vwthingrcer Samba Member
Joined: January 29, 2005 Posts: 462 Location: reno nv
Posted: Sat Jul 29, 2006 11:37 am Post subject: lifting a thing |
im looking to lift my thing with out using the lift kit. any ways I can lift it? coilovers? _________________ 1973 vw thing 1600cc engine ONce agian is a live
1971 super beatle for sell
1964 bug type 4 getting ready to race |
suntour Samba Member
Joined: November 25, 2004 Posts: 443 Location: Woodinville, WA
Posted: Sat Jul 29, 2006 8:21 pm Post subject: |
Do you have any idea what is involved with using coil-over springs? (well besides a hell of a lot of money) _________________ Order of the Voodoo Spoon |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Sat Jul 29, 2006 9:41 pm Post subject: |
Why do you want to lift it? For larger tires? Clearance?
If you wish larger tires there are new fenders with clearance for them. If you go too much bigger you will need a bigger motor. Some people have used body spacers to get more clearance but this only gives tire room.
There are raised spindles and adjustable beams. Maybe a early rearend with boxes.
You will get more informed answers here with full questions. State your current motor size and tire set up, what kind of tranny you have. Tell us why you want to raise it. |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Jul 30, 2006 4:14 am Post subject: |
Raising it via the torsion bars is your best bet, but that assumes you know how to do that. |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Sun Jul 30, 2006 9:32 am Post subject: |
Mighty small thinking, TR. I mean, if you're going to bolt in a more powerful motor, it'd better be a type 4, right? And while you're at it, make it a turbocharged type 4.
And re-indexing the springs will give you what - maybe 3 inches of lift in front? Why bother?! Six inches of lift sounds like a good place to start.
Think big, BE BIG. |
Thingggg Samba Member
Posted: Sun Jul 30, 2006 10:12 am Post subject: |
Quote: |
Raising it via the torsion bars is your best bet |
I would also start here and use lager tires next to get more ground clearance.
If the tires are huge, then I would also add body lift.
Remember big means more CV wear. |
Posted: Sun Jul 30, 2006 12:01 pm Post subject: |
i know how to raise the torsion. but how do you raise the front _________________ 1973 vw thing 1600cc engine ONce agian is a live
Posted: Sun Jul 30, 2006 3:21 pm Post subject: |
The front end suspension is torsion bars you can buy adjusters, they can be turned to give lift and add stiffness. Or you can just turn them and not have them adjustable.
The book below will tell you how to do all this it is a great book and shows other options:
Baja Bugs & Buggies By Jeff Hibbard. Includes engine & transaxle mods, roll bars/cages, skid plates, tires, wheels, brakes, lights, driving and safety tips, breakdown solutions, and more! |
Posted: Sun Jul 30, 2006 8:05 pm Post subject: |
Lifting a Thing is such a vague term that it’s hard to give you any answers. To one person it’s a 3” body lift, to another it’s a cut and turned front end and re-index the rear torsion bars. (See the off-road forum sticky on this subject) any then there is the mid to long travel suspension with a combination of body modifications to fit the tires.
If you’re serious about the whole coil-over thing you need to make a serious commitment of time, money and fabrication skill to make it happen. Those mid to long travel off-road machines start around 30k and only go up. Just the rear shocks and springs start around $1800. This is not something to half-ass, you’ll just end up trashing a perfectly good Thing or worst case killing yourself when the suspension fails.
At this point wouldn’t you just be better off with a Jeep or something? _________________ Order of the Voodoo Spoon |
racer_dude Samba Member
Joined: May 11, 2006 Posts: 99 Location: Oak Hills, CA
Posted: Mon Jul 31, 2006 1:16 pm Post subject: |
suntour wrote: |
At this point wouldn’t you just be better off with a Jeep or something? |
he doesnt want a jeep, he likes his thing... just like i like my thing and paid good money for it instead of something "like a jeep"
$1800 is VERY steep, where are you getting your prices from? i can buy all 4 shocks for each corner and have money to spare on a $1800 budget. you can get top of the line racerunner shocks from sway a way for $250 plus springs which they list for approximatly $60 or so for sinlge rate.
as far as fabricating the mounts, yeah it might be pricy or very time consuming, but VERY possible. it is what im going to do further down the road with my thing, along with a big motor and full cage/ bucket seats and bench...
vwthingrcer- my beam is cut and turned, and im not sure if the bars are preloaded in the rear but i have room to clearance 7.00x15's up front and 33x9.50's out back, i have no fenders yet, but have had friends with the same set up that used stock front fenders and wide rears that had zero problems. i was thinking about getting a body lift, but i dont think i need one as of yet. as far as ground clearance, i have tons, probly more than my race car.
like alsehendo34 said, get the book "Baja Bugs and Buggies" it will help you a lot... |
Posted: Mon Jul 31, 2006 3:41 pm Post subject: |
For the weight of a Thing you need to run at least a 2.5 shock, a 2.0 is going to have a hard time dealing with the weight. The cheapest 2.5 with reservoir (Fox or King) with 14” travel is around $500 a piece add another $200+ for a dual spring setup per shock for the rear end. Add to this limit straps, brake lines, mounts and misc. parts and expect to pay $1800.
This doesn’t include new rear trailing arms (3x3), or converting to duel pivot arms. If you stick with traditional trailing arms you should remove the pivot point and re-weld it to the proper angle so you don’t have a case of killer camber. Your also going to want to change out the CV’s to 930’s to handle the abuse and angle. That leads to new snub axles and flanges for the transmission. You can stick with drum brakes or go with disk brake (take your pick). Your also going to need new axles.
This leads to a new transmission and engine to turn the larger wheels (yes a 1600 will work but don’t expect much performance.)
At this point you might as well switch to a King and Link from end with 2 ¼” x 1” arms and combo spindles (torsion or coil-over, take you pick) That means a tubed front end, possibly rack and pinion and relocating your gas tank.
I have not even touched on the rollcage or tube chassis, suspension seats, engine mount modifications, etc.
What I am getting at is that there are a lot of extra do-dads that really add up that are often over looked. Believe me I am looking into doing this exact same thing with my Thing.
I was down at the Baja Shop just the other day to get some quotes and they were the cheapest so far.
Chromoly Chassis $3800 (+or- 10% depending on material cost at time of purchase)
Front shock tower mounts $425
Rear shock mounts $425
Chromoly duel pivot (only 3x3) with heim joints $1400
Mounting body to chassis $500
Total $6550. for a coil-over suspension.
This doesn’t include anything else, I would need tires and rims, all four shocks and springs, cable shifter setup, new pedal cluster, brakes, new steering column (Stock will no longer work with the chassis), brake lines, limit straps, front arms (K&L) combo spindles, bearings, etc, etc, etc… just to get a rolling chassis.
So far I budgeted around $45,000 for this car with all the little things (gaskets, seats, electrical, blah blah.)
Now I have to ask myself, is it worth it? Will I realistically use my Thing (or want to after spending this much) to its full potential? Would I be better off getting a Baja or Manxster? I also plan to drive this around as a part-time daily driver. Will it be streetable? Or just suck on the pavement?
Frankly I don’t care what the hell you do with your Thing, lift it, drop it, throw it off a cliff for all I care but look at the big picture before you jump in half cocked.
P.S. I have had horrible experiences with Race Runner shocks when we were building the Rhino RTV. One major headache after the other… Their air suspension of the other hand was really cool and works well. _________________ Order of the Voodoo Spoon |
Posted: Tue Aug 01, 2006 10:45 pm Post subject: |
whoa... why will you be running 14"? i plan on leaving mine stock for the most part and would be looking at 8-10" coils and a 2.0 will be plenty fine, along with single rate..
a 14" 2.5 means you will be cycling over 12" of travel which means you plan on off-road driving, and doing it VERY hard. im lucky to cycle 10" out of the back of my 5/1600 and 2 2.0 fox's handle the job quite nicely without fade in a race application
i plan on getting +1" arms out back, if i have to make them, i have to make them, i just want the wheel to be centered in the wheel well, and i would like coils just to get the adjustability, i plan on getting 8-10" out of the back, which will be plenty fine for off-road "play", which done properly would only take a 6-8" coil, i dont plan on trying to pre-run all that much if any so a 2.0 will dissapate heat just fine and not fade for my application.. i dont plan on chopping the body up, so i will try, key word try, to make it all hidden.
i dont know what to do up front yet, but i do plan on going rack and pinion along with coils, i would like to use maybe +1 arms so i might have to fabricate a new beam and mount. but i will still try to maintain stock look. We cycle 9" of travel in the the front of the race car with a single smoothie 2.0 with zero fade, so once again a 2.0 will be the coice on the coil.
i do hear that there are a million things that i am overlooking at this point, but my thing the way i want it is still over 3 years from the making.
a coil setup is expensive, but you dont need to go full bore pre-runner thing like you are asking baja shop to do for you.
i have a friend that is trying to sell a complete chassis that is painted and has test miles on it now for under what your budget you said for your thing was... |
Posted: Wed Aug 02, 2006 12:00 am Post subject: |
Just for the sake of clarity my break down of what is involved in a coil-over was for vwthingrcer. I was trying to reiterate to him that a coil-over lift (if you can really call it a “lift”) isn’t a simple bolt on and go operation.
If you have read pervious posts from vwthingrcer you’ll notice he is a bit of a grandiose dreamer (nothing wrong with that, I find myself doing it to) but I am a bit dubious about his ability to make these plans a reality. I am just trying to inject a bit of reality into his grand scheme before his gets involved with something that may or may not be over his head. I have never met the man and have no idea what his fabrication, scrounging, bartering, and or resourcefulness skills are or his financial statue are in regards to these projects he comes up with. So I just play the part of the devils advocate.
Anyway, In regards to what your trying to achieve with your Thing it makes 100% sense. For a light duty car that you just want to go and have fun with your plans sound great. I wish I knew what to tell you about your front end. The ball joint setup is kind of a plague for off-roading. No one offers any kind of improvements that are worth a damn so your stuck with swapping frame heads or going with a tube setup to support a K&L. It’s just a PITA for us.
I still think that a 2.0 shock is a bit small for the weight of a Thing but that’s just my opinion. Just out of curiosity, how much does your Baja weigh? I am predicting my Thing is going to run around 2200-2500lbs. with everything bolted on.
I should also mention my predicted budget is heavily influence by a short time frame (trying to get the hell out of Dodge in the very near future) extensive body work and paint (my car is trashed) and a damn expensive engine and transmission. Those type IV engines are bloody expensive. A Subaru engine is looking better and better everyday. More Hp for a lot less money, you just have to find a home for the radiator.
On second thought maybe I should just get a Jeep and call it a day… _________________ Order of the Voodoo Spoon |
Posted: Wed Aug 02, 2006 9:26 am Post subject: |
suntour wrote: |
If you have read pervious posts from vwthingrcer you’ll notice he is a bit of a grandiose dreamer (nothing wrong with that, I find myself doing it to) but I am a bit dubious about his ability to make these plans a reality. |
Dubious? Some of my favorite vwthngrcer posts:
vwthingrcer wrote: |
ask everyone i think most people aer starting to know me around here for the thing that never works i would jsut get some peice of crap car that runs and drive that around i have 5+ grand in to my car and it dosnt run amn this suck |
Quote: |
im fianl giving up and selling my thing or what ever i jsut have had enough of it ...pissing me off never working right so im giving up on it
i guess im not the machanic i thought i was so im jsut giving up so no more post for me and i dont know what im going to do with the car
if anyone can tell me why i should go ack to working on it tell me |
Quote: |
well you see i know that but it is when like i ask for help from people and they tell me something and like i got a new carb and im running stock dual vance distro i guess this is my problem all the time this guy told me a different timing so i kept on blowing top ends and i get realyl mad about that so the is dents everywhere from peope telling wrong stuff so i have to repair all that but no kidding i have spent over 5000 and my car still dosnt run that is with in the last year so it is kinda frustrating spendign that much jsut on an engine i need a new trans and new body work i dunnp if i should paint it becuase me and my dad do like taking it off road so i dunno but i dunno i need a new door and rear deck lid so ya and rims and tires seats electrical is bad engine is weird i have a lot to do |
Quote: |
it is kinda hard when your 17 and this is your only car my parents wont let my drive there on account i kinda screwed my dads truck up but i know i love the car but it is summer time and i have nothing to do except stay at home becuase of no car so it is kinda of frustrating i have had the car only work like a max of a week in the past 6 mounths but i found out why taht was some guy told me to set my timing to something else that waht is was then
i jsut want a car that runs so i dunno it is hard beign 17 and having no car |
Quote: |
should i jsut get a piece of shit car to get me from point a - b and then jsut set the thin g up beacuse of know that is my daily driver so i dunno |
And some of my favorite responses:
bljones wrote: |
look kid, if you came looking for pity or sympathy, you came to the wrong place. we've all been there, done that, got, bought, sold, rented, stole, fixed, broke, and fixed again the t-shirt. . . . |
radioman wrote: |
I am sorry...I have never been able to follow anything you are typing. I feel like I do when I order ink cartridges for my Dell printer and talk to some guy in India. I'd like to help also, but you have got to learn punctuation and reasonable construction before anyone can figure out your issues. |
Towel Rail wrote: |
Seriously. Try to get a stock setup working. |
Big Luni wrote: |
Good ol' vwthingrcer. Your high school's English Department must have blown their entire budget on red pens! |
kevin11 Samba Member
Joined: March 12, 2004 Posts: 828 Location: Arlington,Texas
Posted: Wed Aug 02, 2006 9:37 pm Post subject: |
Posted: Thu Aug 03, 2006 8:47 am Post subject: |
all i have to say is hmmmmmm.....
and a 2.0 is plenty enough shock for playing, yes your right with a 2.5 would be better for more serious play, but the shock does not carry the car, that is what the coil is for, and they make heavier rate springs for that.
a 2.0 that is over sprung for the car will work less than a 2.5 that is dual rate and undersprung. the size of the shock most importantly for getting rid of heat, the bigger the shock the better it dissapates, and more oil volume it holds which over time equals fade protection.
as far as weight on my race car i couldnt even give you a guess, but i do know my thing gets going A LOT quicker. race car has a built motor with 12.5-1 compression, built tranny with closer ratio gears, and 33" rears. the thing has a stock 1600, stock tranny and 27" rears (bfg all terrains woot woot ) and hits 65 mph in 3rd gear in a hurry.. ok maybe i was kidding myself, but it does get going out of the hole a lot quicker, and stops better to. so i dont know if that helped you at all, but i think my racecar might weigh a bit more than my stock thingster |
Posted: Thu Aug 03, 2006 9:10 am Post subject: |
well my dad said he would pay for all the suspention work on it but i think i might have changed what im doing i want to make it a show type car itis pretty much there jsut do the supention and paint and interior maybe a motor and some nice rims _________________ 1973 vw thing 1600cc engine ONce agian is a live
Posted: Thu Aug 03, 2006 9:22 am Post subject: |
well my dad said he would pay for all the suspention work on it but i think i might have changed what im doing i want to make it a show type car itis pretty much there jsut do the supention and paint and interior maybe a motor and some nice rims |
Nice how you can get these guys all riled up and then turn on a dime. Without so much as a thanks anyway, fellas.
Show car, now. Pretty much there. Just needs suspension, paint, interior, motor, rims -- what is it that doesn't need doing that makes it "pretty much there?" |
Posted: Thu Aug 03, 2006 12:04 pm Post subject: |
Captain Spalding wrote: |
LOL, my thoughts exactly.
P.S. there was a great Groucho Marx marathon on TCM yesterday. (but I am sure you already knew that.) _________________ Order of the Voodoo Spoon |
Posted: Fri Aug 04, 2006 11:29 pm Post subject: |
Quote: |
Those type IV engines are bloody expensive |
Dont let anyone fool you, I have 5 of them in my garage, and paid no more than $100 for any of them. A Type 4 with Cali conversion and some used IDFs can be done for a grand easy and half that money is for carbs. I havent found one yet were the bottom end was bad, however I always rebuild them. The heads are usually why vans end up in the junk yard, but good ones can be had pretty cheep if you look around. Carbs are getting expensive but this is true for T1 also.
http://www.aircooledtech.com/type4_upright_conversion/
Heres the manual to get
Next Generation Type IV Upright Conversion Manual, by Joe Cali.
http://www.nextgen-usa.com/
Here is a picture of Joes car.
Mine is in progress and will not look this nice + I am using Megasquirt FI.
I do have both a van and 412 I have rebuilt T4 for it was not much more than a T1. Also not going in my Thing, but I think this would be a great idea. |
