janerick3 Samba Member
Posted: Thu Aug 14, 2014 7:08 pm Post subject: |
The coil has been replaced, as the TE6A3 coil was used until the end of the 1956 model year. This explains why the bracket is missing.
Also, my Dec '54 Barndoor engine with an upright air cleaner has the fuel line hole in the front tin. I believe the tin is original. _________________ Thanks,
Jan K. |
D-train Samba Member
Posted: Thu Aug 14, 2014 7:35 pm Post subject: |
janerick3 wrote: |
Also, my Dec '54 Barndoor engine with an upright air cleaner has the fuel line hole in the front tin. I believe the tin is original. |
Was that for my engine or the Barndoor one? _________________ shiny paint doesnt make it worth any more |
Posted: Thu Aug 14, 2014 8:39 pm Post subject: |
D-train wrote: |
janerick3 wrote: |
Was that for my engine or the Barndoor one? |
Yours. I can read "TE6B1" on the end of the coil. _________________ Thanks,
Jan K. |
Posted: Fri Aug 15, 2014 4:53 am Post subject: |
janerick3 wrote: |
D-train wrote: |
janerick3 wrote: |
Yours. I can read "TE6B1" on the end of the coil. |
Correct, now I have to find the right strap n coil... Damn.
Got the right crank start apron for it now too.
Didn't realize that there was 2 different styles to go along with the front pulley tin until 2day, it's prob in this thread and I've read it but forgotten.
U can see the differences with the finger section.
An I found a triangle bracket, just need a finger now.
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3776 Location: Twin Cities, MN
Posted: Fri Aug 15, 2014 5:13 am Post subject: |
Finger is for 25hp. You want the pulley tin with no finger.
This is 25hp tin.
Posted: Fri Aug 15, 2014 5:20 am Post subject: |
U sure? Australia was limited with 25hp motors an I have 2 of the finger crank tinwares, plus my engine has been I storage for 40? odd years.
By the looks of it too, the front pulley has never been off and it's the no finger pulley tin, so needs the finger crank start tinware if that makes sense. _________________ shiny paint doesnt make it worth any more |
Posted: Fri Aug 15, 2014 5:24 am Post subject: |
D-train wrote: |
By the looks of it too, the front pulley has never been off and it's the no finger pulley tin, so needs the finger crank start tinware if that makes sense. |
The pulley is a later pulley too as has been stated. So yes, you need the crank start tin with no finger, the one with blue paint on it above. |
Posted: Fri Aug 15, 2014 5:35 am Post subject: |
nlorntson wrote: |
D-train wrote: |
I'm goin to have to look into this now. I've never seen a random 25hp engine around the place here unless in an early car (which are very few) so it wouldn't explain why I have 2 25hp crank tinwares.
When did the thin lip pulley finish tho?
Australia had random things too, not standard stuff like USA _________________ shiny paint doesnt make it worth any more |
Posted: Fri Aug 15, 2014 9:20 pm Post subject: |
D-train wrote: |
I have an April 1956 engine w/the thin lip pulley... _________________ Thanks,
Jan K. |
Posted: Fri Aug 15, 2014 9:51 pm Post subject: |
janerick3 wrote: |
D-train wrote: |
I have an April 1956 engine w/the thin lip pulley... |
Good call. I'll have to swap it then.. _________________ shiny paint doesnt make it worth any more |
Posted: Tue Aug 19, 2014 3:04 am Post subject: |
fixed the missing screw..
and changed the pulley.
Posted: Wed Aug 20, 2014 4:30 am Post subject: |
so this is seriously, just an oil change and clean the plugs. scraped out the sludge from where my finger could fit around the sump plate.
didnt touch the points, clearances or anything.
the pump even worked. needed to bypass the og line to the pump, it had holes.
got fuel into the carb, then cranked away with the crank handle.
then this happened.
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Wed Aug 20, 2014 4:41 am Post subject: |
super stoked for you! |
Posted: Thu Aug 21, 2014 1:32 am Post subject: |
Just another quick one showing this motor.
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Thu Aug 21, 2014 9:32 pm Post subject: |
Thats one of the reasons I love these 36hp engines!! I did the same thing with an engine that was sitting on a barrel in a lean-to for 30+ years. The guy I bought it from remembered his dad setting it there after he pulled it out of a wrecked 56' oval. That's awesome! |
Posted: Fri Aug 22, 2014 6:07 pm Post subject: |
motofly196 wrote: |
makes it all that much better doesnt it.. good to hear yours did the same too!! _________________ shiny paint doesnt make it worth any more |
PASHN8 Samba Member
Joined: January 30, 2011 Posts: 152 Location: Melbourne, Australia
Posted: Tue Nov 04, 2014 3:58 am Post subject: |
Here's my September '54 36hp nearing completion, yes I know the coil should be black
Any other notable errors? One thing to note, it has been 12v converted, but aiming to keep the stock 6v look
_________________ www.dinography.com.au - Dino!
1957 11-Window Split Bus
1954 3-fold Sunroof Oval Beetle
*** Looking for '56 Porsche T1 356A 1300 engine no. 22373 *** |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
splitjunkie Samba Member
Posted: Tue Nov 04, 2014 10:28 am Post subject: |
uberwagen wrote: |
What is not correct for early january type 2 ? (Ignore the 1- case number)
...Discuss...
That is one rare sigt. Those original manifolds are very hard to find. Did that bus come with that manifold or did you add it? If you have any problems with the engine running correctly, a vacuum leak from the inside of the jacket is the first thing to check. _________________ Chris
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
