How to Lower / Raise Front and Rear Suspension
Goto page Previous  1, 2, 3, 4  Next
WhitewallsJohnson
WhitewallsJohnson is offline
PostPosted: Sat Mar 17, 2007 7:00 pm    Post subject: Reply with quote
Bobnotch wrote:
ArkansasChad wrote:
If you dont plan on adjusting the inner splines, do you have to unbolt that end of the torsion bar?
In other words, can i adjust the outer splines only with unbolting the inner torsion bar bolt?
If you're wanting to do your adjusting on the outer splines only, then no, you don't have to remove the bolt or the torsion bar from the opposite end that you're lowering on. In other words, just remove the lower torsion arm from the outside end of the bar, and rotate it up to lower it.
Some of us have a hard time getting them to seperate (due to rust), so doing the inner bar end is another option. In my son's case, his car had been lowered some before he got it, and it was uneven. He had to work both ends of the 2 bars in order to get it even, and lowered. Shocked This is where a protractor comes in handy (to be able to check both sides, and make sure they're set the same).
Thanks BobNotch
AKA: Arkansas Chad
Show your love for the Land of Kong:
http://www.thesamba.com/vw/forum/viewtopic.php?t=254661&highlight=
Kermit, the highroof westy:
http://www.thesamba.com/vw/forum/viewtopic.php?t=318687&highlight=
NEGATIVECAMBER
NEGATIVECAMBER is offline
PostPosted: Sat Mar 29, 2008 2:55 pm    Post subject: Reply with quote
Just wanted to say thanks for this post! I lowered my square this weekend and it worked out perfectly.
I'll post pics later.
'67 squareback
WhitewallsJohnson
PostPosted: Sat Mar 29, 2008 6:45 pm    Post subject: Reply with quote
Lets see some pics!
AKA: Arkansas Chad
myvento
myvento is offline
PostPosted: Sat Apr 12, 2008 3:32 pm    Post subject: Reply with quote
how low is it gonna be? pics???
"Who you choose to be around you lets you know who your are." Sung Kang as "Han" in Tokyo Drift
Cultwagen
help spread VW love register here and see if we cant get on the show!
Stacey Davids GEARZ
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
jim altemus
jim altemus is offline
PostPosted: Wed Apr 16, 2008 8:08 am    Post subject: Reply with quote
The front on my '68 Fastback is down a notch or two (I did it years ago so I don't remember which) so I'm going to tackle the rear this weekend. Can anyone estimate how much drop I would get for each outer notch versus inner notch on the rear? The guy I bought the car from is warning me not to drop it by the outer splines.
- Jim
myvento
myvento is offline
PostPosted: Wed Apr 16, 2008 8:34 am    Post subject: Reply with quote
i saw a chart somewhere that had the drgres per spline... anyone?
Cultwagen
Stacey Davids GEARZ
RafCarre12
RafCarre12 is offline
PostPosted: Wed Apr 16, 2008 10:06 am    Post subject: Reply with quote
Type 3 Fasty
jim altemus
PostPosted: Wed Apr 16, 2008 10:13 am    Post subject: Reply with quote
So for a smaller (lesser) drop, I should work with the outer splines? Sounds good but also opposite what my buddy was telling me.
- Jim
myvento
myvento is offline
PostPosted: Wed Apr 16, 2008 10:42 am    Post subject: Reply with quote
thats it thanx raf
Cultwagen
Stacey Davids GEARZ
KTPhil
KTPhil is offline
PostPosted: Wed Apr 16, 2008 10:50 am    Post subject: Reply with quote
The difference between inner and outer is less than 1/4 inch.
RafCarre12
PostPosted: Wed Apr 16, 2008 10:52 am    Post subject: Reply with quote
KTPhil wrote:
The difference between inner and outer is less tha 1/4 inch.
...yeah, 1/3" like the pictures say up there ^^^
Type 3 Fasty
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Apr 16, 2008 12:06 pm    Post subject: Reply with quote
Raf, better read your chart more carefully! Jim & Phil are talking about the difference between moving an inner OR an outer. A tuning move refers to moving an inner AND an outer for a small adjustment.
RafCarre12
PostPosted: Wed Apr 16, 2008 12:19 pm    Post subject: Reply with quote
yes
Type 3 Fasty
Bobnotch
Bobnotch is offline
PostPosted: Wed Apr 16, 2008 5:45 pm    Post subject: Reply with quote
- Jim
Part of how much it'll drop depends on how much the torsion bars are sagging.
On my 71 Notch, the left side was sagging almost 1.25 inches lower than the right side. When I dropped the rear, I had to do a combo move (inside and outer) to get them even. Then I took the car out and bounced it a few times in the driveway, to help settle it some more, and found the left side was lower than the right again. Rolling Eyes I again got back in there, and did a couple of combo moves, right now it's about 3/8th of an inch higher, hoping it'll settle back down some after I bounce it again (currently I have the engine out, so I can paint the engine bay). I little higher on the left won't bother me as much, due to the car always having a driver going down the road, so my weight should help level it a little more. Wink
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
DUBL-DUBL
DUBL-DUBL is offline
PostPosted: Fri Jun 26, 2009 8:01 pm    Post subject: Reply with quote
Just want to say THANKS a BILLION to Mike TopNotch for your TopNotch Step-by-step lowering instructions!!! Very Happy
Got some ContiPro Contact tires on the front yesterday, and lowered the front today with ease! Could NOT have done it without your pics and detailed instructions, thanks so much and I owe you a beer! Very Happy
Cheers!
Craig
DUBL-DUBL
PostPosted: Sun Jun 28, 2009 8:47 am    Post subject: Reply with quote
I apologize for the double-post......
so is there any way to lower the rear just 1 inch?
Or are the only options 1/3 of an inch with a tuning move, or 2 inches or so with an inner OR outer move?
Thanks in advance!
Craig
Bobnotch
Bobnotch is offline
PostPosted: Sun Jun 28, 2009 9:50 am    Post subject: Reply with quote
Craig, you'll have to do a combo move to get 1" drop. The best thing you can do, is get an angle finder. Then once you've got the spring plate off the stop, take a reading from the angle finder (to use as a baseline, in case you ever need to get back to that point), then do your inner/outer moves. What you're going to want is about 2 to 5 degrees (if I remember correctly) drop from your original reading for approximately 1" drop in the rear. It might take a few tries to get this, but once you figure out how many splines in each direction you need on one side, then you can do the opposite for the other side. You'll still move the inner or outer splines the same amout, but you're working on the opposite side of the car. I hope this helps.
kyle242gt
kyle242gt is offline
PostPosted: Sun Jun 28, 2009 9:54 am    Post subject: Reply with quote
Just did this myself - the rear pretty well follows the beetle chart. 4* got me about one inch, which was 5 inners up and 5 outers down.
You will almost certainly have to adjust multiple times, even if you have an angle finder and a perfectly level floor. The torsion bars seem to react differently side-to-side.
So, start with a baseline (+5/-5) put it back together, road test it, then remeasure. Chances are you'll need to tweak one side a bit more.
It gets really really easy after you've done it a few times.
1967 Type 3 Fastback, gathering parts for resto mod - "Stay on Target!"
gone but not forgotten:
1964 Type 1, sunroof, 1600sp, 4" narrow, 2.5" trans raise, pan smacker
1972 Type 3 Squareback - never did much to it
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Jun 28, 2009 10:00 am    Post subject: Reply with quote
This is the actual factory gage.
You used the sill or the tunnel of the car to zero the gage, and then it did not matter how the car was sitting.
Gary: OK. Ima poop.
W1K1
W1K1 is offline
PostPosted: Sun Jun 28, 2009 11:31 am    Post subject: Reply with quote
That's the one I use Russ.
A buddy had to fish it out of the dumpster at the VW dealership when they tossed all the aircooled tools out. Rolling Eyes
Sure makes the job easier than feeling around for the next notch
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1961 beetle
1965 squareback 1500E
Page 2 of 4
