Fritter Samba Member
Joined: October 14, 2004 Posts: 232 Location: Chicago
Posted: Wed Mar 23, 2011 3:05 pm Post subject: |
Anyone know how many turbines are in the Harbor Freight 44677? It seems the more turbines the better. _________________ Mike
'64 Sunroof Bug |
refinisher Samba Member
Posted: Sun Apr 10, 2011 1:03 pm Post subject: |
Hey guys i just started an account here because of this thread. I refinish bathtubs anf countertops for a living using a turbine setup. I usually spray with a capspray cs8100 but have also used the new titan 6 stage units. Based on my expierence with theese i can say without a doubt how imperative it is to properly thin the paint. From what i have seen, thinning/reducing 20% makes the paint go on very evenly with minimal orange peel. The manufacturer suggests 10% but they are assuming your using a traditional compressor.
Anyway the point i am trying to make with this is that i have alot of expierence with theese and i can chime in that they work quite well, and while i am not spraying cars with it, i have colleagues who have with good results. We use both epoxy based and ureathane based paints. |
paulski Samba Member
Posted: Sun Apr 10, 2011 1:42 pm Post subject: |
benCarn wrote: |
Quote: |
What the hell would the longevity have to do with what gun it was shot with? |
So if you're willing to spend $40.00 on a paint sprayer, Im more than sure you aren't using high quality paints in that sprayer. Guess I had to spell it out.
Still wanna see some of those paint jobs a year or two down the road. |
Thought i'd put up a quick update. Finally got this all finished this weekend, as the bike had been imported from Italy and took a while to register etc. One of the side panels had reacted as well (my fault not guns) so redid this yesterday, came out pretty good seeing as its cellulose paint.
The rest of the paint on this is over a year old and holding up perfectly. Bike is garaged, but unheated, and UK winters are very wet/cold/miserable. All finished -
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Sun Apr 10, 2011 2:39 pm Post subject: |
That looks great!
How much color sanding to get it that smooth? _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Mon Apr 11, 2011 8:20 am Post subject: |
No a huge amount tbh. Definately needed colour sanding as there was orange peel, but again thats most likely down to my technique (or lack of it!) Just sanded down with 1200, finished with 1500 and polished out with Farecla G10, that being said cellulose is a lot easier to colour sand then 2 pack. |
vwsb74 Samba Member
Posted: Tue Apr 12, 2011 9:16 am Post subject: |
[quote="paulski"]No a huge amount tbh. Definately needed colour sanding as there was orange peel, but again thats most likely down to my technique (or lack of it!) Just sanded down with 1200, finished with 1500 and polished out with Farecla G10, that being said cellulose is a lot easier to colour sand then 2 pack.[/quote
Is the paint 2 stage? Can I sand the color then clear it? Thanks _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Posted: Fri Apr 15, 2011 3:21 am Post subject: |
This was a single stage paint as its cellulose. With a two stage so long as their isn't horrific orange peel on the base coat you can clear over it then sand and polish the clear coat. |
bllgrn Samba Member
Posted: Wed Apr 27, 2011 5:27 pm Post subject: |
I just picked up the HF HPLV turbine a couple days ago and just took it out of the box tonight. I apologize if this is a stupid question, i've only done rattle can jobs in the past.
Is it normal that that it pushes so much air even when the lever to spray is not depressed? |
Budreaux Samba Member
Posted: Thu Apr 28, 2011 7:58 pm Post subject: |
bllgrn wrote: |
Yes, completely normal operation for that unit. I have the same one. |
bllgrn Samba Member
Posted: Fri Apr 29, 2011 3:50 am Post subject: |
Budreaux wrote: |
bllgrn wrote: |
Thanks, I used it last night to spray a coat of primer over my motorcycle tank, at first it was spitting up paint, i loosened the cap in the front of the gun and that seemed to help.
Next question, how the heck are you supposed to clean these things? All I had was paint thinner and that didn't seem to do much. I let it soak overnight but it is still stuck on and I worry that letting it soak in thinner might eat away at some of the softer pieces... |
hpw Samba Member
Posted: Fri Apr 29, 2011 4:00 am Post subject: |
bllgrn wrote: |
Budreaux wrote: |
bllgrn wrote: |
"Paint thinner" MIGHT not be the proper thinner for the paint you are spraying. What primer are you spraying?
You have to dis-assemble to properly clean |
bllgrn Samba Member
Posted: Fri Apr 29, 2011 6:47 am Post subject: |
hpw wrote: |
I am using Transtar Euro Classic Primer:
Euro Classic Primer is a two component primer surfacer that can be applied direct to
metal surfaces. It is quick drying and easy to sand wet or dry. It provides corrosion
protection along with excellent fill and build properties. This unique primer provides
improvements in productivity and reduces cycle times while providing significant
labor and material savings. This primer can also be tinted using Transtar’s exclusive
“Star Shade” system for a better match. Easy 4:1 mix ratio.
I did disassemble, and spent well over an hour scrubbing it with a hard bristle brush and scrapping with a flat head screw driver and got most but not all of it off. The biggest problem I can see is that the plastic tube that extends from the gun to the canister is lined with paint on the inside and I can't figure out how to clean it. |
Posted: Fri Apr 29, 2011 6:52 am Post subject: |
I always ran mineral spirits or whatever solvent is appropriate through the gun. I spray them like paint onto a piece of cardboard outside.
After the tube and stuff are clean then I disassemble the gun and clean that.
But if you don't catch the paint early enough, I don't know. I have a gun I forgot to clean that is just setting there. There's enough plastic in the body that I'm afraid to soak. So I just bought another one. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
bllgrn Samba Member
Posted: Fri Apr 29, 2011 7:28 am Post subject: |
DurocShark wrote: |
But if you don't catch the paint early enough, I don't know. I have a gun I forgot to clean that is just setting there. There's enough plastic in the body that I'm afraid to soak. So I just bought another one. |
I started cleaning immediately after spraying with some paint thinner I had sitting around, apparently that was the wrong solvent. |
Brionp Samba Member
Posted: Fri Apr 29, 2011 7:06 pm Post subject: |
Try Lacquer Thinner or Acetone to clean the the Gun. Then run paint thinner through it. |
bllgrn Samba Member
Posted: Sat Apr 30, 2011 5:49 am Post subject: |
Brionp wrote: |
Lacquer thinner worked like a charm! Thanks guys. |
bllgrn Samba Member
Posted: Fri May 06, 2011 8:58 pm Post subject: |
I struggled through sanding tremendous amounts of orange peel when spraying the primer over the past week. Tonight I took my first stab at spraying my base, I am using PPG Deltron with PPG reducer. I used more then the recommended reducer after thinking that was the trick with turbines but now I wonder if I should have used less
My results are astoundingly bad and I don't think I could have done worse if I tried. I am going to try using less reducer but I am open to suggestion at this point.
[img][/img] |
Posted: Fri May 06, 2011 9:15 pm Post subject: |
Looks like an Alien head... _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
hpw Samba Member
Posted: Sat May 07, 2011 2:07 am Post subject: |
or a BAD case of fish eye. |
Posted: Mon May 09, 2011 7:06 pm Post subject: |
bllgrn wrote: |
[img][/img] |
I use mineral spirits and use a 50/50 mix. Lays down smooth and levels nicely. |
