is my engine to low?
bluething
bluething is offline
PostPosted: Thu Aug 24, 2006 10:01 pm    Post subject: is my engine to low? Reply with quote
Hi Guy's!
My mechanic tell's me that my engine is tilting back slightly
he say's that the 2 engine mount fork's are angled downward and need repositioning.
do you think it just look's like that the exhaust is the wrong one and is to near to the ground
also the angle of the car from front to back look's odd?
ive just had the front suspension done do i need to get the back done with it
your help would be appreciated
thanks
mike
[img][/img][img][/img]
[img][/img]
[img][/img]
[img][/img]
kevin11
kevin11 is offline
PostPosted: Thu Aug 24, 2006 10:27 pm    Post subject: Reply with quote
sounds like your mech. is right. get underneath and post pics. of the mounts.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Thu Aug 24, 2006 10:53 pm    Post subject: Reply with quote
Looks like mine, on which the transmission carrier horns are sprung. The rubber engine seal *almost* reaches, but not quite.
I acquired another transmission carrier from teh Samba. I'm going to have a machine shop move the bolt holes slightly lower to raise the engine back up. Might be worth considering for you, too, until you can cut and reweld the transmission carrier horns.
Good luck!
emersonbiggins
emersonbiggins is offline
PostPosted: Fri Aug 25, 2006 7:02 pm    Post subject: Reply with quote
Wow, that is low. Something is going wrong under there. DO you have issues shifting or changing gears?
That top is different also. What's up with the front windows? Do they have a metal frame?
emersonbiggins
PostPosted: Sat Aug 26, 2006 8:02 pm    Post subject: Reply with quote
Does that Thing only have 2 doors?
bluething
PostPosted: Sun Aug 27, 2006 9:36 pm    Post subject: Reply with quote
Good luck!
already going ahead with that option.
emersonbiggins.. yes it has only 2 door's, and yes they do have frame's but i have got rid of them in the last 2 day's ,
thanks
mike
PS: cant seem to post big picture's any clue guy's?
Towel Rail
PostPosted: Sun Aug 27, 2006 9:46 pm    Post subject: Reply with quote
I think you're linking to the thumbnails.
(BTW, you should really put some air hoses to your heater boxes.)
bluething
PostPosted: Sun Aug 27, 2006 9:52 pm    Post subject: Reply with quote
wow! how did you do that?
and thank's for the tip Smile it's in the garage having some work done as i type
mike
Towel Rail
PostPosted: Sun Aug 27, 2006 10:03 pm    Post subject: Reply with quote
mike
I looked at the files in your links, and they had a *.th.jpg at the end. I experimented with removing the .th and viola! Wink)
