bottle got close to empty we filled it with some water .we used 4 bottles so far . Will post tommorrow effects after pressure wash bath . |
coW Samba Member
Joined: September 21, 2004 Posts: 2096 Location: New England
Posted: Fri Aug 01, 2008 8:07 am Post subject: |
racetearoffs.com wrote: |
That's more or less the result I got as well when I first did the test fender (see beginning of this thread).
It came down to what looks like factory primer and in some spots left the original blue.
I wonder if this this may be a good solution for when you want to take it down to original paint when a car has been sprayed by places like Maaco and Scheib -- I bet it takes all those cheap paints right off, as some of us experienced.
Edit: I have since used it on my basement's bilko doors and some furniture that had been painted. It has worked really well for me. The sandwich wrap definitely helps as well.
With furniture it will raise the grain so will require some sanding and sealing - that's for a different forum, though. |
Posted: Fri Aug 01, 2008 9:21 am Post subject: |
The top of the fenders are all the way down to the metal with the coating to keep it from rusting from the factory :2gunfire: , The hood i swear it looks like the original skim coat to make the aluminum hood smooth from the factory . I aint gonna million dollar trailer queen this car just a honest get it nice and solid beater mgb and hopefully driving round by Turkey day but open to Xmas . I really like it didnt stink up the [place when i had it in the shop . when i get the case I will try it on a modern junker and see what it does on something newer 90s and above . It is definetly saving time/labor/parts costs which is great !!! I am going to really crap it on all the missed parts when I get the case so I will post the final observation of the mgb paint strip trial . |
Blitzkrieg_ Samba Member
Joined: July 12, 2007 Posts: 229 Location: South Africa
Posted: Fri Aug 08, 2008 2:11 am Post subject: |
Greetings from sunny South Africa
I have successfully used a drain cleaner to strip my Type 4 engine tinwear.
It costs around $3 for a litre.
The main ingredient is sulphuric acid. And the instructions state that you should not use it on aluminium drains and guttering
What I basically did was leave the tinwear in a flat pan and immerse it in the drain cleaner, then left it overnight.
In the morning, the tins were stripped clean!
I just had to blast them with a hose pipe and use some metal conditioner. Now they are ready for painting |
