dixonmanor Samba Member
Posted: Mon Jun 26, 2006 6:18 pm Post subject: Help!! |
So, drove the Thing to Seattle from Portland... no problems. On the way back, however, we stopped to gas up, and when I turn the key... nothing! So, push-start it, it fires right up, drive down to portland fine. Get off the freeway, as soon as I come to a stop, it dies. It continues to die at stops unless I keep the engine revved up. I managed to make it back to my house, but had to push-start it about five times along the way.
What's goin' on?!?! |
LEJ Samba Member
Joined: May 13, 2006 Posts: 115 Location: Ontario, Calif.
Posted: Mon Jun 26, 2006 6:33 pm Post subject: |
Several thing could be happening here. When you tried to start the car, I get the impression that the starter didn't even ""click""" If this is the case, 2 basic things could be wrong. 1. Bad starter 2. The wire that goes from the key to the starter that activates the solenoid could have fallen off. Typically it's a 14 gauge wire with a female spade fitting, you'll have to look for the male fitting on the starter and if it fell off, re-attach it. Also, gently tighten the spade fitting before re-attaching.
Of course it could also be a bad key switch.
The engine thing could be a bad fuel cut off solenoid or a bad fuel pump that's not supply enough fuel to keep the carb from running dry. It could also be a bad electrical wire that feeds the fuel solenoid so check it out, it runs from the + side of the coil (the side that doesn't contain the wire from the distributor) to the solenoid than to the electric choke.
It could also be bad points, bad plugs, bad wires, bad rotor or cap. Could also be a plugged fuel line or a plugged filter.
This should be enough for now to get you started in the diagonisis.
good luck _________________ The more you know, the more you know you don't know.
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Mon Jun 26, 2006 6:52 pm Post subject: |
check your battery cables. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
Thanks! |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Mon Jun 26, 2006 7:13 pm Post subject: |
How old is the battery? They do not seem to last as long as they used to? |
Posted: Mon Jun 26, 2006 10:03 pm Post subject: |
It's not the battery... That was my initial thought and I had a guy jump me- made no difference. |
Posted: Tue Jun 27, 2006 10:12 am Post subject: |
So, after sitting over night- it started right up, drives fine, no problems. Could it have been the extreme heat we're having here in the NW? What's the story with that... I know vapor lock can be a heat-related problem, but this wasn't vapor lock. |
chinarider Samba Member
Joined: November 08, 2002 Posts: 276 Location: San Francisco, CA
Posted: Tue Jun 27, 2006 10:28 am Post subject: |
Sometimes large particles in your gas tank or fuel filter can lodge themselves against hoses and openings, thereby blocking your fuel flow. Allowing the car to sit overnight usually allows the particles to dislodge themselves and settle down, but this is sort of an off-chance reason for your troubles. Still, something worth ruling out. |
