Ogberi Samba Member
Posted: Thu Oct 19, 2006 7:17 pm Post subject: Blew out a spark plug today |
Hi All,
Just when I thought my day was super-crappy,
BAM! CHUG CHUG CHUG
The bus blew out #3 plug. So, it looks like I'll be dropping the motor next week and yanking the heads. I learned when I first tried to change the plugs that #1 and #3 have inserts already. Joy.
The bus is a '77, 2.0L FI.
Thankfully, I was able to tuck the plug wire out of the way through the access hatch, unplug the fuel injector and drive the scant 1.5 miles home very gently. Damn that thing is loud with a plug missing.
Next week I'll know more, but I suppose I'm looking at...
Timesert #1 and #3 plugs with their "Big" kit for previously repaired holes.
Finding a pair of used heads
Buying replacement heads (new)
My questions -
Is it easier to drop the engine and tranny together at once? I planned on dropping the tranny anyway (stick shift) to change the shift bushings. Just wondered it it was more or less work to do 'em both at once. I have access to an ATV jack.
*sigh* Woke up with a pinched nerve in my back. Got to work to find that people can't scan documents into the document server. Get chewed out for not running a software update. Run the software update on the "test environment" and it crashes horribly, taking down the production server for an hour. Stop on the way home to buy tune-up parts for my wife's postal jeep ('83 DJ-5M), and the shmuck at Nappy gives me the *WRONG FREAKIN SPARK PLUGS*. Leaving Napa, the bus blows out #3 plug. Get home, realize that I have the wrong spark plugs for the Jeep, and head back to find Napa closed. Go to AutoBone, get correct plugs. Get home and replace cap, rotor, plugs. Realize jeep has squeak that I can't find (body/vibration related) and the ignition switch is going bad.
And best of all? No freakin' beer in the fridge. *sigh* What a day. |
Bleyseng Samba Member
Posted: Fri Oct 20, 2006 7:33 am Post subject: |
My 77 did the same thing last year from cracks in the heads. No way could I get the plug repair to hold.
New Raby/HAM heads went in. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
whc03grady Samba Member
Joined: February 07, 2004 Posts: 337 Location: Livingston Montana
Posted: Fri Oct 20, 2006 8:44 am Post subject: |
Dropping the drivetrain all at once
Pro: no dancing and wiggling to line up engine and transmission when reinstalling.
Con: CV joints are messy and you're bound to gum up a couple of the bolts.
I'd still do it all at once, personally, but I'm far from an expert and not very well-practiced. Just my two cents. _________________ 1974 Westfalia "Ludwig"
1971 Squareback "Gertie"
Read about their adventures
blankmange wrote: |
The Bentley assumes that the car is complete. |
Freduardo Samba Member
Joined: May 11, 2006 Posts: 25 Location: San Antonio Tx
Posted: Sun Oct 22, 2006 6:03 am Post subject: |
My '76 threw out the #3 spark plug last year. I was able to tap the spark plug insert but later the head burnt a valve. Found out it was a leak from the exhaust manifold. Replaced the head with a rebuilt. |
Blaubus Samba Member
Posted: Sun Oct 22, 2006 6:32 am Post subject: |
Quote: |
Go to AutoBone, get correct plugs. |
not only do they have the right plugs , but i find they are cheaper there. only good thing i can say about autozone. whereas their igniition wires were more expensive than my local FLAPS |
bd1308 Samba Member
Posted: Sun Oct 22, 2006 8:28 am Post subject: |
I'm sorry to be the bearer of bad news, but that head is in need of a rebuild. I had a 914 (still do ) that had a 2.0 head blow out plug #1, and it turns out I uncovered a dropped valve seat or three, and one totally gone. |
Posted: Sun Oct 22, 2006 8:36 am Post subject: |
Its rare that it was just caused by a previous crossthreading leading to a stripped plug.
ususally its a crack _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Randy in Maine Samba Member
Posted: Sun Oct 22, 2006 8:53 am Post subject: |
Not to sidetrack this thread but when the heads are off, can they be "magnafluxed" at the machine shop to see if there are cracks that maybe you cannot see?
Just curious..... |
