47bug Samba Member
Posted: Mon Oct 30, 2006 5:33 pm Post subject: Convertible mirror changes |
Is the rear view mirror for a 55convert any different than for a 57convertable? thanks for your help |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Mon Oct 30, 2006 5:44 pm Post subject: |
Yes it is and a 55 mirror will cost alot more than a 57 |
twinwindows Samba Pimp
Joined: December 08, 2000 Posts: 4086 Location: So.Cal. Highland Park GFK!
Posted: Mon Oct 30, 2006 5:51 pm Post subject: Re: convert mirror changes |
47bug wrote: |
Diff like day and night and mucho bling bling
_________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
vdubinit Samba Member
Joined: July 11, 2005 Posts: 1870 Location: central coast
Posted: Tue Oct 31, 2006 12:24 am Post subject: |
This hear is a 1956 convertible rear view mirror
Hear is the same angle but of my 54 convertible rear view mirror
again 1956 rear view mirror
_________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Tue Oct 31, 2006 12:34 am Post subject: |
I also have a 56 vert rear view mirror that I must dig up. Its unrestored and has that kind of non polished center piece were the hinge point is. The one on my 54 was redone by kochs
anyone have a drivers sunvisor mine is shot _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Not Safari Izzy Samba Member
Joined: February 16, 2004 Posts: 837 Location: Santa Clara, CA
Posted: Tue Oct 31, 2006 12:39 am Post subject: |
Those look pretty similar to me with the exception of the bolt in the pivot mech and the adjusting nut.
I thought that a 1950-1952 vert had a unique mirror, a 1952 through 1957 were almost the same, with the only difference being the 1952-1954 mirror had the single visor setup as standard equip and in 1954 the double visor bar straight across with the mirror attaching arm on the passengers side became standard equip... _________________ DBK Nor Cal
1952 Beetle 11G
1956 Beetle 151 |
Posted: Tue Oct 31, 2006 8:25 pm Post subject: |
izzy wrote: |
I thought that a 1950-1952 vert had a unique mirror, a 1952 through 1957 were almost the same, with the only difference being the 1952-1954 mirror had the single visor setup as standard equip and in 1954 the double visor bar straight across with the mirror attaching arm on the passengers side became standard equip... |
So are you saying that pre 53 convertible rear view mirrors only had one visor??? does anyone have a pic of a 53 mirror _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Tue Oct 31, 2006 9:17 pm Post subject: |
vdubinit wrote: |
izzy wrote: |
So are you saying that pre 53 convertible rear view mirrors only had one visor??? does anyone have a pic of a 53 mirror |
1952 Beetle 11G
1956 Beetle 151 |
Posted: Tue Oct 31, 2006 9:49 pm Post subject: |
I am only 99% positive that a 54-57 are all the same.
Anyone have good pics of a orig 57. |
Posted: Tue Oct 31, 2006 10:51 pm Post subject: |
izzy wrote: |
vdubinit wrote: |
izzy wrote: |
thanks bro that helps alot ,,,,,, it looks like i need to bend my pivot rod back toward an angle to the windshield _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Wed Nov 01, 2006 6:47 pm Post subject: |
I have a '71 Convertible, and it's nearly impossible to see a normal or small car behind the VW using just the stock mirror when top is down. It doesn't matter how tall or short the driver is, can't see over the top (yes, covered by boot). I rigged up an aftermarket mirror and bracket for top-down use just for safety, what have others done? This holds a slightly convex mirror about 5 inches above the top frame, so I can see over the folded-down top. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
47bug Samba Member
Posted: Wed Nov 01, 2006 7:29 pm Post subject: |
Thanks for the info and photos, are you guys sure about the 57 looking like the earlier mirrors, my 57convert came as a basket case in boxes. The mirror that came with it would be like the 58-63 mirrors advertised for sale Is it possible there may have been a mid year change? Also does anybody reproduce the passenger side visor. |
Posted: Wed Nov 01, 2006 7:53 pm Post subject: |
47bug wrote: |
It was a late year change in 1958. Some of the early square window dash verts got the early 54-57 mirror as well, but if you have an oval dash 57 vert then the 58-63 is incorrect. My 1956 vert came with that same 58-63 mirror in it as well and I switched it out for the correct mirror. Since the 58-63 bolts right up and works perfectly, its a way cheaper replacement alternative.
As for repro'ing the passenger side visor, I dont know of anyone that does that. I'm sure a bunch of people wish they did. _________________ DBK Nor Cal
1952 Beetle 11G
1956 Beetle 151 |
Scott Faivre Samba Member
Joined: February 26, 2004 Posts: 368 Location: Las Vegas, NV - USA
Posted: Thu Nov 02, 2006 2:39 pm Post subject: |
izzy wrote: |
vdubinit wrote: |
izzy wrote: |
Izzy,
Where did you find these photos? I know they are linked to here on the samba, but were you the one that uploaded them? Those are some really nice pictures! Just interested where they came
Scott Faivre _________________ 66 Sedan & 64 Convertible
64 Vert Resto Gallery |
Posted: Thu Nov 02, 2006 3:19 pm Post subject: |
They are from "The 1949-1959 VW Beetle" by Bob Wilson..great book, it really goes into detail about the Karmann vert mirror changes. I'm the one who uploaded them. _________________ DBK Nor Cal
1952 Beetle 11G
1956 Beetle 151 |
Posted: Thu Nov 02, 2006 4:25 pm Post subject: |
izzy wrote: |
47bug wrote: |
I wish some one would
I found this photo of a 53 vert interior is this not correct? I always thought that 53 verts also had the passenger visor too
http://www.thesamba.com/vw/forum/album_page.php?pic_id=247056 _________________ **WANTED** ONE 4 1/2 EARLY FUCH |
Posted: Thu Nov 02, 2006 4:48 pm Post subject: |
izzy wrote: |
They are from "The 1949-1959 VW Beetle" by Bob Wilson..great book, it really goes into detail about the Karmann vert mirror changes. I'm the one who uploaded them. |
I'll have to look for that book! Is it still in print/production?
Thanks!
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
