Patmus Samba Member
Joined: October 23, 2005 Posts: 149 Location: Carson City NV
Posted: Sat Oct 28, 2006 11:27 pm Post subject: 73 with Earmuffs? |
Hi Guys,
My 73' Thing has scoops ,which look like the remains of hacked earmuffs, over trapaziod shaped holes where, I guess, the rear louvers are supposed to be. Could it be that my 73' originally had earmuffs or is it more likely that someone hacked out my louvers and attached some sort of aftermarket scoops?
Thanks,
-Pat |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Sun Oct 29, 2006 12:40 am Post subject: |
Several thoughts.
74 steel earmuffs on a 73
aftermarket fiberglass earmuffs on a 73
74 body with a 73 title |
Video Bob Samba Member
Joined: November 03, 2005 Posts: 261 Location: Bishop, GA
Posted: Sun Oct 29, 2006 7:15 am Post subject: |
I bought a 74 Acapulca that had wide fiberglass rear fenders and fiberglass scoops replacing the muffs. It also had a gas heater in addition to std hot air. The scoops were bolted on instead of pop rivets. _________________ Ya can't have too many Vdubs!
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22 |
n0limdon Samba Member
Joined: October 06, 2005 Posts: 192 Location: Cresco, Ia.
Posted: Sun Oct 29, 2006 8:09 am Post subject: |
VideoBob - Your THING sounds like something I would need here in NE Iowa for wintertime driving, gas heater and regular 74 heat. Even then I wonder if I could keep the windshield clear. |
Patmus Samba Member
Posted: Sun Oct 29, 2006 8:28 am Post subject: |
Hi Guys,
Thanks for all of your input so far. Here is more info. The holes covered by the scoops have a wide mesh screen inserted in them to keep debris from entering the engine compartment. Is this stock VW or a clue that my Thing has been hacked? Also, the scoops themselves are made of steel and are attached with sheetmetal screws. The car's history is unknown to me but from what I have been told and seen, the car was at one time completely disassembled (pan off) and may have been Frankenstiened back together. Any subtle clues I should look for to see if my body is really a 74'?
-Pat |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Sun Oct 29, 2006 9:05 am Post subject: |
Patmus wrote: |
Any subtle clues I should look for to see if my body is really a 74'? |
Does the VIN on the chassis tunnel (under the back seat by the shifter coupler access panel) match the VINs on the body (by the front hood latch and on door post in between front and rear driver's side doors?
If they are different, clearly the body and chassis came from two different automobiles. I'll bet the title is for the chassis VIN that they don't match. Generally VINs that begin 183 are 73s and 184 are 74s.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Patmus Samba Member
Posted: Sun Oct 29, 2006 12:47 pm Post subject: |
The Vin# match and they start with 183
-Pat |
Posted: Sun Oct 29, 2006 1:44 pm Post subject: |
Where does the mirrors mount? |
Patmus Samba Member
Posted: Sun Oct 29, 2006 1:57 pm Post subject: |
Hi Ferretkona,
The side view mirrors mount in factory made holes just behind and a bit above the upper hinges of both front doors.
Thanks for your input everyone!
-Pat |
Posted: Sun Oct 29, 2006 6:46 pm Post subject: |
The mirror mounts and the scoops really make me think you have a 74 body. |
Patmus Samba Member
Posted: Sun Oct 29, 2006 8:31 pm Post subject: |
could a late year 73' have some of the features of a 74' ?
-Pat |
suntour Samba Member
Joined: November 25, 2004 Posts: 443 Location: Woodinville, WA
Posted: Mon Oct 30, 2006 1:03 am Post subject: |
I have my doubts you have a 73 body. The mirror mounts and trapezoid holes tell me it is a 74. Does your car have a gas heater or fresh air heat? If you do have a gas heater, do the holes that lead into the passenger cabin look clean and perfectly circular or cut out by a jig saw or hole cutter? Is there a fresh air intake for the heater inside you driver side front wheel well? Do you have a temperature knob for the heater on your left hand side near the latch for your windshield?
If your pan has a vin# 183-blah-blah-blah it isnt a big deal for someone to drill out the body vin# and pop rivet it onto another body.
As far as I know there is not cross-over body stuff when they switched from the 73 to the 74 model. That sort of stuff seemed to have faded away after the 55 beetle. Just out of curiosity, is you Thing a Mexican made or German one? Some of the knock-down kits made in different countries might have a few screwball traits you describe but I doubt you would have one if they even existed. _________________ Order of the Voodoo Spoon |
Posted: Mon Oct 30, 2006 1:45 am Post subject: |
Patmus wrote: |
could a late year 73' have some of the features of a 74' ?-Pat |
Not likely! Time for pictures! |
Patmus Samba Member
Posted: Mon Oct 30, 2006 6:20 pm Post subject: |
Hi Guys, I will try and get some pics togther. Any excuse to show off my Thing! I do indeed have the gas heater ( though not functioning ) with all of the proper switches and knobs. I see no sign of any possible channeling for a heater box style system. My Thing was made in Mexico. I will post pics as soon as I can.
-Pat |
