Tunnel trans into '57 Single Cab...
Goto page Previous  1, 2
i_am_cool_fred
i_am_cool_fred is offline
PostPosted: Wed Aug 05, 2009 6:14 am    Post subject: Reply with quote
my65vert wrote:
I bought my adapter from wolfgang. Cost $42 shipped. I dont think the one you posted will work?
Had to do a little grinding on it so that it would clear the nose cone, it is not just a bolt on and go.
It is solid mount.
after reading this old thread, along with some others that were posted up in another thread, it seems as though i buy that mount from wolfgang (which is ordered Very Happy) do some slight grinding on said mount so it will clear the nose cone, then it's butter correct?
or, based on another thread, i will have to do some "modification" to the nose cone for it to fit. just trying to get my duckies in a row before i rip out a split case in my 58 and run into problems.
oh by the way, hi, i'm brian, just sold my bay and scored a bitchin 58 panel Very Happy
59 mignonette "Lola" see it's build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=495899
Brian Denning, as seen on Gearz TV
James Dwan
James Dwan is offline
PostPosted: Mon Jan 18, 2010 2:44 pm    Post subject: Reply with quote
Hey Brian! As a matter of fact I am researching the same solution. Got a big nut tranny and a 1641 I am putting into an early '59.
Just found out 2 days ago about the solid mount issue. Ironically I was sent here by the TCB!
DAC
TCB
'59 23 Window Deluxe
'73/'77 Westfakia
'78 SuperVert
"Many dreams come true, and some have silver linings.
I live for my dreams and a pocket full of gold. Acapulco gold!" Robert Plant
joescoolcustoms Premium Member
joescoolcustoms is offline
PostPosted: Mon Jan 18, 2010 2:48 pm    Post subject: Reply with quote
I too am having this problem, but will solve it just a bit differently.
I have a April '59 SC with the early mount and it currently has a solid front mount. HATE IT!
I am going to use a beetle nose cone to drop the tranny but at the same time will fab a mount to use the OG rubber mount.
The early bird might get the worm, but the second mouse gets the cheese.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
James Dwan
PostPosted: Mon Jan 18, 2010 2:57 pm    Post subject: Reply with quote
Cool! How soon are you gonna do this? Pics would be awesome Very Happy
DAC
TCB
'73/'77 Westfakia
'78 SuperVert
i_am_cool_fred
PostPosted: Mon Jan 18, 2010 3:36 pm    Post subject: Reply with quote
james it was pretty straight forward
solid mount onto the big nut nose cone and it went right in.
wolfsburgwest is where i got the mount from, it was really easy
edit: the solid mount isn't to bad imho i'v egotten about 150 miles of drive time so far. have no problems
PostPosted: Mon Jan 18, 2010 3:45 pm    Post subject: Reply with quote
I just started. I just removed the rear apron getting ready to pull the engine, then trans.
I will be posting pictures in this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=303792
Actually there are allready some pictures in that thread pertaining to exactly what I am getting ready to do.
mr white
mr white is offline
PostPosted: Mon Jan 18, 2010 10:22 pm    Post subject: Reply with quote
do this on all my buses and trucks,I use Wolfgangs adapter,you have to have the nose cone nose ridge groung down a bit,use a non reverse light bus nosecone. You are going to want to use a 10mm threaded bolt(I believe the thread pitch is 1.5,might be 1.25 though) with a 15mm head on them rather than the usual 17mm head when you mount the trans to the adapter,use blue med loctite. Any good hardware store will have these,I use ones that are 30-35 mm long. The reason for the smaller headed bolt,..Clearance. Dont forget your New body ground strap.
PostPosted: Sat Feb 06, 2010 6:08 pm    Post subject: Reply with quote
Changed mine from the solid rattle trap Wolfgang to the stock style rubber.
GDOG57
GDOG57 is offline
PostPosted: Sat Feb 06, 2010 6:43 pm    Post subject: Reply with quote
Damn! Looks like somebody did a trans drop. Show some more pictures when done.
'57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
dmuis Premium Member
dmuis is offline
PostPosted: Mon Dec 05, 2011 1:46 pm    Post subject: Reply with quote
Best new method is to use one of these from Ken King @ Concept1.
The complete kit comes with adapter, new pre-machined nosecone, and hockey stick! Totally bolt on. All you need is the early rubber mount, available from Wolfsburg West.
Edit Jan 14/2012: Kit now comes with a new powdercoated horseshoe mount as well.
http://store.concept1.ca/store/product/56970/Bus-Nose-Cone-50-59-COMP./
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211301297
BossGuitars
BossGuitars is offline
PostPosted: Fri Jan 06, 2012 11:38 pm    Post subject: Reply with quote
Huge thanks to Ken at Concept1! Used his adapter, nose cone, and horseshoe bracket for my tunnel trans going into my '59 Single Cab.
5?split
5?split is offline
PostPosted: Sat Jan 07, 2012 10:41 am    Post subject: Reply with quote
i installed the same set from wolfgang in my 58 panel using a big nut tranny. it shifted fine sitting on jackstands but as soon as i set it on the ground it will not shift. any ideas what it could be? yes the bus has been lowered 2 clicks in the back. not low at all. please help!
PostPosted: Sat Jan 07, 2012 10:55 am    Post subject: Reply with quote
Sounds like something is shifting once weight is put on it and causing the nose cone to bind slightly pinching the hickey stick. Check the front mount area for something just not right. Also use a floor jack to slightly jack up the front of the trans a very little amout to see if it helps or worsens the problem.
The way these are made, if the lower plate the bolts to the factory mount holes is off a little, it can transfer the weight to the snout of the nose cone and put a ever so slight force on the hockey stick area to cause it to bind. The nose cone is machined to fit the adapter and the machining takes off the cast in factory braces tht brace the hockey tube area.
Page 2 of 2
