Gauges
Goto page Previous  1, 2, 3, ... 9, 10, 11  Next
Forum Index -> Accessories/Memorabilia Share: Facebook Twitter
IN2VWS
IN2VWS is offline
PostPosted: Thu Jul 27, 2006 4:14 am    Post subject: Re: VDO 3K RPM Tach Reply with quote
will-g wrote:
This one just closed on the auction site. i did not bid becouse it did not seem right, all the other period VDO tachs for VWs that have been posted are 6-8RPMS and this one is only 3 Confused
That one is for a boat or an industrial engine. The oval tachs went to 5,000 rpm, like this one:
kai Premium Member
kai is offline
PostPosted: Thu Jul 27, 2006 9:19 am    Post subject: Re: VDO 3K RPM Tach Reply with quote
Then what are the 6,000 and 8,000 rpm tachs for?
There's more to life than VW's.. Wink
'58 143
Please check my ads: http://www.thesamba.com/vw/classifieds/search.php?username=kai
IN2VWS
IN2VWS is offline
PostPosted: Thu Jul 27, 2006 2:32 pm    Post subject: Reply with quote
The VDO brochure shown is from 1956. The brochure is for VW's only
I must say that I have not seen a 6,000 or 8,000 rpm tach with the rings on the face to match the speedo. I have seen them without the rings, but these are generic tachs, not specificly made for VW's. Does anyone have one?
HamburgerBrad
Je suis Napoléon!
HamburgerBrad is offline
PostPosted: Thu Jul 27, 2006 3:57 pm    Post subject: Reply with quote
good call on the rings. now i know what to look out for. i've just never seen one with them before as far as i recall
OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels
IN2VWS
IN2VWS is offline
PostPosted: Fri Jul 28, 2006 3:48 am    Post subject: Reply with quote
I thought the rest of the 1956 VDO brochure deserves to be listed here:
HamburgerBrad
Je suis Napoléon!
PostPosted: Fri Jul 28, 2006 9:19 am    Post subject: Reply with quote
so i assume 80mm (3 1/8") is the correct size to fit in the oval dash grills? and out of curiosity, did all of those grills for gauges have the same size hole?
OGST | CU05 | OGJHC
1970 baja|1953 oval
53 0val
Samba Professor
53 0val is offline
PostPosted: Fri Jul 28, 2006 9:27 am    Post subject: Reply with quote
If your talking about the accessory oval grill.........you are correct. 60mm is correct for the center hole of a MotoMeter panel though.
kai Premium Member
kai is offline
PostPosted: Mon Jul 31, 2006 10:50 am    Post subject: Reply with quote
What era is this for?
'58 143
Thornton
EMPI Guru
Thornton is offline
PostPosted: Mon Aug 07, 2006 2:22 pm    Post subject: Reply with quote
i have the same ammeter NOS and it has 62 date stamp on it
Thornton
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Fri Aug 18, 2006 10:11 am    Post subject: Reply with quote
bathing ape wrote:
could someone please put up instructions for wiring empi gauges gen3,i have the sender,cheers
http://www.amayesing.com/images/literature/empigaugewirediagramJB.jpg
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Fri Aug 18, 2006 10:17 am    Post subject: Reply with quote
I recently almost made a collectors faux pas, I had purchased a couple of gauges and was about ready to sell the 140 lb empi white glove oil pressure gauge when I fortunately noticed that in my full set of white globe gauges the oil pressure was an 85 lb version. All my catalogs show the 140 type.
Image may have been reduced in size. Click image to view fullscreen.Image may have been reduced in size. Click image to view fullscreen.
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Fri Aug 18, 2006 10:18 am    Post subject: Reply with quote
three different logo'd speedwell oil temp gauges.
Thornton
EMPI Guru
Thornton is offline
PostPosted: Sun Aug 20, 2006 9:19 pm    Post subject: Reply with quote
both versions are not rarer than the other
i have had both styles many times
I went on a HUGE Gauge collecting spree and have notice the differences
white globes, black globes even speedwell gauges have all different readings from Oil pressure to Oil temp. I have owned all styles
Oil Temp 280 degrees
oil temp 250degrees
Thornton
will-g
Samba Shalako Expert
will-g is offline
PostPosted: Mon Aug 21, 2006 12:26 am    Post subject: Reply with quote
Now that my friends is a gauge collection Cool
These are not the New Old Stock parts you are looking for...
"My pappy said son, you worthless hippy, you shameless drug fiend, you no good alcoholic, you commie punk, you gonna drive me to drinking if you dont stop driving that hot rod lincoln"
HamburgerBrad
Je suis Napoléon!
PostPosted: Fri Sep 22, 2006 2:11 pm    Post subject: Re: VDO 3K RPM Tach Reply with quote
so i just noticed that these two tachs are slightly different. anyone know why?
OGST | CU05 | OGJHC
1970 baja|1953 oval
vwovalguy
vwovalguy is offline
PostPosted: Sat Sep 23, 2006 10:00 pm    Post subject: Reply with quote
One is an RPM tach for the North American market and some Euro countries. The other is U/minx100 were for most European coutries. Metric/Imperial Confused
doubledoor64
doubledoor64 is offline
PostPosted: Mon Sep 25, 2006 7:31 pm    Post subject: Reply with quote
i just got this and it's dated 11/56 what would it be worth in this shape??
66doka
66doka is offline
PostPosted: Tue Oct 03, 2006 5:07 pm    Post subject: VDO tach Reply with quote
I have a VDO tach that I know little about. I do not know what it is for or when it was made. What I do know is it is a 3 1/8" silver face with chrome ring. It goes to 8000 upm, redline at 6000. The numbers read one digit X 1000. What I find interesting about it is that it is a 6V tach. I will try and post pics as soon as I take them.
66doka
66doka is offline
PostPosted: Fri Oct 06, 2006 8:35 pm    Post subject: Reply with quote
I know it is a bad pic, but it is the best i can do for now. http://mypics.mts.ca/share.do?invite=7ECr4bJI2P85Da8778To&slide=1
IN2VWS
IN2VWS is offline
PostPosted: Sat Oct 07, 2006 12:21 am    Post subject: Reply with quote
Looks like it is from a BMW 1602 or 2002.
Reply to topic    Forum Index -> Accessories/Memorabilia All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 2 of 11
