VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Oct 08, 2015 9:04 am Post subject: Re: Follow up |
Rob Jenks wrote: |
There is no amp.
There are 4 speakers
I am using points on a VW engine
I am using an alternator
I have, at one time or another, disconnected everything except to remove the belt or replace the distributer. |
Well. . its definitely not the amp
Its not likely the speakers..
speaker circuits.. maybe still a possibility IF they weren't checked..
It could be a bad condenser or coil..
It could be the alternator doing something funky when it spins and generates.
Remove the belt and test.
And then.. if it continues.. replace condenser first.. then coil.
Be sure to look at the points and make sure everything is in good condition.. Hopefully it has some resistor plug wires or resistor plugs so you can rule them out?
The symptom started with a dead radio.. and continues with other replacement radios.. ..so .... Its not likely a radio problem..
Its the car..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Rob Jenks Samba Member
Joined: July 31, 2013 Posts: 10 Location: United States
Posted: Thu Oct 08, 2015 4:44 pm Post subject: Success |
Of all things what we had was a cross feed coming out of the electric fuel pump, which apparently was going bad. In sleuthing this out, I had a spare and took the 10 minutes to swap it out...we've got music.
I have never, ever used a forum and must admit I am very impressed with the community response and appreciate everyones help.
A sincere thanks and does anyone know where I can buy a new Bang Head Here sign? |
Posted: Fri Oct 09, 2015 6:26 am Post subject: |
Electric fuel pump... not fare.. .... you changed the rules...
Told you it was the car...
Usually and often edited |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Oct 09, 2015 8:32 am Post subject: |
Fuel pump?.... That's interesting.... And I was about to tell you to rename your buggy to "Christine"...
Posted: Fri Oct 09, 2015 8:33 am Post subject: Re: Success |
Rob Jenks wrote: |
Welcome to the real world....
