olivierfr Samba Member
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Tue May 16, 2006 10:32 am Post subject: |
It looks like a real 383 to me. _________________ Glenn
Member #1009
#BlueSquare |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue May 16, 2006 11:08 am Post subject: |
Nope.
Real 25 hp doesn't have the the oil ring groove. Ask for the date code off the bottom... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Glenn Mr. 010
Posted: Tue May 16, 2006 11:58 am Post subject: |
I stand corrected... but it IS a real 383. Maybe mid 50's Porsche. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue May 16, 2006 12:15 pm Post subject: |
Yes, and given the seller id "a356guy" it probably is a P-dist. He says it "fits 1949-1953", true, but it was never used on a 25 hp VW engine.
I asked him for the date code via the eBay auction, but no reply.....yet. _________________ John Henry
'57 Deluxe
'56 Single Cab |
splitjunkie Samba Member
Posted: Tue May 16, 2006 12:16 pm Post subject: |
Quote: |
Real 25 hp doesn't have the the oil ring groove. |
Are you sure about that? My Oct. 51 split has the groove. It was parked in 62 with 120,000 miles on the odometer. The only things replaced on the motor were the regulator and the manifold. It has the Zwitter manifold and the regulator is the square black painted Bosch version so it is pretty original.
My distributor has the wire cap clamps. If it were a later replacement I would think that that it would of had the flat steel clips.
I have seen lot's of pictures of these distributors but only own the one, but I have seen many more with the groove than ones without it. I have always assumed that the earlier ones did not have the groove but that it was addes at some point during the production of the 25hp. I'll have to look it up in progressive refinements.
Chris |
Posted: Tue May 16, 2006 12:31 pm Post subject: |
johnshenry wrote: |
Yes, and given the seller id "a356guy" it probably is a P-dist. |
a356guy is the highest bidder at the moment, anyway this could confirm your idea (porsche part).
thanks, i will think about bidding or not bidding ... |
Posted: Tue May 16, 2006 12:39 pm Post subject: |
splitjunkie wrote: |
Chris |
Simple quandry to answer: what is the date code on the bottom of your dist??? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue May 16, 2006 12:41 pm Post subject: |
olivierfr wrote: |
johnshenry wrote: |
Oopps, you are right. Yes, it would explain why he is bidding. That dist (with the oil ring) was used in the P-cars until '54 or '55 I think.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Glenn Mr. 010
Posted: Tue May 16, 2006 1:06 pm Post subject: |
I ran into this with a 383 that I restored. John pointed out that mine had an o-ring and the 25hp ones did not. He also told me about the date code which is stamped on the base of the body. It's a 2 digit, number and letter which denote the manufacture date. Mine was a April 1956 distributor. After some additional research I found that Porsche continued to use the 383 on the 356 long after VW stopped.
So it will work and is a 383 distributor. But if you want to be really correct, it's not the right one for a VW.
Thanks John for teaching an old dog a new trick. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue May 16, 2006 1:10 pm Post subject: |
Thanks for you both, this will help me in my 383's quest .
Olivier |
Glenn Mr. 010
Posted: Tue May 16, 2006 3:45 pm Post subject: |
That one sold for only $160. It looked in really nice shape and has a new German cap. It was worth more than that.
Someone got lucky. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue May 16, 2006 5:11 pm Post subject: |
what is the syntax for the date code? I can make out a 50 but not the letter.
Chris |
Glenn Mr. 010
Posted: Tue May 16, 2006 5:19 pm Post subject: |
Chris |
John Henry emailed me this a while ago.
Quote: |
John Henry wrote:
As of March '51 Bosch began date coding all distributors at the bottom edge of the housing, with the same designations as their generators (see pic). Number for the month, letter for the year, with A at 1945. The letter I is skipped. A "4G" then is an April '51 manufacture. Distributor dates generally lead the manufacture date of the car they were installed in by 2-4 months.
Member #1009
#BlueSquare |
Posted: Tue May 16, 2006 5:47 pm Post subject: |
thanks Glenn,
I think it is 5J so May 53. You learn something new every day.
The car was serviced by Snider Motors in Knoxville from at least 58 to 61 and probably earlier. They were a VW and Porsche dealership so it would make sense that they would have acess to Porsche parts although according to progressive refinements the rubber seal was added in Nov. 52 chassis #1-0412 822.
The 30hp was not introduced until Dec. 53 chassis # 1-0575 415. So the rubber seal was used on the 25 hp but not until Nov. 52.
Chris |
Matthew Tolbert Samba Member
Posted: Wed May 17, 2006 5:24 pm Post subject: 25 hp dist. |
you guys got me wondering whether my distributor is correct or not so i went to look for this date code and could not find it. i have a may 53 car with the original engine and the dist. has the oil groove. where exactly is the date code? pics maybe?
thanks
matthew tolbert |
Posted: Wed May 17, 2006 6:04 pm Post subject: |
the rubber seal was added in Nov. 52 chassis #1-0412 822 so yours should have the seal.
It is on the small part of the base before it goes into the engine. It is quite small and hard to find because that part of the distributor has the rough as cast finish and is painted.
You will most likely need to remove it and clean the base to be able to find it.
Just remove the nut that holds the distributor clamp to the case and remove the wire and cap and pull the whole thing out that way you will preserve your timing setting. Like Glenn said the date will most likely be several months earlier than your car.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=276221
Chris |
Posted: Wed May 17, 2006 6:23 pm Post subject: |
i probably wouldnt have ever found that. thanks for the pic now i am going out to look for it.
matthew tolbert |
Posted: Wed May 17, 2006 7:13 pm Post subject: |
Actaully, they can be in a number of places. Here is the one on my earliest dist:
Most I have found are on the lower sides, not the bottom as I erroneously stated previously.
Also, I was told that they only started doing this coding in '50 or '51, so it is likely that some earlies (no oil seal ring) have no code. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Glenn Mr. 010
Posted: Wed May 17, 2006 7:18 pm Post subject: |
What I find odd is of the 6 or 7 383 distributors i'ver restored there's no rhime or reason for which have the wire style distributor cap clips and which have the solid ones.
Does anyone have any info on them?
For example this one came with the solid clips, but it has the early perferated ozone screen. It also has an o-ring so i'd assume it was a later one.
But it also has the early large diameter capacitor.
Member #1009
#BlueSquare
