harlannj Samba Member
Joined: December 19, 2007 Posts: 83 Location: New England
Posted: Sat Aug 09, 2008 9:26 pm Post subject: |
when you use this, can you spray a rag then wipe it over a larger surface of paint? or is it just a spray on wipe off sorta thing _________________ 1991 GLI 16v 09-10
1986 GTI vr6 10-12
1991 Vanagon 1.8 14-__ |
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 846 Location: Fort Wayne, IN
nhopk Samba Member
Joined: July 29, 2007 Posts: 79 Location: Washougal, Washington
Posted: Sun Aug 10, 2008 10:12 pm Post subject: |
I gave this a shot on my 74 Baja bug this weekend. I went down to wal mart and bought what was their medium-priced aerosol oven cleaner. My bug still has most of its original paint, with several layers of crappy jobs on top.... I sprayed down the entire thing with 3 and a half cans and let it sit for about 3 hours. After that, the paint came off incredibly easy with a simple power-washer. I couldn't have asked for better results.
_________________ '71 1302
'83 GTi |
coW Samba Member
Joined: September 21, 2004 Posts: 2096 Location: New England
Posted: Mon Aug 11, 2008 5:37 am Post subject: |
blue72beetle wrote: |
It seems to work best of you let it soak for awhile. |
Right. That's why you use the plastic wrap to hold the moisture in so it doesn't dry out as quickly.
That's an old woodworker trick.
Well, maybe not "old" but it certainly has been around since we've had stripper and plastic wrap. |
kingston1200 Samba Strummer
Joined: July 03, 2005 Posts: 267 Location: Ventura, California
Posted: Fri Aug 29, 2008 12:17 pm Post subject: |
Found some at walmart for 1.98 per bottle. ACE has it too. They sell it by the case, $30 for 10 bottles. you can buy it online and have it shipped, i believe.
Here is my test on my steering wheel lock. I painted it red with a rattle can thinking it would look cool but no dice so i needed to strip it.
there are multiple layers of paint on the peice. red, flat black, primer, white, turquoise blue, off white, and the original paint color with i think was birch green. the Dawn ate thru it all down to the metal.
SPRAYED THE DAWN ON
COVERED IT PLASTIC WRAP AND LET IT SIT OVER NIGHT, ABOUT 8 HRS.
TOOK A GARDEN HOSE TO IT WITH A PRESSURE ATTACHMENT ON IT.
95% OF THE PAINT PEELED RIGHT OFF WITH JUST THE WATER PRESSURE. THE REST CAN BE SCRAPED OFF WITH A THUMB NAIL OR TOOTHPICK.
C_Heath Samba Member
Posted: Mon Oct 19, 2009 12:11 pm Post subject: |
didnt go nuttin for my paint. |
andrewsanteiro Samba Member
Joined: July 07, 2009 Posts: 273 Location: Pisgah Forest, NC
Posted: Tue Jan 05, 2010 1:31 pm Post subject: |
HAS ANYONE PAINTED AFTER USING DAWN POWER DISSOLVER TO STRIP
¿RESULTS? _________________ On the road. Thanks to the Samba!
72' 1600cc Baja Bug |
Penaltyboxxx Samba Member
Posted: Thu Apr 22, 2010 11:24 am Post subject: |
For a small section I used Carbona Oven Cleaner and steel wool. Worked well because it's biodegrabale, has no fumes and is sprayed as a gel so it didn't run on vertical surfaces. I used it with steel wool over original stencilling because I didn't want to use anything too strong that would harm the lettering underneath. |
Mack8743 Samba Member
Joined: December 07, 2009 Posts: 289 Location: Waynesboro Pa
Posted: Sat Jun 12, 2010 6:59 pm Post subject: |
where can you get this checked wallmart and lowes here in south central pa they don,t carry it _________________ 66 beetle and 67 baja both projects |
Miss Bea and Me Samba Member
Joined: December 01, 2009 Posts: 204 Location: Carthage, MO
Posted: Sat Jun 12, 2010 7:24 pm Post subject: |
Got mine at WalMart. It also does a nice job on my stove top (but I did carefully test it on a hidden area first!) _________________ 1974 Convertible SunBug named Miss Bea (by my daughter).
1974 Super Sedan/donor car
1973 Super Sedan - all in pieces
Build Thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=412484&highlight= |
Vinnems Samba Member
Joined: December 23, 2008 Posts: 1183 Location: Simi Valley, CA
Posted: Sun Sep 12, 2010 5:39 pm Post subject: |
For people asking about paint, I would definitely not just paint over anything I just put chemicals on unless it specifically said that you can. Anything I'm unsure about, I'd hit with soapy water, heat gun it dry, and take some sand paper to it. |
KidJoe86 Samba Member
Joined: April 07, 2013 Posts: 35 Location: United States
Posted: Fri Jul 26, 2013 1:59 pm Post subject: |
gonna give this a try this weekend for the air ducts above the engine to see how it goes, cause sanding in there is damn near impossible.... _________________ Joe
72' Super Beetle |
Anthonyisawsome Samba Member
Posted: Sat Jul 27, 2013 1:44 am Post subject: |
Has anyone tried this on bondo yet? |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Sat Jul 27, 2013 9:20 am Post subject: |
It wont touch bondo. The active ingredient is these oven cleaners, simple green, soap is Sodium Hydroxide. It does not affect plastics. Mixed very strong it will eat metals over time. The common name is Lye. In the old days people used it as pipe cleaners for the sewer drains. Over time it ate away at the old cast iron pipe. Todays plastic drain pipes it is fine for. It also has to be pretty strong to eat metal.
I have been building scale models for years and we use it to strip paint off of models.
You can buy it from places that sell home soap making products and mix as strong as you like. It is dangerous in high concentration and you have to add the powder to water, not the opposite. It has a property called volcanism if mixed wrong and it can cause problems. BOOM.
It does not work on all paints but quite a few it will. It also strips paint off of metal better than plastic due to its reaction with metal. It does need some chipped edges for that method to work though. |
Der Speed Shack Samba Member
Joined: April 10, 2010 Posts: 164 Location: Fullerton, Ca 92832
Posted: Sun Jul 28, 2013 2:05 pm Post subject: |
Anthonyisawsome wrote: |
if you heat the backside of the panel with a torch the bondo will scrape right off with a putty knife. just dont get the torch to close or hold it on the metal for long periods or the panel will warp. It makes quick work of plastic filler |
Posted: Sun Jul 28, 2013 11:17 pm Post subject: |
Well I don't want to remove the bondo but I used rattle can primer when I was done with the bondo and I want to remove the rattle can primer from the bondo. |
Posted: Mon Jul 29, 2013 12:42 pm Post subject: |
So I used it yesterday...I found it at my local Walmart..... sprayed on the vents and left for a few hours I didn't cover it at all like other guys did just cause I was in a bit of a hurry but when I got back to it, the old paint had lifted and came off completely. Pretty damn good stuff for sure.... it took off the cheap dark blue paint that the PO had sprayed it. It didn't lift the original paint which I'm okay with but with a little screwdriver and my thumb on the end of water hose everything came off and I'm gonna spray primer tonight and see how it sticks....I will take picks as I go.... _________________ Joe
72' Super Beetle |
brendo907 Samba Member
Joined: September 13, 2013 Posts: 339 Location: North Pole, Alaska
Posted: Mon Oct 07, 2013 2:19 am Post subject: |
What is this stuff called? Dawn easy off? So happy I stumbled on this post |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Wed Oct 23, 2013 7:15 pm Post subject: |
DAWN POWER DISSOLVER _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
moab762 Samba Member
Joined: October 09, 2014 Posts: 518 Location: El Segundo, CA
Posted: Tue Nov 18, 2014 12:03 pm Post subject: |
This is a fascinating thread. Although a little old. Has anyone found anything better? Are they still selling this stuff? What's the cheapest place that carries it?
Much thanks. This stuff sounds great!
EDIT - Holy shit. This stuff is $9.37 a bottle now! What happened?
