VW Bug Stereo Systems - Rear Speaker Box Ideas.
Page: 1, 2, 3  Next
brent85_98
brent85_98 is offline
PostPosted: Tue Aug 29, 2006 4:37 pm    Post subject: VW Bug Stereo Systems - Rear Speaker Box Ideas. Reply with quote
Samba Folks!
Hey I'm onto my next vw bug project. I NEED A STEREO! I am working on how to install a stereo in my classic 67. I don't want to open the orginal stereo hole, I want to put a block-out plate there. (Does anybody have one around) I am working on installing a cd-player into the glove box and wanted some ideas on that. Has anybody done that and do you have any pictures of yours? Also, has anyone designed a custom speaker box for the rear and have any blueprints, if not I am sure I can design my own. I just wanted to what you guys had. Post some pictures if you got some...
Thanks,
Brent
67 Beetle
KillerTux
KillerTux is offline
PostPosted: Tue Aug 29, 2006 5:26 pm    Post subject: Reply with quote
They sell gloveboxes that are meant to have radios in them but they are crappy. I just grabbed a plastic glovebox and drilled two holes on top and used ties to mount radio. Then I cut out a little 4 by 4 cm hole for the wires coming out of the glove box. I have the later style glovebox but it should work all the same.
I forgot what size I cut for my little speaker box in the back but just measure it out and use plywood..I got good results.
1964 Beetle Convertible
ESQ747
ESQ747 is offline
PostPosted: Tue Aug 29, 2006 6:59 pm    Post subject: Reply with quote
It's not a rear box design, but worth noting:
http://www.hoodride.com/phpBB2/viewtopic.php?t=7752
sloink
sloink is offline
PostPosted: Wed Aug 30, 2006 5:50 am    Post subject: Reply with quote
I used a piece of 2x4 to make a mount in my glove box. Glove box is now unusable. and had to cut the back of the box to give some extra room for the radio to sit comfortably. For the speaker box I made a shelf out of plywood and covered with upholtry carpet. Looks great, sounds better, and gives lots of extra bass with just 2 6x9s. My brother actually asked if I had a sub installed.
I used an old cardboard box to make a template of my parcel tray behind the back seat and just cut the plywood as appropriate.
I will post some pix in a bit
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
rusty57
rusty57 is offline
PostPosted: Wed Aug 30, 2006 6:38 am    Post subject: Reply with quote
I did this to one of my cars once, sounded really good and no one noticed.
This was another similar take on my other car.
I just put the cd player in the glove box and opened it when i would use the stereo and locked it when i left the car. Out of site out of mind.
I'm gonna do something very similar to my 62 here shortly. I'll post what i do then.
67 Ghia coupe, Retired military.
www.TagDefender.com
luckystiff
luckystiff is offline
PostPosted: Wed Aug 30, 2006 7:57 am    Post subject: Reply with quote
this is just a pic i found somewhere but i've built several like this set up over the years. 1 10"(or 12" if you want) sub and you can either do 6x9s or 6.5 or i have done a full component system in the shelf(6.5, 4, and 1" tweeter). honestly since it's all behind you i don't think the component sytem is worth the extra effort sound wise. i good set of 6x9s or good full range 6.5s will sound great. run the whole deal off of a smallish 4 channel amp with the rear channels bridged to run the sub. i worked for HiFonics for a while and can tell you most people mistakes are trying to put to many speakers in a car and trying to over power what they do have. you can have a small system that will rip shit up and be really stealth to boot. i bought a brand new civic when i worked for them and we built it at the office with 1 12"(later switched to a 10") in a custom fabbed enclosure in the spare tire well, 8" mid base in modified stock door location(that was tricky) and 1" tweeters in the stock upper door location. all ran off of 1 100 watt amp dropping in a low ohm mode and running much more power.other than the nice Alpine in the dash the whole thing looked stock. even in the trunk as the woofer, amp and spare were all under a false floor. that car sounded like a concert hall on wheels and won tons of sound quality and spl contest.
basiclly saying just remember lots of times less is more. something like the pic below will give you a nice system and if done right can be completely hidden. and for the head unit in the glove box. i've never used one of those gloveboxes that are made for it. i have made one long long ago similar for someone elses car. some fiberglass and a little time can get you one that is very nice. i've heard good and bad about the ones now on the market. i'll be making mine...ken....
TedzBug
TedzBug is offline
PostPosted: Wed Aug 30, 2006 8:17 am    Post subject: Reply with quote
Here is my take..... I had two 10" sony xplod in a shelf in the back (no enclosure) It sounded ok, bass was not bad, but a little "droning" and muddy.
So i found some plans, and modified them. Now i have a double bandpass enclosure with the subs firing away from each other in its own separate enclusure........ OMG, i never imagined how much bass could come from 2 med/small subs. I plan so paint the box, and make a shelf/storage area where the rear seat used to be....
'75 Super Beetle
http://www.pbase.com/tedzillich/1975_super_beetle
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Wed Aug 30, 2006 9:15 am    Post subject: Reply with quote
Have any of you guys considered the search button? There are all kinds of non-hackjob recommendations in existing threads, and the work doesn't look like it was done with a high school kid with a toy tool set.
brent85_98
PostPosted: Wed Aug 30, 2006 9:52 am    Post subject: Reply with quote
Thanks guys for all the ideas. I really liked the luggage roof-rack stereo idea, very creative! So far I have made a wooden plate for my glove box that will hold my cd-player. Now I have to get it to fit right and add some fill to the corners then cut out the slot for the player. It also looks like I will have to cut part of the back of the glove box to fit properly. My next idea is to take a flat board and place it in the rear and cut out some 6x9 holes. I still don't know about front speakers but pondering some ideas. I will post some pics on the work soon.
~ 67 vw bug ~
elvisjer
elvisjer is offline
PostPosted: Wed Aug 30, 2006 11:38 am    Post subject: Reply with quote
I dont like the idea of cutting the glovebox...thats something very hard to un-do in the long run if you ever have to sell it for huge medial bills or something. I have a sponsored and magazine featured PT cruiser, and have MUCH experience with car audio...finally something on this fourm i know about Wink If your going to make that rear speaker holder...it would very much improve the sound quality of the speakers if you sealed them--build a box or similiar device aroung the bottom of the speaker. Sealing in the components makes them sound immensly better. If you're on a budget, alpine type R or type S are great for the price, and thier subs are great too. If you have any questions shoot me a message, id love to help. Ive got $4k worth of stereo (sponsored, i didnt spend $1) i my cruiser.
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Classifieds Feedback
xzener
xzener is offline
PostPosted: Wed Aug 30, 2006 1:51 pm    Post subject: Reply with quote
Here is my creation.........
Designed for 2 JL Audio 10w0 subs. These are just for looks. Wink
My 70 Beetle was totaled. Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
brent85_98
PostPosted: Thu Aug 31, 2006 2:53 am    Post subject: Adding some pictures Reply with quote
Well at it all day and night trying to install my cd player. and I have got some good news. It's in the glove box and looks better than I expected. Tomorrow I will wire it up and hopefully turn it on. Put some pictures up so you can see where I am at.
http://www.thesamba.com/vw/forum/album_search.php?search_author=brent85_98
xzener
xzener is offline
PostPosted: Thu Aug 31, 2006 6:53 am    Post subject: Reply with quote
Looking good Brent85_98. You putting a sub under that speaker tray in the back?
DFDubVDub
DFDubVDub is offline
PostPosted: Sat Sep 02, 2006 10:10 am    Post subject: Reply with quote
I agree! How exactly are these installs above better than the actual hidden stereo glove box? Just curious...
xzener
xzener is offline
PostPosted: Sat Sep 02, 2006 10:20 am    Post subject: Reply with quote
Nice install DFDubVDub, I like the in glove box setup. I prefer having the stereo "right there" as apossed to having to open the glove box. I'm getting my Pioneer DEH P7600MP today. I'll post my installation pics.
krlang
krlang is offline
PostPosted: Sat Sep 02, 2006 2:41 pm    Post subject: Reply with quote
That ty-wrap looks all too familiar.
I have one of those gloveboxes, one of these days I will buy a stereo shallow enough to not offset the wiring cover.
I have a box in the back of my car that has 2/10's and takes up all of the baggage area. Good thing I never drive my car.
67 Type I in Harley turquoise(1914CC)
"Then I landed on the water, Just about my favorite thrill....." -JB
g352nv
g352nv is offline
PostPosted: Sat Sep 02, 2006 9:53 pm    Post subject: Reply with quote
Ill post pics of our setup soon. I put the deck in the glove box with a custom panel. I also made front fiberglass pods. A member on this site gave me a great idea for a rear box that Ill be working on soon.
DFDubVDub
PostPosted: Sat Sep 02, 2006 11:53 pm    Post subject: Reply with quote
Right on! I definately want to see your custom work! I just bought the fiberglass kick panels from VW Innovations for now, until I learn how to do fiberglass work, and can afford to upgrade! I had a hell of a time getting them to fit right, but if you look at the pics on my profile, you can see the final results!
xzener
xzener is offline
PostPosted: Sun Sep 03, 2006 10:39 pm    Post subject: Reply with quote
Got my Pioneer DEH P7600MP installed!! Here are a couple pics. I'm excited as to how well it came out. Sure am glad I found a radio trim here in the classifieds.
[/img]
bugninva
bugninva is offline
PostPosted: Mon Sep 04, 2006 6:50 am    Post subject: Reply with quote
xzener wrote:
dude, your radio can't spell... Laughing
Page: 1, 2, 3  Next
