alg Samba Member
Joined: April 24, 2006 Posts: 134 Location: Webberville, TX
Posted: Mon Sep 25, 2006 1:56 pm Post subject: whats dat box for, electrical, headlight woes |
Battle of the headlights for about 8 months now.
Replaced ALL components of the headlights:
- turn signal switch (hi beam)
- headlight relay
- headlight switch
- All new, proper fuses
Next to the headlight relay, in the dash behind where the headlight switch is mounted is this black box. Its about the size of a biscuit block used for the old-style telephone jacks.
What is that box? I have diagrams and some schematics, and cannot figure it out at all.
All wires have continuity and I rang out the ground paths with a meter.
There is power to the fuse box, but no headlights at all.
Running lights are fine as is dash backlight/dimmer.
Signals work fine.
Thanks for any feedback you may have |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Mon Sep 25, 2006 2:17 pm Post subject: |
What year is your 181? This will help us in identifying that black box.
On my military 181 (1971), I have one in this location that is used for the "parade" horns and blue light. Was your's a military import? |
mattt Samba Member
Posted: Mon Sep 25, 2006 3:56 pm Post subject: |
The black box with 4 wires out the bottom is the turn signal flasher relay.
Check the fuses for the headlights. Sometimes one of mine doesnt light, and I wiggle the fuse in the fuse holder, boom, headlight comes on. |
bucko Samba Member
Posted: Mon Sep 25, 2006 5:07 pm Post subject: |
"The black box with 4 wires out the bottom is the turn signal flasher relay.
Check the fuses for the headlights. Sometimes one of mine doesnt light, and I wiggle the fuse in the fuse holder, boom, headlight comes on."
Good point Matt. I had a bus one time that had what appeared as faulty headlights. I spent a good part of a day with a multimeter cheacking for 12 volts from the switch to the headlight bulbs. What I found was that the tip or crown of the fuses were worn off. The fuses looked good, but in fact were not making contact in their holders.
You might want to put all new fuses in the low beam and high beam positions. |
kubelmann Samba Member
Posted: Mon Sep 25, 2006 7:30 pm Post subject: |
I recently went through a one headlight out issue. It turned out to be a ground wire that had broken inside the solderless connector. I took countless hours to track this faulty ground// |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Thu Sep 28, 2006 10:57 pm Post subject: |
bucko wrote: |
Yeah, I 've had this happen seceral times over the years of VW ownership. I've normally just spun the fuses in the holder to see if that brings them to light. If not, then I look deeper. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Sep 28, 2006 11:39 pm Post subject: |
Yeah, I've spun fuses to get my brake lights back, my wipers back, my turn signals back. Every year, I pull them all, clean all the contacts and fuse ends, and make sure the retainers are tightly seated. I still have to spin fuses now and again.
I'm thinking of swapping out the fuse box with a box that'll take the blade style fuses:
http://www.delcity.net/delcity/servlet/catalog?par...p;tabset=1
or, if that one uses a common power feed (and thus won't work to replace the old fuse box) then this should do it:
http://www.delcity.net/delcity/servlet/catalog?parentid=650092&page=1
$6 or $12. Heck, I'll order them both.
With the blade-style fuse boxes, you can get fuses at any gas station or you could even replace some of them with breakers:
http://www.delcity.net/delcity/servlet/catalog?parentid=151&page=1
(only 10 amp and up) . |
mattt Samba Member
Posted: Fri Sep 29, 2006 9:16 pm Post subject: |
That first fuse panel you show is similar to what I plan to convert to some day when I get to it. Does delcity.net have one that is 10 fuses wide? I think there are 10 fuses stock. If not, the company LittleFuse has a 10 wide fuse block just like the one you pulled up in the link here. Its a bit more expensive, but its a 10 slot. G. Mondshine did a write up & first unit on this LittleFuse install years ago. Its a clean install since it's the same shape and rough size as the stock one. |
MajerThing Samba Member
Joined: January 04, 2006 Posts: 45 Location: Tucson, AZ
Posted: Thu Feb 22, 2007 11:00 am Post subject: |
Ian,
Have you installed either of the fuse boxes? My current fuse block is bent all to heck and spinning/wiggling the fuses has become a standard start-up routine. I was looking to replace with a blade style and wondered if you had any luck. |
90runner Samba Member
Joined: July 24, 2006 Posts: 118 Location: Vancouver Island, British Columbia
Posted: Fri Feb 23, 2007 9:44 am Post subject: |
I've thought of totaly rewiring with something like a painless universal kit it updates everything. A little expensive though but could be worth it. |
