honky Samba Member
Joined: August 10, 2006 Posts: 149 Location: Connecticut, USA
Posted: Fri Aug 11, 2006 6:01 pm Post subject: Thing Shimmy |
just bought a 74. It has 55,000 miles on it (I know the car) It has been sitting for about 5 years.
It has a shimmy that shows when you hit bumps. I have the gas tank out .
I dont feel any play in the tie rods. It had a click in the steering box which went away when I adjusted out the excessive play. Is there anyway to test the tie rods to see if that is the problem. Any other suggestions ? |
CARMENMC Samba Member
honky Samba Member
Posted: Sat Aug 12, 2006 7:30 am Post subject: Thing Shimmy |
Sorry I forgot to mention I have a new damper on it. I can feel the shimmy with the car on stands either pushing the tire top to bottom or side to side but i don't see any play in the tie rod ends or ball joints. The outer tie rod end pass side swivels pretty freely when i grab it should this normally be very tight ? |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Sat Aug 12, 2006 8:38 am Post subject: |
sounds like wheel bearings. tighten up the spindle nuts a little and see if that reduces the wheel movement when it is on the jack stands. If so, then a) the nuts were too loose, or b) the bearings are shot. in any event, just for peace of mind, pull the drums and lube the spindles and repack the bearings. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
honky Samba Member
Posted: Thu Aug 31, 2006 2:47 pm Post subject: shimmy |
Well I got the car back together. wheel bearings ok, Tires balanced and rotated front to back, no noticable play in the ball joints or tie rods.Adjusted steering wheel play to one inch. I do notice that the steering wheel has play up and down, the whole coluum does not move. I also notice there is a clicking sound that seems to come from the steering box when you turn the steering wheel That was there before I adjusted the worm play. this has me perplexed. still shimmys over bumps. any ideas out there ? |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Thu Aug 31, 2006 3:01 pm Post subject: |
Could be the tires, how old are they? Old tires can look great but give problems. |
74 Cosa Samba Member
Joined: June 06, 2006 Posts: 535 Location: The Midwest
Posted: Thu Aug 31, 2006 5:05 pm Post subject: Shimmy |
Also check the steering coupler. It could be broke or very worn. |
WD-40 Samba Member
Posted: Thu Aug 31, 2006 5:29 pm Post subject: |
Your steering wheel movement could be the nut that holds the wheel to the steering shaft. Pull the horn button / pad and check that out.
I think we need a better explaination of your shimmy.... What is it that you are feeling over bumps that you also feel with the car up on stands??
- David |
honky Samba Member
Posted: Thu Aug 31, 2006 6:26 pm Post subject: bump d bump |
over bumps I gets a shimmy ( steering wheel shudduring back and forth. On jacks all I get is at 3 and 9 oclock grabbing the tire a slight play and a clicking noise that seems to come from the steering box. I cannot feel any play at the tie rod ends or see any at the ball joints. steering damper is new and feels good ( I took it off ) to see. |
WD-40 Samba Member
Posted: Thu Aug 31, 2006 7:58 pm Post subject: |
Ok. Next questions:
Are the wheels stock? Have you checked the toe?
- David |
honky Samba Member
Posted: Thu Aug 31, 2006 8:06 pm Post subject: shimmy |
stock wheels 195x14 M&S no I have not checked the toe in. That might cause a shimmy ? |
WD-40 Samba Member
Posted: Fri Sep 01, 2006 6:32 am Post subject: |
Well, I'm not sure I would call it "shimmy"... but having too little toe in, or having toe-out, will make it rather "darty". It will not want to drive straight on its own if you let go of the wheel, and won't be as stable when you hit the wind of other cars, etc...
- David |
honky Samba Member
Posted: Fri Sep 01, 2006 7:02 am Post subject: shimmy |
No it drives straight just gets the shudder a little and then much more over bumps. I hate to just start replacing parts. Been there done that. Would be nice to figure out what is wrong. My suspician is it might be the steering box since i am getting a click from that area when i turn the wheel back and forth also there is play in the column with whatever goes down through the tube. The donut seems Ok. |
honky Samba Member
Posted: Fri Sep 01, 2006 8:06 am Post subject: Shimmy |
Well maybe this is it. the steering column is loose in the column tube. I dont think it is at the donut. My bentley manual is not clear on what holds the tube inplace centered at the steering wheel end. The big nut is tight . Would seem like there is a bearing or something that would do that. The play at the wheel is top to bottom and less from side to side. I can put a video up on a site if that would help |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Fri Sep 01, 2006 9:13 am Post subject: |
Check out some of the images from someone with similar problems. http://www.thesamba.com/vw/forum/album_search.php?search_author=asagodowns Maybe you can find some enlightenment there.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Sat Sep 02, 2006 11:23 am Post subject: |
Think it could be a loose grub screw somewhere? |
honky Samba Member
Posted: Sat Sep 02, 2006 11:25 am Post subject: Shimmy shimmy coco pop |
Thanks for the replies. I guess the question is now do I replace the bearing and add the plastic shim gismo. Should have time in a couple of days to take it apart and see what gives.... I will take some pics and try to document it. Now if I can just get rid of that hesitation when I shift.
I swear this is the last old VW I will resurect after it has been sitting in a barn for 7 years. Famous last words. |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Mon Sep 04, 2006 6:46 pm Post subject: |
This is a very common problem, most of the time it's the bearing. All oringinal bearings came with the plastic sleeve. The last time I priced a new bearing it was 45 bucks! The new bearing does not use the plastic sleeve. The same set up is used on a bug. They can be kind of a pain to replace because you have to pull the wiper and turn signal switches. There is also a black sleeve that is just in front of the bearing on the shaft that you have to pry up and off. If you can't find one, let me know, I may have a good used one in the garage. |
honky Samba Member
Posted: Tue Sep 05, 2006 6:21 am Post subject: Shimmy |
I am looking into finding the plastic spacer part. Others who have had the same problem have been able to fix it by just replacing it. My guess is the bearing is not bad. I will see when i get it apart. Air Cooled.net says to replace the bearing but i don't know yet if that includes the spacer. If it does not it probably will not fix the problem. |
