TheSamba.com Connecticut Bug A Fair
Third Brake light
Goto page 1, 2, 3, 4  Next
BusBerd
BusBerd is offline
PostPosted: Fri Sep 01, 2006 12:59 pm    Post subject: Third Brake light Reply with quote
I just got my 3rd eye brake light from J.C. Whip-me today and I am wondering if I can stick it on the TOP of my hatch window? It will go over some defrost wires. Will that be a problem?
I taped it on with scotch tape to the bottom of the window and then to to top of the window to see the difference in how it looks from the back as well as how my view is from the driver's seat looking in the rear view mirror. I like the brake light better up in the higher position at the top of the hatch window.
"Don't postpone joy."
'77 Westy 2.0L Fuel Injected Engine(since Aug. '05)
Bajatacoma
Bajatacoma is offline
PostPosted: Fri Sep 01, 2006 1:09 pm    Post subject: Reply with quote
The LEDs shouldn't get hot enough to damage anything. Post a pic when you get it mounted- that's the one I keep meaning to order too.
'78 Westy
Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?
Hunter S Thompson
dwill49965
dwill49965 is offline
PostPosted: Fri Sep 01, 2006 3:30 pm    Post subject: Reply with quote
Here's the one I got from JC Whitney over three years ago. Still sticks firmly to the glass. Only problem is that it isn't that bright. Two weeks ago I went on a short camping trip around NS with my parents following behind in their car. At one point, I asked my dad if all my lights were working okay (they were), and then asked how my third brake light was. He didn't know I had one. Shocked That was during daytime driving. At night, it does show up better, obviously. As for mounting, put it up high.
I think I'm going to get one from Daniel Stern lighting - more expensive, but advertised as being far superior to other "junk". After all, why have one if it doesn't really work that well?
Darryl
'78 Westy, Boston Bob built 2.0 L, FI, Pertronix, MSD 6
Meyer wrote:
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent?
Hippopotabus
Hippopotabus is offline
PostPosted: Fri Sep 01, 2006 4:02 pm    Post subject: Reply with quote
Do you have a link or information on this vendor? Also, what if your bulb burns out? Can you access the bulb from a "back plate".
Thanks in advance.
Celer, Silens, Letalis
www.2dreconbn.net
dwill49965
PostPosted: Fri Sep 01, 2006 4:17 pm    Post subject: Reply with quote
http://www.danielsternlighting.com/products/products.html
There is a ton of really good info on the site - check out the tech page. He is very responsive to email as well.
As for access to the brake light - this is an LED light (I think 16 or 20 of them), so I don't expect to EVER have to change a bulb (or LED). I think there is access by popping off the back plastic cover, but I've never tried.
Looking at the photo again, maybe its those two screws on either side visible from the outside that hold the housing on. In that case, I'd say no.
Darryl
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Fri Sep 01, 2006 4:48 pm    Post subject: Reply with quote
Here is mine. It's not LEDs, but it works - plus it was only $4 at Harbor Freight.
Eric
77 Westy / 74 Super Beetle
My Feedback
Outside the Bus Table Brackets Available!
Click Here!
Fattie on being 'fired' from the Samba wrote:
then who would tell you guys if a ride is roll-able or not
Desertbusman
Desertbusman is online now
PostPosted: Sat Sep 02, 2006 2:22 am    Post subject: Reply with quote
Here is one of the Harbor Freight lights.
It worked out nice on the bus. Should help prevent getting rear ended. Since the busses are slower than all the crazies every once in a while I've tapped the brakes when it appeared a fast approaching vehicle might not see our weak tail lights.
Have had one on the bug for years. That one came from Pep Boys.
The best thing that anyone can do for their Bay is get the Bentley service manual. Without it the bus is pretty much doomed.
73kombi wrote:
when that red light goes on, you have to make a choice.
Amskeptic wrote:
I am not answering that.
Respectfully,
GoBuyABentley
71 Superbug
71 Westy
benw82
benw82 is offline
PostPosted: Tue Dec 15, 2009 8:03 am    Post subject: Reply with quote
anyone know how to get there third brake light to blink a few times when you first step on the brake and then it stays solid after a few seconds.
is it just some kind of inline relay?
i've seen it on a few vehicles around town and i think it would be great for the bus to keep from getting hit.
dubluvv
dubluvv is offline
PostPosted: Tue Dec 15, 2009 8:08 am    Post subject: Reply with quote
Here's a few:
http://signaldynamics.com/products/BLSM/blsm.asp
http://www.comagination.com/bflasher.htm
-Mitch
For all of your recycling needs! http://www.earth911.com
'76 Westy 2.0L FI "Lucy" Project Thread
'74 Super Beetle 1641CC
chazz79 wrote:
"Aw honey, I got another one of those bay-bus things on my shoe again...dammit"
jtauxe
jtauxe is offline
PostPosted: Tue Dec 15, 2009 8:20 am    Post subject: Reply with quote
That looks fairly dim as well--not even as bright as the already relatively dim stock rear lights. I want one that really grabs your attention.
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
Long gone: 1969 Transporter, Westies: 71, 76, 77, 76, 77, 71
Current fleet:
1978 Neptune Blue Double Cab 2.0-L FI RHD
1973 White Westfalia (production number 9)
1977 Orange Westy project - for sale soon
http://vw.tauxe.net
SGKent
SGKent is offline
PostPosted: Tue Dec 15, 2009 11:58 am    Post subject: Reply with quote
it looks like the reduced brilliance is the angles involved. The lights, including Daniel's, aren't designed for a window at close to 90 degrees so one is looking at the lights/refector at an angle. Once needs to locate one for a vertical window - maybe something from a truck store where people sell camper shells with vertical windows.
Thank You,
Merlin
Merlin the Wrench
Steve's Racing and Engine Blueprinting
1978 & 1979 SCCA F & G Prod champions - California and Western Regions
1971 Butterscotch 7-passenger sunroof deluxe (1976-1984)
1977 Sage Green 7-passenger sunroof deluxe
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Tue Dec 15, 2009 12:16 pm    Post subject: Reply with quote
That is because that window was darkly tinted - I have since removed the tinting and it is a lot brighter.
Eric
My Feedback
Click Here!
SGKent
SGKent is offline
PostPosted: Tue Dec 15, 2009 12:32 pm    Post subject: Reply with quote
that harbor freight item appears discontinued
Thank You,
Merlin
Merlin the Wrench
meinvw
meinvw is offline
PostPosted: Tue Dec 15, 2009 12:49 pm    Post subject: Reply with quote
although I do plan on adding a third brake light, I put these on all mine. The reflector strips available at most flaps or truck stops. At night they really show up when someone is behind you. You can see from the flash during the day how they light up.
The memories of a man in his old age, are the deeds of a man in his prime.
Quando Omni Flunkus Moritati !
88 transporter panel,78 & 73 westy,01 NB
www.fullmoonbusclub.com
Want a hazet tool kit or hazet buddy ,plaid stool/bucket, or a drive away tent (later model, do not want og tents) Trades on these parts since I am a broke mo-fo.....
Bajatacoma
PostPosted: Tue Dec 15, 2009 3:44 pm    Post subject: Reply with quote
Wow- thread resurrection. Shocked
I ended up going with the Hella LED light from Daniel Stern, although I see they've gone up in price considerably since I bought mine. Installation was very easy- just measure where it needs to go and stick it on with the 3M doublesided tape; I stuck it at the top so the wires were better hidden and to get it up as high as I could. Run the wire to a brake light wire (I used the left side since that's the side the wire comes out of the assembly) and tap it in using the supplied wire tap. No worries about voltage drop since LEDs use so little voltage. It also came with small plastic pieces to secure the wire along the window molding. The bus rear window isn't exactly ninety degrees so it works just fine- it's definitely an improvement over the stock brake lights. Honestly I think most people are so stupid these days that they expect a third brake light and aren't looking down at the factory lights on the bus. I can't access my Photobucket account from here or I'd post a picture.
Like meinvw I also have reflective tape on the back of the bus although I used white tape that fits almost perfectly in the contour of the bumper (where it's indented). It's not very noticeable in the daytime, but it definitely catches your eye at night when you cruise up behind it. 3M also makes reflective tape in a multitude of colors including the very cool black to white.
'78 Westy
Hunter S Thompson
dwill49965
PostPosted: Wed Dec 16, 2009 2:30 pm    Post subject: Reply with quote
I also went to the Hella LED brakelight from Daniel Stern, shortly after my above posts. The difference is night and day.
I'd never heard of those brake light pulsing modules before - I think they would be a great idea (on my other vehicles, too).
Darryl
chabanais
chabanais is offline
PostPosted: Wed Dec 16, 2009 9:22 pm    Post subject: Reply with quote
Pulsing lights are not legal in the US.
"I spud therefore I yam."
I love shiny bits!
timo78
timo78 is offline
PostPosted: Wed Dec 16, 2009 10:24 pm    Post subject: Reply with quote
Which sucks because pulsing actually works to wake up the sleeping masses at the wheel as they talk on their cell phone, while checking themselves out in the mirror, and playing with the stereo while texting. I'll tap mine when I see trouble ahead.
on topic: I want a third brake light too, that's two old threads tonight that have spawned additions my project list. Thanks
Green Bay Bus > 78Grµn Westfalia ~ FI - Pertronix
Fiendish Dr Wu, your knowledge of scientific, biological, transmogrification is only outmatched by your zest for kung fu treachery!
chabanais
PostPosted: Wed Dec 16, 2009 10:28 pm    Post subject: Reply with quote
Mercedes is working to have the law changed.
I love shiny bits!
Mr'72Special
Mr'72Special is offline
PostPosted: Wed Dec 16, 2009 10:31 pm    Post subject: Reply with quote
I like the third brake light Daniel Stern sells as well. But the thing is that none of the high-mount third lamps are angled near perfectly vertical with their mating surface(s). if I used model 39 for 57° to 80° back windshields, would this affect medium- to long-range visibility at all? It looks good for the earlier Vanagons (when DID they start to add them?), but for a bay/split I'm not sure.
Honsetly, I think all brake lights should pulse or brightness-spike to have most chance of snapping the text driving dolts out of their 'lol I r drivng' somnambulism. Mad
Page 1 of 4
Copyright © 1996-2010, Everett Barnes. All Rights Reserved.   | Archive
