the caveman Samba Member
Joined: August 09, 2004 Posts: 885 Location: island state of Montreal
Posted: Tue Aug 29, 2006 7:12 pm Post subject: air box for idf's |
does anyone know who makes these in the states?[/img] |
mharney Samba Member
Posted: Tue Aug 29, 2006 7:18 pm Post subject: |
No one in the states makes them, but they are ridiculous expensive. |
clearsurf2001 Samba Vaccinator
Joined: February 26, 2004 Posts: 1671 Location: Dave-AKA-fortyeye-Oceanside, Ca
Posted: Tue Aug 29, 2006 7:26 pm Post subject: |
Not sure if it would look better on the hood ...
Actually I've been toying with the idea of making just such a setup ... maybe without the horns though. _________________ Get ready for the injection
EverettB wrote: |
Make sure it is coherent. Rodney |
mharney wrote: |
I think Glenn has an EMPI crank in his engine. |
Posted: Tue Aug 29, 2006 7:27 pm Post subject: |
i just lookied again and it sure looks like the csp shop product.. and at 950 canadian quatllous i think i'll get go to the scrapyard and some fiberglass and have another project for next winter |
Posted: Tue Aug 29, 2006 7:28 pm Post subject: |
hey clearsurf looks like a nice cold air induction system up got there |
btrghia Samba Member
Joined: September 15, 2004 Posts: 190 Location: tucson,az
Posted: Tue Aug 29, 2006 7:29 pm Post subject: |
that box sire would make the carbs quiet. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76903 Location: Sneaking up behind you
I saw them at the Classic... something like $700 for it... OUCH. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Aug 29, 2006 7:30 pm Post subject: |
Those tiny inlets on that setup (the one on the ENGINE, yes) would have to go. Those little horns would restrict airflow in a big way. |
wizardVW Samba Member
Joined: August 21, 2006 Posts: 44 Location: Puyallup,Washington
Posted: Tue Aug 29, 2006 9:35 pm Post subject: |
i would agrre with ya about the reduction of air.just trying to figure out how to take that and introduce more air some how.ya know take a good product and make it better.but it looks really cool. _________________ 65 beetle.lots of rust but I WONT LET THIS ONE GET EATEN BY THE CRUSHER!!!!! |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Wed Aug 30, 2006 12:45 am Post subject: |
I saw one of thouse tested on a dyno session, the engine actually made more TQ with it on, My guess is less turbulant air entering the carb.
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Wed Aug 30, 2006 5:45 am Post subject: |
Actually, if you look at the inlets, each one is about the size of a single barrel on the carb. Since only one cylinder pulls air in at a time, then it probably is not a restriction. My guess is that it is adequate even for a large 2 liter since there is two openings right there.
A vacuum gauge hooked to the air filter housing while the engine is under load at WOT would tell for sure though. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Posted: Wed Aug 30, 2006 8:55 am Post subject: |
I think they are awesome, just too much money. It's also possible they are TUNED via opening size and chamber volume, and could increase power compared to regular filters or stacks without filters. The intake system resonates just like the exhaust, most guys tune the exhaust but don't bother with the intake.
As eric pointed out, the engine is only sucking thru one bbl at a time, and the filter box has 2 inlets, should not be an issue at all.
John
Aircooled.Net Inc. |
Posted: Wed Aug 30, 2006 9:17 am Post subject: |
does the part of the filter that connects to the carb one big opening or is it chambered into two sides? _________________ 65 beetle.lots of rust but I WONT LET THIS ONE GET EATEN BY THE CRUSHER!!!!! |
Posted: Wed Aug 30, 2006 9:44 am Post subject: |
just look at the original air filter[ of course with a lot less power] and other manufacture's air intakes. the intake is as small or smaller than the throttle diamater. i was thinking of using some turbo blow-through housings on the carbs,with larger inlets and finding a 85-92 vw turbo diesel air filter housing etc. |
74 Thing Samba Member
Posted: Thu Aug 31, 2006 9:18 am Post subject: |
Mark H did something like that-used the turbo caps from CB and then fabbed up a box and hoses from PVC-it worked great. The downside to the one in the pic is that you may have to change linkages as well or it may interfere with the airbox. |
Luftgekült Samba Member
Joined: December 30, 2007 Posts: 388 Location: Canary Islands, Spain
Posted: Fri Oct 16, 2009 8:50 am Post subject: |
I know is a 3-year-old thread.
I searched in the forum and find very little info about the dual IDF air boxes.
I'm looking for one in order to a quiter ride, but as everyone said, the CSP box is too expensive, and I can´t find a cheaper one.
A friend of a friend bought one, custom-made in Germany and he loved the noise reduction.
I wonder if anyone has developed another model (another=cheaper) since 2006.
Thanks
A link to the CSP air box: 728€
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_m...0&all= _________________ '71 VW 1302 1300cc in progress....
'72 VW 1302S 2109cc
'84 Passat Variant GL 1.6TD |
eds_apple Samba Member
Joined: April 21, 2009 Posts: 16 Location: Suffolk, UK
Posted: Wed Apr 21, 2010 7:52 am Post subject: Airbox |
Hi, I have been making a custom box given the cost of the CSP one. (just been working on it today)
I have made the central section, it follows a similar design to the CSP one, but with a modified intake. In essence two halves with a panel filter sandwiched between it.
I am now in the process of making the sections which fit on top of the carburettor bases, which then connect to the middle section by 3" rubber connectors. The box fits under the standard deckled, with no clearance issues.
The intake is 2 1/2" in oval diameter, and the dimensions were arrived at from studying Porsche intake boxes.
The box still needs clamps to be added, which is the next job and removing some of the mould tape which you can see in the inlet and a polish in places.
Sorry haven't worked out yet how to add images into my post but some images can be found at :
http://gallery.me.com/eds_apple |
Posted: Wed Apr 21, 2010 7:59 am Post subject: |
Please post photos when you are done. I could not access the link you provided.
Thanks |
Posted: Wed Apr 21, 2010 8:07 am Post subject: airbox |
ArnoudH Samba Member
Joined: December 30, 2008 Posts: 162 Location: The Lowlands
