Pddpimp Samba Member
Posted: Tue Sep 13, 2011 4:00 pm Post subject: |
OUCH!!!
I replaced my nose this spring (haven't got it painted, yet). I plan on using POR-15 on the sheet metal, where the seal goes. You can prep the POR-15 and paint right over it.
Just a thought for something you could do for your next nose.
Good luck, man! |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Wed Sep 14, 2011 5:36 pm Post subject: |
Here's my Gerson piece. This will speed up the repair.
Here what I found after I took a knotted wire wheel to the metal. I was expecting more holes but this is all that showed up. The top of the frame was solid - no rust through.
Welding from the nose replacement.
_________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Fri Sep 16, 2011 3:35 pm Post subject: |
EZ Gruv wrote: |
Damn, time to move. |
I was thinking the exact same thing..... _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Joey Samba Member
Posted: Fri Sep 16, 2011 5:30 pm Post subject: |
Kirk wrote: |
EZ Gruv wrote: |
I was thinking the exact same thing..... |
Or I could just stop driving it in the winter... _________________ Joey
Joey Samba Member
Posted: Tue Sep 20, 2011 4:07 pm Post subject: |
Started repairing the small rust holes...
Then I moved on to the big piece. Pretty rusty inside too. I brushed on some Tremclad to slow down the rust.
Welding in the Gerson piece.
I found the Gerson piece to be a bit too long where the metal bends over the A pillar. I had to cut pieces off (last two pics) in order to get the piece to fit on. I'll weld them back on after I trim a little off them. The piece fit good around the windshield opening but I had to force it to meet on the bottom. I think it was easier when I replaced the complete nose. _________________ Joey
shiningstar76 Samba Brewer
Posted: Tue Sep 20, 2011 4:17 pm Post subject: |
Nice thread Joey. Great photos. _________________ KK4NTP
96 Tacoma
86 4Runner
My bus caught on fire and is now on the other coast with someone who gave me money for it. |
Joey Samba Member
Posted: Wed Sep 21, 2011 5:18 pm Post subject: |
shiningstar76 wrote: |
Nice thread Joey. Great photos. |
Thanks.
I got the rest of the welding done on the A pillars.
And the doors back on.
Not sure why the top body line is off on this side. I'm not too concerned about the looks just as long as the windshield fits.
This guys body lines are off too:
If I were to do it again I'd do it how this person did it:
http://www.thesamba.com/vw/forum/viewtopic.php?p=5290725&highlight=#5290725
Next I got to weld up the few small holes on the top frame and slap some POR 15 on it. _________________ Joey
TheRealMacGyver Samba Member
Joined: July 13, 2011 Posts: 198 Location: Spring Hill, FL
Posted: Wed Sep 21, 2011 5:36 pm Post subject: |
How did that Tremclad hold up with the welding heat? I have been thinking about doing something similar with POR-15 (maybe Tremclad-not familiar with it though). Been thinking I could coat a lot of the "back-side" of things you never see and keep it from rusting from the inside out. But was wondering about melting it off or possible starting it on fire and basically losing the purpose of the product. So, what did you experience in that respect?
BTW, great pics and thread, definitely great info for me since I am close to doing the same repair here soon. Thanks. _________________ 1977 Transporter 2.0L Automatic Project
1979 Transporter 2.0L Automatic Project
1977 thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=484931 |
Joey Samba Member
Posted: Wed Sep 21, 2011 6:05 pm Post subject: |
I'm sure the Tremclad (same as Rust-oleum) burned off where I welded. I didn't see any fires yet. I plan on shooting a rust inhibitor in there as well. Weld-through primer would be better. It burns but it melts back into the weld. _________________ Joey
Kirk Samba Member
Posted: Wed Sep 21, 2011 6:11 pm Post subject: |
Damn good work. Way to keep one alive. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Joey Samba Member
Posted: Sun Sep 25, 2011 5:02 pm Post subject: |
More progress...
Not sure if I should use POR 15 or just paint for around the windshield frame. Anyone have a bad experience with POR 15 in this area? _________________ Joey
Kirk Samba Member
Posted: Sun Sep 25, 2011 6:46 pm Post subject: |
I'm not from your area obviously, but I'd por 15 it since its more rust resistant. Looks good. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
78riviera Samba Member
Joined: August 31, 2011 Posts: 96 Location: snohomish,WA
Posted: Mon Sep 26, 2011 8:00 am Post subject: |
i need to replace my dented up front panel on my 78 its too much for a new panel, so im assuming if i can find a straight nose on another 78 or 79 i can just cut it off and weld it to my bus?Im not going to just cut up any old bus it will have to be a parts bus thats to far gone to save. I know of a 78 down at pull a part that im going to be going to pretty soon. _________________ Victim of Volkswagen Virus |
Joey Samba Member
Posted: Mon Sep 26, 2011 5:05 pm Post subject: |
78riviera wrote: |
i need to replace my dented up front panel on my 78 its too much for a new panel, so im assuming if i can find a straight nose on another 78 or 79 i can just cut it off and weld it to my bus?Im not going to just cut up any old bus it will have to be a parts bus thats to far gone to save. I know of a 78 down at pull a part that im going to be going to pretty soon. |
If you're just going to use the nose skin then '73 and up will work.
I did the Marine clean & Metal-Ready to the windshield frame this evening. Hopefully it'll be dry and ready for the POR 15 tomorrow. _________________ Joey
Bloog Samba Member
Joined: April 11, 2007 Posts: 484 Location: Over yonder
Posted: Mon Sep 26, 2011 5:20 pm Post subject: |
You've got some mad skillz Joey! Very nice! _________________
Bob Hoover wrote: |
Listen to what the ENGINE has to say. It won't take your money and it's incapable of lying. All you have to do is learn to speak its language.
-Bob Hoover |
chabanais wrote: |
Ah... you buy from Sum Ting Wong Distribution Company. |
Posted: Mon Sep 26, 2011 6:08 pm Post subject: |
yes butthe doors bolt on different in 78 and 79 dont they _________________ Victim of Volkswagen Virus |
chris roop Samba Member
Posted: Mon Sep 26, 2011 6:54 pm Post subject: |
Wow! To think of doing that job every 5 years! _________________ http://www.roopsmg.com |
Kirk Samba Member
Posted: Mon Sep 26, 2011 7:17 pm Post subject: |
78riviera wrote: |
yes butthe doors bolt on different in 78 and 79 dont they |
Nope. If I were you I'd try popping out that dent on your nose first. You have many other things to address before you start major body work. I bet you can pop it out into usable shape. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Joey Samba Member
Posted: Tue Sep 27, 2011 4:27 am Post subject: |
chris roop wrote: |
Wow! To think of doing that job every 5 years! |
The nose I put on back in 2006 wasn't in perfect condition. In fact, it came off a bus that also was driven in the winter (road salt). _________________ Joey
Joey Samba Member
Posted: Tue Sep 27, 2011 4:33 am Post subject: |
Kirk wrote: |
78riviera wrote: |
Nope. If I were you I'd try popping out that dent on your nose first. You have many other things to address before you start major body work. I bet you can pop it out into usable shape. |
Like I said earlier, if you are just replacing the nose skin, not the whole piece as I did, you won't have to worry about the door hinges. _________________ Joey
