blackdog1999 Samba Member
Joined: October 17, 2004 Posts: 1203 Location: Rancho Cordova, CA 95670
Posted: Sun May 30, 2010 4:26 pm Post subject: |
I have done my last 4 Buses with Bay tanks. I love extra driving distance. The fuel total at the pump does suck though.
Corey _________________ Home of the one true split Bus Motorhome
Last edited by blackdog1999 on Thu Aug 19, 2010 10:08 pm; edited 1 time in total |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
quartermilecamel Samba Member
Posted: Sun May 30, 2010 6:33 pm Post subject: |
Well, I dont think it matters how big the tank is. Your bus will use the same amount of fuel reguardless of the size of the tank. You just fill up less often. I have the bay tank and like it. I also have a locking gas cap. I fabbed the filler neck to use a chevelle cap. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Wed Aug 18, 2010 11:03 pm Post subject: |
yup 3 bucks those were the days. Nobody gave a shit how much gas cost. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Thu Aug 19, 2010 10:10 pm Post subject: |
bill may wrote: |
i hear that-i used to fill up for $3 now it costs $30 |
$30? You must be running 87. I have been running 91. It is $40 to fill it up. Still better that the $100 in my Duramax Chevy. _________________ Home of the one true split Bus Motorhome |
Posted: Fri Aug 20, 2010 7:21 am Post subject: |
blackdog1999 wrote: |
bill may wrote: |
$30? You must be running 87. I have been running 91. It is $40 to fill it up. Still better that the $100 in my Duramax Chevy. |
87 is more than required octane for 1600 SP with 30pict-1 carb in a 65 overloaded camper panel. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Wed Feb 22, 2012 1:56 pm Post subject: |
close your eyes and dont look. Yes I did the toilet bowl bay sending unit deal. I didnt like it as it drove me nuts even though I already am. Swapped baytank out for a 68 to 71 tank that took the same style fuel sender but baywindow ...........a little longer than the split fuel sender. I purchased the 68 to 71 fuel sender out of the classifieds, fixed it, installed it and love it. Sending unit works just as well as the shorter split one in split tank. I did try to futz around with capacitors ect to smooth out the jumpyness.........it worked some, but not as smooth as just using the can float style split or early bay unit. Youd pretty much have to build yourself an integrator or custom circuit to get it to work flawlessly. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3294 Location: Seattle, WA
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Mon Oct 29, 2012 11:26 am Post subject: |
Curious if anyone has used the bay tank vent pipe and hose? I am doing this swap out presently, and I do not see any reason not to use the venting of the Bay tank.
Well, I am going to try it out. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Mon Oct 29, 2012 11:37 am Post subject: |
peaceful warrior wrote: |
Well, I am going to try it out. |
I have my bay tank vented. I do second guess it every once in a while because it stinks up my garage. I will need to figure out a charcoal stopper for the end. _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
Daddybus Samba Member
Posted: Mon Oct 29, 2012 12:03 pm Post subject: |
It's difficult to get a full tank at the gas pump when you don't vent the top of a bay tank. I run the stock '68 bay vent tube and just route it to the filler neck so when the air in the tank rises to the top of the tank as it gets displaced by the incoming fuel it just flows back to the open filler. Otherwise, the air gets trapped in the top of the tank and you have to rock the bus side-2-side to burp the air out the filler neck. Here's a picture.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Oct 29, 2012 12:05 pm Post subject: |
Where are you guys getting the rubber sleeve for the filler tube? Or are you just using the bay set up? _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Mon Oct 29, 2012 12:56 pm Post subject: |
napa auto parts stores carry the stuff. Cant remember the size used. 2 inches?? Anyway its about 3 to 5 bucks a foot so yeah its not cheap. Just went into garage to look at spare hose. Numbers on it are 031109 sae j30r6 ebp 78cn25. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Posted: Mon Oct 29, 2012 1:11 pm Post subject: |
Thanks. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Mon Oct 29, 2012 1:30 pm Post subject: |
crofty wrote: |
Where are you guys getting the rubber sleeve for the filler tube? Or are you just using the bay set up? |
I just went and bought some at O'Reilly's. I bought a 4' length being that is how it comes though they would have cut it for me. I figured it didn't hurt to have some extra. It cost me $50. ID was 2 1/4". _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Mon Oct 29, 2012 1:34 pm Post subject: |
Daddybus wrote: |
I looked at my Bay and the vent hose goes into the cap area, but it is closed off from the engine compartment, unlike the Split. I am going to run it into the bit of metal that is to the rear of the gas cap.
Trying to decide whether to use the Bay or Split end of the pipe and cap. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Mon Oct 29, 2012 1:36 pm Post subject: |
KevinAlbrecht wrote: |
I have my bay tank vented. I do second guess it every once in a while because it stinks up my garage. I will need to figure out a charcoal stopper for the end. |
Kevin, what about running it thru a Bay Charcoal canister somewhere above the right rear fender well.....there seems to be enough room to mount one? _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Mon Oct 29, 2012 2:33 pm Post subject: |
Kevin, what about running it thru a Bay Charcoal canister somewhere above the right rear fender well.....there seems to be enough room to mount one? |
Yeah, that sounds like an idea. I did not know where to get one. I was gonna start scoping out pet stores' aquarium sections. I like the Bay filler neck that pipes it back in, but that kinda defeats the idea of venting the tank, doesn't it? _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Mon Oct 29, 2012 3:25 pm Post subject: |
Here is my install on my '58 panel. I knocked a little dent into the tank so I wouldn't have to cut the trans tunnel.
I had the added benifit of a hole cut into the top of the engine bay. So that made room for the top hump to clear going over the trans tunnel. Also, the '58 had no gas guage, just the reserve petcock and cable accuater. I put in a stock tank sender and will find an aftermarket guage to mount under the dash.
_________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
