Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Wed Aug 09, 2006 8:11 pm Post subject: Carpet Kit |
I'm contemplating putting carpet in the rear storage area. JBugs has a fairly reasonable kit available:
http://www.jbugs.com/store/merchant.mvc?Screen=PRO..._Code=1079
But I have a few concerns... How do you secure them in place so they won't blow out when you have the top down. And once they are secured, what do you do if they get wet? I'd hate to trap moisture underneath them. |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Wed Aug 09, 2006 8:16 pm Post subject: |
I just bought some indoor/outdoor carpet for a couple of dollars a yard at Lowes. It looks just like the original carpet in our 67 Volvo we are restoring.
You could carpet a piece of plywood and use snaps to secure it. Or use Velcro. |
kubelmann Samba Member
Posted: Thu Aug 10, 2006 3:43 am Post subject: |
The TMI carpet kit for the Thing (that is the most commonly available) is designed to be glued in place using contact cement. I used indoor outdoor very high quality carpeting ( I spared no expense grabbing a remnant left from recarpeting a school library). I cut it to fit the rear area and secured it in place using ss screws with nice collars ( near exact to the screws and flared washers that hold the footwell covers in pace. The screws went into the rubber plugs in the rear of the body so no holdes needed to be drilled. The PO had contact cemented in a carpet kit. It was a bit of a mess to remove. The glued in place carpeting resulted in some minor rust damage that has now been repaired. I do not suggest glued in carpeting in a Thing. Anything that traps moisture will result in eventual rust damage. I cut some thick rubber mats that I have not used because I fear moisture will be trapped under the mats... I am considering making a 1/2" round punch to make holes in my rubber mats to allow moisture to escape. The plan would be to make the thick sponge rubber mats look somewhat like the original swiss cheese mats... |
Posted: Thu Aug 10, 2006 3:49 am Post subject: |
I jsut saw the coolest set of duck boards made from welcome mats made of wooded blocks and rubber blocks. The mat was a closeout item from Target. It was taken apart and put back together to to fit the floors.
Posted: Thu Aug 10, 2006 4:53 am Post subject: |
I like both of your ideas! My next stop will be Lowes... |
