MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1475 Location: Westfield, MA.
Posted: Fri Nov 27, 2020 6:17 am Post subject: Cam Followers |
Good morning. I have a low mile 1975 engine thats been torn down for a refresh because of sitting around forever.. The cam is great but lifters are questionable...nice but pretty much flat. What brand would you recommend for a stock rebuild and original cam? I was thinking to go reground but search seems to reveal problems with those lately. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Fri Nov 27, 2020 1:01 pm Post subject: Re: Cam Followers |
Measure all the lobes before reusing. Reground German lifters are fine. Send your lifters out. I think SLR costs $65 in labor. I sent three sets to Steve recently. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sun Dec 13, 2020 7:05 pm Post subject: Re: Cam Followers |
bugguy1967 wrote: |
Measure all the lobes before reusing. Reground German lifters are fine. Send your lifters out. I think SLR costs $65 in labor. I sent three sets to Steve recently. |
Thanks. I've been searching, but can't find any guide on cam visual inspection or how to measure. Any advice? Leaning towards just getting a new cam, but I have a couple that look low miles to me. Thanks |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Dec 14, 2020 8:13 am Post subject: Re: Cam Followers |
unitedracing wrote: |
bugguy1967 wrote: |
You need a digital dial caliper and measure each base circle and measure the total lift of the lobe. Subtract the two numbers to see how close they all are.
As for lifters, regrounds are great....IF they are done correctly and washed correctly afterwards. If you don't have a place to buy them from that you trust 100%, then you should buy new, saving $8 isn't worth it if your cam goes flat and you have to do it all twice. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Posted: Mon Dec 14, 2020 8:45 am Post subject: Re: Cam Followers |
[email protected] wrote: |
bugguy1967 wrote: |
As for lifters, regrounds are great....IF they are done correctly and washed correctly afterwards. If you don't have a place to buy them from that you trust 100%, then you should buy new, saving $8 isn't worth it if your cam goes flat and you have to do it all twice. |
Thanks Roy! Looks like I'll be hitting you up for some lifters once I check my cam. Probably reground but if i decided to go new what lifters do you recommend for a stock cam? And if its bad I know you have reground cams also. Are you aware of any different in the 75 to 79 Beetle FI cams. The few I have all have an F after the part number however when looking at new, they are all the same 1972 on. |
