Front Bumper mount holes
houseoffunn
houseoffunn is offline
PostPosted: Mon Oct 09, 2006 8:43 am    Post subject: Front Bumper mount holes Reply with quote
I'm in the process of building a small slide in luggage rack for the front of my Thing and have a couple of questions.
First, has anyone ever built a carrier that would slide into the rectangular bumper mount openings?
Second, inside the bumper mounts there is a cross pin installed on each mount. What is it for?
What I am trying to design would be removable, kind of like the carriers that you see on the back of trucks/SUV's that slide into the trailer hich mount.
Any help appreciated.
bucko
bucko is offline
PostPosted: Mon Oct 09, 2006 1:48 pm    Post subject: Reply with quote
"Second, inside the bumper mounts there is a cross pin installed on each mount. What is it for? "
Can you post a pic of this? Not sure I know what you mean.
Ferretkona
Ferretkona is offline
PostPosted: Mon Oct 09, 2006 2:20 pm    Post subject: Re: Front Bumper mount holes Reply with quote
houseoffunn wrote:
I'm in the process of building a small slide in luggage rack for the front of my Thing ,,,,,,,, What I am trying to design would be removable, kind of like the carriers that you see on the back of trucks/SUV's that slide into the trailer hich mount.
Why not make a 2" receiver to mount behind the front bumper? You could use the carriers that are already made for the receivers and use it front and rear. Bicycle racks, fuel can racks, a removable winch! Winches are sold mounted to 2" mounts to use front and rear, lock in the garage during the off season. Using the holes in the bumper is a cool idea, but the carrier would be limited to the Thing only.
houseoffunn
PostPosted: Mon Oct 09, 2006 3:41 pm    Post subject: Reply with quote
The pins are inside of each of the two bumper mounting arms, close to the front of the bumper and running across from side to side. It's about 2 or 3 inches long by 1/4 inch and appears to be some kind of attachment point for something. Maybe this car had the rubber guards and the pins held them on?
Thanks again for your help.
markie61
markie61 is offline
PostPosted: Mon Oct 09, 2006 4:30 pm    Post subject: Reply with quote
Here is a design for a REAR trailer hitch that uses the existing bumper bolts. http://www.thesamba.com/vw/classifieds/detail.php?id=320835 The same concept could be adapted to the front bumper and a box receiver.
If you are talking about the two square holes on the face of the bumper that each have a piece of roundstock bisecting them horizontally....I am not sure what their designed intent was. I have seen them used frequently on military Things as anchor points for ropes. My bumper overriders are installed through a single hole drilled through the bumper. Some other types of overriders may be installed there however.
If this is not what you are referring to, it was probably a previous owner mod that lost its purpose.
Mark
Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!?
ztnoo
ztnoo is offline
PostPosted: Mon Oct 09, 2006 5:22 pm    Post subject: Reply with quote
houseoffunn,
I think you are "spot on". We don't have any here on the three vehicles holed up in the barn here in Hoosierville, and I've never seen any "in the flesh", but it sure makes sense to me.
Here's what I've been able to round up from my album of Things shots lifted off the net.
My vote: holes for bumper overriders.
Tim Gud can probably speak to this with authority.....he listed a set in Classifieds several months back.
Here's some pics:
[/img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=308111[img]
[/img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=308112[img]
[/img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=308113[img][/img]
ztnoo
ztnoo is offline
PostPosted: Mon Oct 09, 2006 5:31 pm    Post subject: Reply with quote
Well I screwed that up big time....was going for a direct link to display the pics here in the thread.
Too tired to figure the mechanics out tonight.
houseoffunn
PostPosted: Mon Oct 09, 2006 5:55 pm    Post subject: Reply with quote
Thanks everyone for the replys.
As to taking a generic rear hitch reciever as mentioned and fabing a custom mount for it, that wouldn't be too hard but it would leave the receiver joint there all the time. The orginal idea was to use the existing stock front bumper rectangular holes as insert points so that when not in use, the carrier could be removed and hung up on the wall. I think either one would work though.
Has anyone seen this done?
bucko
bucko is offline
PostPosted: Mon Oct 09, 2006 6:39 pm    Post subject: Reply with quote
Those "pins" that run horizontal in the square hole are for towing of the vehicle, if it got stuck in sand. The military versions came with an eyelet that mounted in these pins for that purpose.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Mon Oct 09, 2006 9:20 pm    Post subject: Reply with quote
You got close, Steve. Wink
Am I mistaken, or are those Bug overriders on the middle one?
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Ian Epperson
Ian Epperson is offline
PostPosted: Mon Oct 09, 2006 10:32 pm    Post subject: Reply with quote
Those are the exact same ones I had on my Thing before I changed out to the tube bumpers. Note that the hole that's being described is visible (like mine was) - these overriders don't cover it.
markie61
markie61 is offline
PostPosted: Tue Oct 10, 2006 5:29 am    Post subject: Reply with quote
The orange car's overriders are the ones I have too. They don't cover the towing holes like the other tow cars' overriders seem too and perfectly match the bumper cross profile. Interesting the different overriders: my set looks like B cups while others look like D's .... Razz
Mark
markie61
markie61 is offline
PostPosted: Tue Oct 10, 2006 5:38 am    Post subject: Reply with quote
Never seen it done, but I don't get out much... Rolling Eyes
I think this would be a great idea. You could turn these holes into mini-receivers by cutting out the bumper's pins and using the front bumper bolt to anchor it into place. Or, you might be able to cut a long notch and preserve the stock pins. Brilliant! Idea
Besides increasing carrying space, keeping cargo weight up front and close to (or below) the axle line certainly could enhance vehicle stability by lowering the center of gravity.
Mark
Video Bob
Video Bob is offline
PostPosted: Tue Oct 10, 2006 7:00 am    Post subject: Reply with quote
Examine the over riders on the orange Thing and it says VWOA. It was an original optional equip. The large ones are later units made available by the Thing Shop. Yes the cross pins are for towing. They don't look very practical though. :lol:
houseoffunn
PostPosted: Tue Oct 10, 2006 7:23 am    Post subject: Reply with quote
Agreed, the pins don't appear to be strong enough to be of much assistance. My thought was to remove them in order to make the bumper openings a reciever point for the carrier.
As to a proper towing attachment point in the front, installing a hook mounted under the bumper mounting points to the body might be an option, using longer bolts to go through both the bumper mounts and the hook mount.
Any ideas on that?
