wolfblack58 Samba Member
Posted: Sat Aug 26, 2006 4:49 pm Post subject: Installation of an Albert clip mirror in a 59 bug |
I intend to install an Albert clip mirror in my 59 bug. So, I bought in ebay a mirror and a "F" Albert clip (witch is designated for the Volkswagen limousine) from two different sellers.
When I received the two itens, I had some research on Samba foruns and I found some usefull information, in order to attach the clip to the mirror.
However, I still have need of information about:
1- Where/how should I exactly fix the mirror on the door?
2- The clip and the mirror did not possess any gaskets, so there is any possibility of the installation of the mirror cause damage to the door painting?
3- How should I work with those two little internal bolts? There is any necessity of drilling on the door frame?
Can someone give me some help in order to install this mirror?
Kindest regards from Portugal to all Samba community, Paulo. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Aug 26, 2006 5:41 pm Post subject: |
Place a piece of plastic between the drip rail and the pointed set screws. Tighten the set screws against the plastic & it will hold the F-clip into place. Place the mirror unto the F-clip. Screw the the two Chrome screws through the mirror bracket and into the threaded portion of the F-clip. Done. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Sat Aug 26, 2006 5:59 pm Post subject: |
RareAir wrote: |
Place a piece of plastic between the drip rail and the pointed set screws. Tighten the set screws against the plastic & it will hold the F-clip into place. Place the mirror unto the F-clip. Screw the the two Chrome screws through the mirror bracket and into the threaded portion of the F-clip. Done. |
RareAir, thank you very for the information. Where exactly is located the drip rail? I can`t find a photo to have an idea of the place where the mirror is mounted on the door! Best regards, Paulo. |
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Sun Aug 27, 2006 11:12 am Post subject: |
Quote: |
I can`t find a photo to have an idea of the place where the mirror is mounted on the door! |
Its mounted to the drip rail on the edge of the windshield post, not the door itself. |
Posted: Sun Aug 27, 2006 2:44 pm Post subject: |
With the information provided by Rareair and Kantdrivefast I made an attempt to install the mirror on the drip rail near the windscreen post.
However, it became evident that there is no fitting of clip to the drip rail. On the other hand, I took the perception that clip has a shape that permits the fixing to the door frame, where it is mounted the rubber. I had not understood how the fixing of the clip is compatible with the presence of the rubber. Is it possible to obtain some help about this?
Kindest regards to all Samba community, Paulo. |
Posted: Tue Aug 29, 2006 6:31 am Post subject: |
The Albert F-clip took its place at last (I hope) in the door frame.
The final result was
andreou Samba Member
Posted: Sat Mar 24, 2007 6:12 am Post subject: |
Hello Andreou
In my opinion, the Albert "C" clip is to be used on VW cabriolets, as indicated on the respective box. Dont forget that in the cabrio the mirror is mounted on the front quarter glass frame, not on the door frame.
Kindest regards, Paulo |
tomas persson Samba Member
Joined: December 09, 2002 Posts: 220 Location: Sweden
Posted: Mon Jan 26, 2009 11:46 am Post subject: |
I have the original plastic peace that should be used with the mirror clip...I have a whole bunch! |
Posted: Tue Jan 27, 2009 1:29 pm Post subject: |
Here comes photos of the plastic part...nothing fancy at all.
[/img] |
EMPIFLAKE Samba Member
Posted: Tue Jan 26, 2010 7:38 pm Post subject: |
Hello I just bought this clip albert mirror! I made a judgement call that the clip would work on a vert! even though its a d clip it still has the same look as all the other c clips Ive seen ! Please give me your thoughts!
tazm Samba Member
Posted: Sat Jan 30, 2010 6:36 am Post subject: |
here is my mirror with Clip for conv !
I'm looking for a NOS passenger side albert clip mirror ( only the mirror I have the clip)
Thanks,
Guido |
CUBA Samba Member
Posted: Sun Apr 20, 2014 7:11 pm Post subject: |
Seriously...? $135.00 for an Albert F Clip
Any other options? |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed May 13, 2015 5:02 pm Post subject: |
What years were this style of Albert Mirror typically installed on? Splits? Ovals? Later?
I have a pair I am contemplating installing on a split, just to have a bit more safety.
Thoughts?
El Guero Samba Member
Joined: January 03, 2004 Posts: 1197 Location: I.E. Y-QUE
Posted: Sat Oct 07, 2017 3:26 pm Post subject: Re: Installation of an Albert clip mirror in a 59 bug |
You ever install those mirrors? Looking for some _________________ Praise the Lowered... |
Second Air Force Samba Member
Posted: Sun Aug 26, 2018 5:34 am Post subject: Re: Installation of an Albert clip mirror in a 59 bug |
I'm trying to decide what to do about outside mirrors on Ingrid, also.... A previous owner, probably when the car was still in Germany, added door mirrors but cut these ragged slots in the door lip on both doors. The slots are approximately two inches in length.
My question is: What kind of clip (or brand of mirror) would have been used that the slots would have been needed, and has anyone else ever run into this kind of hackery on their sedans?
My instinct is to repair and fill the slots and then get Albert "F" clips and mirrors to do it right, but if there is a mirror out there that used the slots in the door I may correct the holes and use them. _________________ 1956 Standard Sedan |
