fisheye Samba Member
Joined: July 08, 2005 Posts: 101 Location: Boca Raton, FL
Posted: Tue Sep 12, 2006 6:55 pm Post subject: Now that the CV's are off - what type of oil? |
I got my CV's off with plenty of soaking with Gibbs oil. Since I have room to work I thought I'd change the transmission oil. What is a good synthetic for the Thing gear box? |
bciesq Samba Member
Joined: April 13, 2005 Posts: 495 Location: Orlando, FL
Posted: Wed Sep 13, 2006 3:26 am Post subject: |
I've recently researched this very issue. The main thing that I learned is to stay away from GL-5 gear oil because some of the additives are corrosive to the ACVW tranny.
I really trust the folks at aircooled.net, so I just ordered this:
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=CAL0003&cartid=
You can find it cheaper elsewhere online, but I was placing an order with them anyway.
Other people swear by this stuff:
http://swepcousa.com/lubesite/gear.htm
And then others say to get any name brand synthetic in proper weight (75W90).
Here's one of the better discussions that I read:
http://www.thesamba.com/vw/forum/viewtopic.php?t=158813&highlight=gear+lube
Oh, and one technical tip: Remove the plug where you add oil *before* you drain the oil. You don't want to empty your tranny only to find out that the plug where you add the oil has frozen up.
Good luck and HTH.
Ben _________________ '73 Thing -- making 45 mph exciting again. |
Posted: Wed Sep 13, 2006 7:15 am Post subject: |
It seems that all of the oil in the local shops says exceeds GL-5 standards. I picked up a bottle of Mobil 1 75w90 synthetic. Is that safe to use? |
74 Thing Samba Member
Posted: Wed Sep 13, 2006 9:56 am Post subject: |
I have used Redline Syn gear oil for years-good stuff. |
