Joey Samba Member
Joined: August 12, 2005 Posts: 3696 Location: Halifax, Nova Scotia, Canada
Posted: Tue Sep 27, 2011 4:59 pm Post subject: |
Two coats of POR 15. One more to go...
 _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
vintagevdubbers.ca |
skills@eurocarsplus Samba Member
Joined: January 01, 2007 Posts: 3954 Location: sticksville, ct.
Posted: Tue Sep 27, 2011 7:34 pm Post subject: |
good work! but i have to ask, if your nose keeps evaporating every few years, what the hell does the bottom of your bus look like?
i like rust too. click my "click here" in my sig line. i can appreciate the work you're doing  _________________
| VWsArent4Hippies wrote: | | Whenever I click on the baywindow forum I feel like I'm entering a place where most people have no sense of reality |
| schell '59 wrote: | | The honor system works for boy scouts..not in real business |
| modok wrote: | | It was in the instructions back when stuff came with instructions |
| curtis4085 wrote: | | as most your information you give is crap anyway |
| bugger101 wrote: |
skills, you never win with cheap vw people |
Joey Samba Member
Posted: Wed Sep 28, 2011 5:22 am Post subject: |
Actually, the bottom is still solid, including the rockers.. I've been applying Rust Check to the chassis, inside the rockers, doors, outriggers, front beam and any other place I can get it for the last ten years.
Here some other pic of what I repaired over the last few months:
https://www.facebook.com/media/set/?set=a.10150309...amp;type=1
It's my winter vehicle so I know it's going to rust. When the chassis or beam starts to rot out then I will call it a day. _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
Joey Samba Member
Posted: Wed Sep 28, 2011 7:18 pm Post subject: |
First coat of green paint (Tremclad) on:
You can kinda see I didn't bother to fully grind down the weld on the bottom of the repair... I'm going for the Frankenstein look. _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1412 Location: East Bay Area, California
Posted: Wed Sep 28, 2011 9:27 pm Post subject: |
I need to do this to my bus, its a 68, and the nose is dented from a previous owner's misjudgement of the stoppingness of the brakes. I'm having a hard time locating a low light nose though...
I like your work, makes me want to learn to weld! _________________ 1987 Wolfram Gray 2WD Vanagon GL Westy (1.8T Powered!)
2001 ALH Jetta TDi (Hers)
1998 ALH New Beetle (His)
http://www.thesamba.com/vw/forum/viewtopic.php?t=496946 |
Joey Samba Member
Posted: Fri Sep 30, 2011 6:02 pm Post subject: |
Windshield is installed!
Gap between the metal and the rubber here...
...and here, probably because of my weld repair.
The windshield rubber seal (http://www.cip1.ca/ProductDetails.asp?ProductCode=C16%2D241%2D121COE) was a bitch to get on the glass. I had to get the wife to help hold it on on one corner as I worked it around the glass. Once it was on it fit real good. She also helped with the install, she pulled the string from the inside as I pushed on the glass from the outside. Once the paint hardens a bit more I'll shoot some windshield urethane adhesive under the windshield rubber to seal things up. _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4083 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Fri Sep 30, 2011 6:07 pm Post subject: |
I just bought that German seal for my bus. Haven't installed it yet, but it looks to be a very good quality seal at a very fair price. I couldn't find a seam on mine anywhere; it was like a continuous piece. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
Joey Samba Member
Posted: Fri Sep 30, 2011 6:33 pm Post subject: Front Nose Replacment & windshield frame rust repair |
The seam is very hard to detect. It's in the middle on top. It fit very well in my hacked & slashed window opening...  _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
Posted: Wed Oct 05, 2011 9:08 pm Post subject: |
I'm trying to find a new nose panel, are only used ones available for the low light buses? _________________ 1987 Wolfram Gray 2WD Vanagon GL Westy (1.8T Powered!)
maximan1 Samba Member
Joined: January 07, 2008 Posts: 1367 Location: Anaheim, California
Posted: Wed Oct 05, 2011 10:07 pm Post subject: |
Sweet! My thread was used as an example again!
For the record though, my left body line was off too. I just beat a new body line into it though. Seems like this is kind of a common issue with Gerson panels... _________________ 1978 Transporter, 2.0L FI |
chris roop Samba Member
Posted: Wed Dec 28, 2011 8:43 pm Post subject: |
Great results from a leap of faith!
I brought home a 71 today that will need a nosectomy, but it comes with the virgin donor replacement from another bus. If rust wasn't an issue, can you just linish the skin from the door openings and then cut horizontally wherever top and bottom?? _________________ http://www.roopsmg.com |
Joey Samba Member
Posted: Thu Dec 29, 2011 7:00 am Post subject: |
| chris roop wrote: | Great results from a leap of faith!
I brought home a 71 today that will need a nosectomy, but it comes with the virgin donor replacement from another bus. If rust wasn't an issue, can you just linish the skin from the door openings and then cut horizontally wherever top and bottom?? |
Like this?
http://www.thesamba.com/vw/forum/viewtopic.php?t=400853 _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
Posted: Thu Dec 29, 2011 8:20 pm Post subject: |
| Joey wrote: | | chris roop wrote: | Great results from a leap of faith!
Like this?
http://www.thesamba.com/vw/forum/viewtopic.php?t=400853 |
That was an excellent tutorial! Thank you! Once things settle down around here a little, I'll have to check that out some more. My welding skills might produce something looking akin to what the Reevers would fly, but hey. _________________ http://www.roopsmg.com |
themadcap Samba Member
Joined: January 02, 2005 Posts: 2 Location: Pembroke Pines, FL
Posted: Tue Jan 22, 2013 10:02 am Post subject: |
I did the same thing, but for the life of me I can't get the darn headlights to mount correctly. Your front panel looks just like mine, did you have to do anything different? Please help. _________________ DJ Ksada
Pinchadiscos305.com |
Nigelbug Samba Member
Joined: November 13, 2010 Posts: 148 Location: England
Posted: Sat Mar 30, 2013 2:22 pm Post subject: |
| Joey, I don't know why you bothered it's always going to be a bay window. Sell it and buy a split screen. |
Chad aka Chud Samba Member
Posted: Mon May 13, 2013 5:36 am Post subject: |
| Very interesting. I am getting ready to do the same, but I am going to go from the middle of the floor to above the wind shield... |
Joey Samba Member
Posted: Mon May 13, 2013 7:36 am Post subject: |
Take lots of pics! _________________ Joey
'56 Beetle
'65 Beetle
'74 Bus
'79 Panel
