pete000 Samba Member
Posted: Thu Oct 26, 2006 9:57 pm Post subject: Vanagon Green Light up Cigar Lighter Surround? |
Just wondering if this lights up? I had my dash off receintly and noticed there is no bulb going to mine. Is this normal? I know there is a socket in the recepticle.
Also where can I source the little bulbs that go in the HVAC Controls. Local auto parts store only has bigger ones... |
ChesterKV Samba Member
Joined: February 07, 2005 Posts: 1725 Location: El Cerrito, CA
Posted: Thu Oct 26, 2006 10:07 pm Post subject: |
Mine is green at night....dunno about sourcing........
good luck |
dkumar1 Samba Member
Posted: Sun Oct 29, 2006 10:22 am Post subject: |
Try NAPA auto parts for a North American green-lighted cigarette lighter socket. Vanagons came originally with European cigarette lighter sockets, which do not hold your 12 volt accessories very well at all.
It's a little tricky to pull the old socket. If you want to try, here's a link to instructions and PICS!
http://www.thesamba.com/vw/forum/viewtopic.php?t=151026 |
Turambar Samba Member
Posted: Sun Oct 29, 2006 10:44 am Post subject: |
My '94 Ford Aerostar has the green lighted ring around the cig. lighter, I assume you could use one of those in a pinch.
T |
r39o Samba Polizei
Posted: Sun Oct 29, 2006 11:29 am Post subject: |
I am told (and have yet to try) the Eurovan one which is supposed to be black inside and work (look) better. Hope you find my pics of use in the other thread.
-Walt _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
erdonline Samba Member
Posted: Mon Oct 30, 2006 9:38 am Post subject: Dash bulbs |
The bulbs for the HVAC controls can be had at GoWesty. There are two varieties and two brighnesses, I believe- black base and white base.
Someone (though I can't remember where) had a nice article on the kinds of bulbs and where they are used, but for the most part, you want the black or white ones from GoWesty.com
Ed in CT |
cheekoman Samba Member
Joined: July 29, 2006 Posts: 346 Location: Burlington, VT
Posted: Mon Oct 30, 2006 11:46 am Post subject: |
mine lit up fine when it was hooked up. Just unhooked it today and did this
r39o Samba Polizei
Posted: Mon Oct 30, 2006 12:02 pm Post subject: |
Cheekoman,
That rocks! Did you buy that or make it? Tell us all about it!
-W _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Oct 30, 2006 12:38 pm Post subject: |
was easy cheesy..... Just posted a reply here.
The cigarette lighter thing was a snap.
I simply boght the 3plug extension thing at walmart. I then unplugged the harness from the back of the lighter. That allowed me to work the lighter free. I then removed the plastic heater vents below dash. I worked harness down through the dash until i could see it. Then, I put the plug that came with the 3outlet thing through the hole for the lighter. I simply hooked up the harness to the old lighter, plug the new one in and electrical taped it. I screwed the 3outlet thingy into the dash with sheetmetal screws. Easy cheesy. Took me about 10min. |
Gauche1968 Samba Member
Posted: Fri Nov 10, 2006 3:39 pm Post subject: HELP! |
So I am replacing the stock lighter with the GoWesty aftermarkt one. I got everything wired up, except the small brown wire (there are 2 brown wires) came disconnected from wherever it goes as I was stripping it. Does anyone know where it goes? I pulled the radio out, but still can't see where it goes.
Thanks, |
URQ Samba Member
Joined: April 12, 2006 Posts: 140 Location: San Diego
Posted: Fri Nov 10, 2006 9:50 pm Post subject: Re: HELP! |
Gauche1968 wrote: |
Thanks, |
Brown is usually your ground |
r39o Samba Polizei
Posted: Sat Nov 11, 2006 2:20 pm Post subject: Re: HELP! |
Gauche1968 wrote: |
Thanks, |
Don't double post!!!!
http://www.thesamba.com/vw/forum/viewtopic.php?t=203697 _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Sat Nov 11, 2006 3:23 pm Post subject: Sorry About that |
missionalan Samba Member
Posted: Fri May 23, 2008 2:58 pm Post subject: Socket |
r39o wrote: |
Cheekoman,
-W |
I got the one with the three sockets in it at Pep Boys. I think it is made by Bell. What I did it cut the original socket from the bus and the socket off the new three pronged socket. I then spliced them together.
Works great! Thanks for the idea. |
