kccabledude Samba Member
Posted: Tue Jun 13, 2006 5:50 pm Post subject: How many volts? |
How many volts should my bosch alt be putting out? It's a AL 82N, if that tells you anything. Also how do you check? I put my volt/ohm meter on the 2 posts on the top of it and it only read 11.89 volts DC. Thanks for any info. |
cbr900racer Samba Member
Joined: April 29, 2005 Posts: 1360 Location: middle tennessee
Posted: Tue Jun 13, 2006 7:27 pm Post subject: |
i couldnt remember the exact voltage of mine, so i ran out to garage and checked....13.66 at 1krpm. is your idiot light connected and working? (just for the heck of it i checked the spade connector that goes to said idiot light, it read 14.54..) |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Wed Jun 14, 2006 2:09 am Post subject: |
Usually alternators should put out around 14VDC. That 11.89 is not good at all, as that low of voltage is well below the nominal rest voltage of the battery, which is 12.5-12.6V usually. That your battery is below 12V means it is going dead and no charging at all is going on. Sounds like they alternator could be bad, or you might be lucky and your warning light might be out. The alternator will not begin to charge unless it gets the warning light current to "kick" the regulator into charge mode.
-Andy |
Posted: Thu Jun 15, 2006 7:30 pm Post subject: |
I found the problem the wire going back to the dash light was cut. Thanks for the help. |
