amishman Samba Member
Joined: March 09, 2004 Posts: 3217 Location: California
Posted: Tue Oct 24, 2006 1:56 pm Post subject: Starting my Thing after sitting a year - It Started! |
My Thing has sat in my garage for a year or so. I should have been good about starting it every so often but had boxes and all sorts of stuff around it and never did. I decided to move all the crap out of the way today and see if she would start. I do have a 1/2 tank of gas. The fuel filter (yes in the engine bay but will remove on day and stick outside the engine compartment) is bone dry. I had though the fuel pump would kick in and fill it after a few attempts to start but no luck. No fuel in the clear filter that goes between the fuel pump and carb.
Not sure if the fuel pump is having an issue or what I should check. The engine does turn over and plenty of oil as I did an oil change before I parked her for a year.
So, do I need to remove the filter and try to start without the filter on and put the end of the hose in a bottle until I see gas come from it and then re-connect and see what happens or???
Thanks
tj _________________ tj (the Amishman)
Come visit my web site!
http://www.vwhippie.com
Video Bob Samba Member
Joined: November 03, 2005 Posts: 261 Location: Bishop, GA
Posted: Tue Oct 24, 2006 3:23 pm Post subject: |
Pull the air intake off the carburator and pour in a little gas. After starting, the fuel pump should take over with no problem. _________________ Ya can't have too many Vdubs!
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22 |
Posted: Tue Oct 24, 2006 3:52 pm Post subject: |
Video Bob wrote: |
Pull the air intake off the carburator and pour in a little gas. After starting, the fuel pump should take over with no problem. |
Are you talking about the rubber sleeve that goes over the top of the carb and then goes over to the air cleaner?
Do I just pop that off and poor some gas in the hole? How much gas and any certain spot to pour it in?
I do not want to blow things up here. hehehe
http://www.vwhippie.com |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Tue Oct 24, 2006 4:00 pm Post subject: |
A soda bottle capful should be enough to get her going. You need to loosen the screw on the band clamp slightly to take the rubber air cleaner elbow off of the carb.
Always be cautious when working with gasoline. It can be nasty if spark meets fumes.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Posted: Tue Oct 24, 2006 4:35 pm Post subject: |
markie61 wrote: |
Mark |
After I pout the capfull of gas in the carb, do I put the rubber air cleaner elbow back on before starting the Thing up or leave it off until engine is running and after it has ran for a bit, stick it back on once I turned the engine off?
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Wed Oct 25, 2006 12:05 am Post subject: |
I would use starter fluid. A quick spray at the filter.
A thimble full of gas will work if you are paying attention.
In either case, get it running. Deal with the air cleaners and elbows after it has ran. |
Posted: Wed Oct 25, 2006 9:05 am Post subject: |
OK all. Thanks for the tips. She started. Three capfulls if gas in the carb, one at a time, and the last one she started and continued to run. So, she started! Yeah!
Thanks again,
ztnoo Samba Member
Posted: Wed Oct 25, 2006 10:20 am Post subject: |
tj,
Over in your other thread you just stated something I think gives me a clue about your non starting issue:
Quote: |
I have the Thing lifted on jacks in the rear waiting to finish brake job I started last year |
From my experience the tank works essentially on gravity.
The fuel pump really only has to lift fuel from itself to the carb body.
When the car wheels are on the ground, fuel will flow freely from the metal line coming around the left side of the shroud if it's unhooked.
Test it out sometime.
With the rear jacked up in the air, I would say the level in the rear of the car was higher than the tank, and since the tank is vented, fuel backflowed towards the front of the vehicle and eventually air was introduced into the fuel line probably from the carb venting.
No science here, just speculation on my part.
Posted: Wed Oct 25, 2006 10:26 am Post subject: |
ztnoo wrote: |
tj,
With the rear jacked up on the air, I would say the level in the rear of the car was higher than the tank, and since the tank is vented, fuel backflowed towards the front of the vehicle and eventually air was introduced into the fuel line probably from the carb venting.
No science here, just speculation on my part. |
So the moral is if you ever get the famous VW engine fire where by gravity, gas just keeps pouring on the hot engine, we should build a hydraulic system at the rear tires, like a low-rider can do, and quickly switch the switch so the rear goes like 2 feet up, and then you run to the back and spray the fire retardent on it. That way less gas gets poured all over the engine. hehehehehe
wings_n_fins Samba Member
Joined: May 02, 2006 Posts: 166 Location: Mangilao, Guam USA
Posted: Thu Oct 26, 2006 11:30 pm Post subject: |
... Or run the front end into a ditch. Then you've got water at hand, too! _________________ DAVE
'73 Thing
'07 Harley Sportster
'09 Jeep Wrangler Unlimited |
