School me on the 1967 one year only stuff
Goto page Previous  1, 2, 3, 4 ... 36, 37, 38  Next
RareAir
RareAir is offline
PostPosted: Fri Aug 18, 2006 6:59 am    Post subject: Reply with quote
aircooled wrote:
They are both real hard to find. However, between the two finding
SB-12's that are in great shape are harder to find.
I've a few mint ones in my stash. And I don't even have a '67. Thanks to Bill May, I've been hoarding nice '67-only parts for about 3 years now.
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
Sent from my iPhone 9S
NRTH60
NRTH60 is offline
PostPosted: Fri Aug 18, 2006 9:56 am    Post subject: 67 TRANSAXLE CHANGE Reply with quote
BELIEVE THAT OUT SIDE DEMENSION WAS SAME AS 66 . CHANGE TO 12VOLT BROUGHT SLITLY BIGGER FLYWHEEL OUTSIDE DIA. , 68 WAS YEAR OF BIG CHANGE TO CV AXLE
12 VOLT FLYWHEEL WILL FIT FINE AFTER COUPLE MINUTS RUNNING TIME . IT WILL CLEARENCE ITSELF. I KNOW NOT CORRECT BUT IT WORK S
aircooled
aircooled is offline
PostPosted: Fri Aug 18, 2006 12:20 pm    Post subject: Reply with quote
Sapphire VIII AM/ 8 Track's in working condition are harder to find than the Sapphire VI's. Not to mention the optional VDO tach.
codycat
codycat is offline
PostPosted: Fri Aug 18, 2006 1:46 pm    Post subject: Reply with quote
what are SB-12's ????
KantDriveFast
KantDriveFast is offline
PostPosted: Fri Aug 18, 2006 2:53 pm    Post subject: Re: 67 TRANSAXLE CHANGE Reply with quote
Allow me to edit:
NRTH60 wrote:
BELIEVE THAT the OUT SIDE DiMENSION WAS SAME AS 66 (although the rear track got wider) . CHANGE TO 12VOLT BROUGHT SLIghTLY BIGGER FLYWHEEL OUTSIDE DIA. , 68 WAS the YEAR OF the BIG CHANGE TO CV joint AXLE (only on auto-stick, all others got it in '69)
12 VOLT FLYWHEEL WILL FIT FINE AFTER a COUPLE MINUTeS RUNNING TIME . IT WILL CLEARaNCE ITSELF. I KNOW its NOT CORRECT, BUT IT WORKS (actually, this is a BAD idea...forget I said it!) Oh, and SORRY for YELLING!
Welcome to The Samba!
House Premium Member
Minutia Militia
House is offline
PostPosted: Fri Aug 18, 2006 4:07 pm    Post subject: Reply with quote
codycat
codycat is offline
PostPosted: Fri Aug 18, 2006 5:08 pm    Post subject: Reply with quote
OH - so if my currect rings do NOT have that imprinted on them - they are not OG?
Hakka
Hakka is offline
PostPosted: Sat Aug 19, 2006 6:57 am    Post subject: Reply with quote
67's are a pain in the ass.... Confused
67 Florida Deluxe Premium Member
Samba Purist
67 Florida Deluxe is offline
PostPosted: Sat Aug 19, 2006 7:15 am    Post subject: Reply with quote
Rather vague generalization
Wanted:
Atlas Motors and Brundage Motors license plate frames.
A few of my toys
KantDriveFast
PostPosted: Sat Aug 19, 2006 9:22 am    Post subject: Reply with quote
Wasn't it just the earlier '67s that had these? Confused
Samba Purist
PostPosted: Sat Aug 19, 2006 9:42 am    Post subject: Reply with quote
Some had them, some didnt. Either is correct (ie "OG"). However, some people want the SBs because they are more rare and exclusive to '67.
Wanted:
A few of my toys
RareAir
RareAir is offline
PostPosted: Sat Aug 19, 2006 2:55 pm    Post subject: Reply with quote
Both the inner & outer headlight rings should have the SB12 designation embossed on them. The inner rings are easier to find since they were used on multiple years following 1967. The outer ring was used during 1967 production only.
The outer ring shown above was on my former '67 convertible. Here's a pic of the inner ring on the same car while I was assembling it a few years ago.
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
Samba Purist
PostPosted: Sat Aug 19, 2006 3:04 pm    Post subject: Reply with quote
Is that a common wood screw I see?? Shame on you
Very Happy
Looks like halogen, too...
Wanted:
A few of my toys
67conv
67conv is offline
PostPosted: Sun Aug 20, 2006 8:26 am    Post subject: Reply with quote
Hello everyone. I'm new here. How about the tunnel mat? and 'vert things......rear-view (inside) mirror, early top w/ chrome strip above rear window, mid year change without strip, deck lid (try to find one of these!), and the most esoteric 67 only thing ever...the convertible's deck lid "rain tray".
RareAir
RareAir is offline
PostPosted: Sun Aug 20, 2006 9:20 am    Post subject: Reply with quote
Since I was building a daily driver resto custom, I choose to install H4s rather the the regular sealed bulbs.
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
RareAir
RareAir is offline
PostPosted: Sun Aug 20, 2006 9:21 am    Post subject: Reply with quote
Duh! Embarassed
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
RareAir
RareAir is offline
PostPosted: Sun Aug 20, 2006 9:23 am    Post subject: Reply with quote
67conv wrote:
Hello everyone. I'm new here. How about the tunnel mat? and 'vert things......rear-view (inside) mirror, early top w/ chrome strip above rear window, mid year change without strip.
The tack strip below the rear window was changed mid year, not the Chrome deco strip. Early cars were stapled below the rear window, later production cars used a curled lip.
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
67conv
67conv is offline
PostPosted: Sun Aug 20, 2006 10:10 am    Post subject: Reply with quote
The tack strip below the rear window was changed mid year, not the Chrome deco strip. Early cars were stapled below the rear window, later production cars used a curled lip.[/quote]
Correct....but, I was speaking of the tack strip (w/ recess) and chrome deco strip ABOVE the rear window, which was eliminated at the mid year change you mention. The chrome deco strip around base of top / body remained thru '69, I think. Isnt the clear plastic fuse block cover another '67 only item? VW1500 emblem on early '67 deck lids.......
RareAir
RareAir is offline
PostPosted: Sun Aug 20, 2006 11:03 am    Post subject: Reply with quote
The emblem is '67-only. But it was used throughout the entire year, not just on early production cars
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
RareAir
RareAir is offline
PostPosted: Sun Aug 20, 2006 11:07 am    Post subject: Reply with quote
I don't think so. 1967 thru mid 1971 cars all use fusebox cover VW part # 111937555A
1947 Type 11a
1954 Type 117
1956 Type 151
1966 Type 151
1966 Type 251
Page 3 of 38
