Adventurewagen Samba Member
Posted: Thu Aug 10, 2006 10:42 am Post subject: Accelerator Pedal Assembly Diagram |
My gas pedal broke off the floor pan a millenia ago and the PO used a door hinge bolted to the floor and pedal to "fix" the problem.
So I got this kit in from BusDepot
Its missing one of the c-clamp things, but I can deal.
The only problem is I have no stinking idea how to assemble the thing as I never had a legit pedal and underneath assembly in the first place. I've looked in Bentely, Muir, Haynes and two other odd ball books I have but could't find a pedal blow-out image in ANY of them. Some pieces I know go certain places others I don't.
Anyone have a blow-out in some other book of the pedal or maybe could take a picture of theirs? The L shaped piece has to somehow attach to the rod that attaches to the pedal, the accelerator cable AND to the underside body mount, but I seem to only have rods though and at least 3 of 4 hose I probably need to use. _________________ 63 Gulf Blue Notch
71 Sierra Yellow Adventurewagen
86 Syncro |
germansupplyscott Samba Member
Posted: Thu Aug 10, 2006 11:09 am Post subject: |
this is for 68-70, not sure if 71 is the same. if your hinge is missing you need that also. kit photo shows no hinge. _________________ scott lyons
http://www.germansupply.com
VW Bus-Centric Online Parts Source |
Posted: Thu Aug 10, 2006 11:16 am Post subject: |
The image helps alot, it makes more sense now.
I can see how #6 fits one side of the L (#9) and the cable is supposed to have its own rod to go through #9.
In my case the L doesn't have the other rod directly attached to it, but comes with one that probably some how fits into the underside plate with the spring and another washer or something.
I got a new hinge from Dansvans (thanks by the way again) and it fits perfectly.
You have any idea on the spring return of the peda? I don't have anything that looks like ti would cause the pedal to return to its top position? _________________ 63 Gulf Blue Notch
86 Syncro |
magnus0328 Samba Member
Joined: April 20, 2006 Posts: 1117 Location: Kissimmee, FL
Posted: Fri Oct 02, 2009 12:53 pm Post subject: |
| Adventurewagen wrote: |
You have any idea on the spring return of the peda? I don't have anything that looks like ti would cause the pedal to return to its top position? |
I have the same question... What do you use for the pedal return spring? |
Daverham Samba Member
Joined: August 27, 2009 Posts: 1214 Location: Seattle
Posted: Fri Oct 02, 2009 1:00 pm Post subject: |
I had a door-hinge-welded-in bug once too! Good times... _________________ 78 Kombi, 65 Bug, 69 Baja Bug, 63 Camper Van, 66 Bug, 72 Bug, 60 Ghia |
Posted: Fri Oct 02, 2009 2:03 pm Post subject: |
| I bought bought the kit when my hinge failed thinking that the kit would have everything I needed. Pretty much a waste of dough. I ended up using a 3" butt hinge, I think it was solid brass with a stainless pin but am not sure anymore. I cut the one leaf of the hinge down so that it fit inside the back of the original pedal and bolted the pedal to it. It took a little work to put every thing together in a way that would not cause clearance problems. I suspect my repair will last as long as any part on the car. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 1539 Location: Kaneohe
Posted: Fri Oct 02, 2009 9:57 pm Post subject: |
the return spring is on the carburetor
tp |
dirigible Samba Member
Joined: September 28, 2009 Posts: 181 Location: Kitchener, Ontario, Canada
Posted: Thu Oct 08, 2009 5:47 pm Post subject: |
Having similar issues. Hinge is rusted out (both pedal and floor sides), and missing the topside spring, boot, and a few other things.
Just took it out of storage and found this mess... the strange thing is I drove it into the storage container. Don't know how I could have driven it without a working accelerator pedal!
Hm. Maybe I was less fussy 6 years ago.
Anyway--can't find the kit on the Bus Depot site. Found similar one on cip1.ca, but looking to compare prices. Can you post a link? |
pjalau Samba Member
Posted: Thu Oct 08, 2009 6:54 pm Post subject: |
And since we are on this topic - does anyone carry part number 4? The accelerator stop pedal? I have my old one, but one of the tabs broke off, and I'd like to replace it.
Scott?
Anyone? Beuller? Beuller?
-P _________________ elementhis.blogspot.com |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 23863 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Thu Oct 08, 2009 7:02 pm Post subject: |
The stop is NLA unless you score at the wrecker or in the classifieds. It's really not neccessary unless you drive while wearing high heels alot, reset the throttle cable length at the carb or throttle body to leave 1MM clearance from the WOT stop on the carb when the pedal is mashed to the floor. Most ankles in flattish shoes have enough range of motion to handle that.  _________________ Rust NEVER sleeps and stock never goes out of style.
Wanted, 68-73 westy OG plaid curtains, singles OK. |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 877 Location: Edmond Oklahoma
Posted: Thu Oct 08, 2009 7:06 pm Post subject: |
I have the #7 rubber accelerator gasket in my stash of parts. Does that part also fit on a '76 accelerator assembly? I don't have one on my bus and if it would help keep any cold winter air out, I would like to install it.
Any thoughts? _________________ James
'76 Deluxe Sage Green Westy 2.0L Fuel Injected with '78 ECU and AFM, ACN SVDA Distributor, Hydraulic Lifters (boo hiss), 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated.
First VW engine I've ever built and it's still running strong. 60,000 plus miles and counting. Built in 2004.
[email protected] |
Posted: Thu Oct 08, 2009 7:09 pm Post subject: |
AFAIK that fits all years, why not try it? _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Thu Oct 08, 2009 7:21 pm Post subject: |
| busdaddy wrote: | | AFAIK that fits all years, why not try it? |
well, I thought someone might suggest that. I probably need to clean out my pedal assembly anyways. I just wanted to ask before I tore something apart for no real good reason. My time right now is very limited. _________________ James
[email protected] |
SGKent Samba Member
Joined: October 30, 2007 Posts: 17524 Location: State Capitol CA (Sacramento)
Busdepot Samba Member
Posted: Fri Oct 09, 2009 5:20 am Post subject: |
FYI, from any Bus Depot product lpage, you can widen the displayed selection by clicking on a product category at the bottom of the page. Using the above page as an example, if you looked below "Application Details" and then clicked on words "accelerator pedal" at the end of the "72-79 Bus" line, it would show you more parts specifically related to your 72-79 Accelerator pedal. Or, if instead you clicked on the less specific "Pedal Controls, Cables & Parts," the listing would expand to also include (among other things) accelerator and clutch cables. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3307 Location: Australia
Posted: Fri Oct 09, 2009 1:14 pm Post subject: |
| What about #2? The spring clippy thing? WHere can I get that or a good substitute? I'm sick of the accelerator pedal falling off! |
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1279 Location: Dartmouth, Nova Scotia
Posted: Fri Oct 09, 2009 2:27 pm Post subject: |
Just follow the instructions in the post above yours, the one from "Busdepot", where he directs you to a link to the "Busdepot" website, where you can find the part you seek. _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, Pertronix, MSD 6
| Meyer wrote: | | Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
Harveybacon Samba Member
Joined: April 10, 2011 Posts: 136 Location: Gainesville, FL
Posted: Thu Jul 21, 2011 8:43 am Post subject: assembly pics |
I had to make my own hinge from metal framing straps I got at Home Depot to replace my broken "home-made" one. So I found the part for my 71 on BusDepot. What I need is a pic of where the NEW hinge should screw in (I have to drill holes). So if you guys got yours in and completed, I would really love to see pics! Thanks. I will post pics of what I have done so far and after pics once I get it in. Thank so much!
p.s. I will probably have to get the parts that go under floor board too, but would like to know where to attach this hinge first. _________________ email: [email protected]
Facebook: http://www.facebook.com/groups/GainesvilleVDubClub
website: http://solemndesigns.com/GainesvilleVDub/?p=1
1971 Campmobile
M-Plate: http://www.vw-mplate.com/mplate-6571.htm |
srfndoc Samba Member
Posted: Thu Jul 21, 2011 11:06 am Post subject: |
These photos from my bus may help for how everything connects underneath:
 _________________ 67 SO-42
RPM=(MPH*336* (R&P*4th*1.39))/Tire Diameter in inches |
