Timing marks
Beryl Green
Beryl Green is offline
PostPosted: Sun Jan 26, 2014 2:43 pm    Post subject: Timing marks Reply with quote
Hi, I have 2 marks on my pulley one at 7.5 the other would be 10 BTDC. I have tried both and had poor acceration feeling it was too retarded. Last night I kept working it mm by mm till the performance improved. it ended up being set at around 6 degrees BTDC and goes much better. Why would this be the case? I used a static timing light, 61 bug 1200.
jwp67
jwp67 is offline
PostPosted: Sun Jan 26, 2014 2:58 pm    Post subject: Reply with quote
What distributor are you using? Different distributors - different timing. Is your dwell correct?
http://www.oldvolkshome.com/ignition.htm
Aussiebug
Aussiebug is offline
PostPosted: Sun Jan 26, 2014 3:23 pm    Post subject: Re: Timing marks Reply with quote
Only if they are very close together. There are at least 4 different pulley mark arrangements on bug engines. Some have only one notch which can be 10BTDC or 5ATDC!!!
As noted above, it depends on your distributor. If you use a 009 (centrifugal - no vacuum), these vary a lot and should be set 30-32 degrees max advance at 3000+rpm and let the idle fall where it may - usually somewhere between 5 and 10BTDC.
If you have a vacuum distributor, it depends on which one you have - if it's designed for the 1200 engine then it should be set at 10BTDC but the 1300/1500/1600 engines used 7.5BTDC with their stock distributors. It's unlikely you would find a TDC distributor here in Australia, but it's just possible I guess (lots of them on the USA).
So, as asked above, WHAT distributor are you using?
And if you have a vacuum distributor, it will also depend on what carb you are using with what distributor - some carbs have a low vacuum signal and dont work well with the vacuum distributors.
So, what carb are you using too?
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com
Beryl Green
PostPosted: Sun Jan 26, 2014 5:08 pm    Post subject: Reply with quote
Thanks, distributor is vacc advance only (has the short body) carb is PICT 28-1
bluebus86
Banned
bluebus86 is offline
PostPosted: Sun Jan 26, 2014 5:15 pm    Post subject: Reply with quote
beware of setting the timing to get max power, if you search for max power you may d\find you have entered the danger zone for detonation.
I can tune any VW to get more power by advancing the timing, However eventually you have a hand grenade motor, lots of power, low life.
use care when selecting the advance
djshutup
djshutup is offline
PostPosted: Sun Jan 26, 2014 5:16 pm    Post subject: Reply with quote
Since your pulley sounds like mine (only 2 notches real close) I am curious if you marked TDC on your pulley with one of the templates available for doing valve adjustments
1967 Volkswagen Bug (stock). 1980 Yamaha XS400 Special II (stock). Ya I like stock classics
Beryl Green
PostPosted: Sun Jan 26, 2014 5:28 pm    Post subject: Reply with quote
TDC was already marked in red when I got the car.
panicman
panicman is offline
PostPosted: Sun Jan 26, 2014 9:45 pm    Post subject: Reply with quote
Hey beryl, I have a 1962 40hp in my '60. I am running a 30 pict 1, and the 4R5 'fatboy' distributor. New points and condenser, rebuilt the carb and fuel pump within the last month. Brand new coil, plugs and wires. While dinking around, I too found that by advancing the timing a bit I could get a better feeling of power. But the idle seemed off, and it seemed to labor at idle, and I swear I had flat spots in acceleration, and trouble starting.
I re-timed to 10 degrees, and the idle is great, starting is great, but the tiny little edge of power I felt is gone.
I want to run this 40hp for a while, so I am just playing it safe and keeping it at ten deg.
Plate of shrimp
Aussiebug
PostPosted: Mon Jan 27, 2014 1:43 pm    Post subject: Reply with quote
Ok, with that combo, 10btdc is the right static timing.
Stay cool in Warburton, it's going to be hot there again today like here in Adelaide.
Rob
Beryl Green
PostPosted: Mon Jan 27, 2014 5:04 pm    Post subject: Reply with quote
No worries will give 10BTDC a go again. While we're on the subject the bloke up the road who's a mechanic says to use a strobe is the best way. Muir says static.
Few fires around today Aussiebug, stay safe too.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Mon Jan 27, 2014 5:51 pm    Post subject: Reply with quote
The big cap 40 horse and the 30 PICT carburetor are a mismatch.
Roads Scholar &
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Jan 27, 2014 8:25 pm    Post subject: Reply with quote
While I normally agree totally with tasb... I have to say, I never had a single issue when running a big-cap 40HP distributor with a 30PICT-1. '
The vacuum advance "plumbing" of the 30PICT-1 is identical to the 28PICT-1. It does vary from the 28PICT though. But I've run "fat boy" distributors on my big-bore 40HP engines for 20 years now, with a few different carbs. I've currently gone back to an old 28PICT (after I fixed the pulled out base studs) , but the Mexican 30PICT-1 I ran for several years ran quite well.
-Andy
panicman
panicman is offline
PostPosted: Wed Jan 29, 2014 9:45 am    Post subject: Reply with quote
It seems to be running fine, but what ought I watch for if the two weren't playing nice?
Plate of shrimp
tasb
tasb is offline
PostPosted: Wed Jan 29, 2014 5:44 pm    Post subject: Reply with quote
You would be looking for a spark advance that is not giving you the performance that you need/expect.
I am with Andy (glutamodo). I ran a 34 PICT 3 with a 113 905 205 T for many years. Not supposed to play well together but they did.
Lately I have had customers asking me what is "correct" rather than what will work.
Roads Scholar &
