Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Thu May 01, 2014 8:19 am Post subject: |
Looks freakin awesome |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Thu May 01, 2014 10:00 am Post subject: |
type3nut64 wrote: |
Did some more work this past weekend. Headlights in you can see that smile behind the towel rails. Here is Leroy.
Looks good. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
type3nut64 Samba Member
Joined: September 25, 2000 Posts: 347 Location: Yucaipa Ca.
Posted: Thu May 08, 2014 11:00 am Post subject: |
Erik G wrote: |
type3nut64 wrote: |
The part that goes from the stainless housing to the part that bolts to the door has pitting as well. I would have to get the glass out to pull it apart. I will get it all together and revisit some items that need rechroming. unless someone out there is willing to let go a really nice cat eye and i can send them this one and something else to make it worth there while. I dout that will happen since they rarely come up for sale. It took me many years (of casual looking) to find mine. |
That's what I was saying, it's the same as a regular early mirror, maybe I wasnt clear enough. I'll find some pics. I was pissed when mine was broken, but much relieved that I could scavenge parts off a regular mirror |
Thanks Erik G.
Erik G Samba Member
Posted: Thu May 08, 2014 12:41 pm Post subject: |
type3nut64 wrote: |
Erik G wrote: |
type3nut64 wrote: |
Thanks Erik G.
Sweet! now you know what I meant. Looks way better |
Posted: Thu May 08, 2014 2:47 pm Post subject: |
yep but i broke the glass! i didnt let it cook long enough i guess. Luckaly its a clean break in 2 pcs so I can take it to glass shop and have one cut. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Thu May 08, 2014 3:43 pm Post subject: |
type3nut64 wrote: |
Order a few, asmany of us have broken mirrors on a few cat eyes. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Posted: Fri Jun 13, 2014 8:17 am Post subject: |
ok moving forward and tried to put the back window multiple times and this is the best it has come out. what am I doing wrong. Th echrome doesnt lay flat. the rubber isnt going to corners and it seems loose. never used the chrome molding rubber before and read many forums but aarrrgghh this sucks!
Erik G Samba Member
Posted: Fri Jun 13, 2014 8:24 am Post subject: |
I'm almost positive Tram has complained the same problem with the early cars |
Posted: Fri Jun 13, 2014 9:26 am Post subject: |
Let me guess, this is ISP West seals and trim? If so, do a search of Woreign's thread about his Notch, as he was having trouble installing his as well. I think Anthony replied to that thread, explaining how it's supposed to go together (they didn't send any instructions). And YES, Tram was having trouble installing it as well. You might need to tape the trim in the slot, before you install the window assembly. It helped doing that, when I/we did my T-34 rubber seals.
Erik, if you look at his pics, he's using the later "thin style" trim. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Jun 13, 2014 10:43 am Post subject: |
Bobnotch wrote: |
Erik, if you look at his pics, he's using the later "thin style" trim. |
Yes, but it isn't an ISP exclusive problem- it's every Type 3 seal out there. The seals aren't quite as wide as original as you'll see by the OE seal lines on the glass. The ISP guys seem to have a system down, though, so it really would be great if they'd lay out exactly what they do to get theirs to fit right. Be aware that to get them to SEAL once they are in, you're going to have to go all under them with flowable silicone window sealer on the outsides or they WILL leak, even if they appear to seal flush. If one doesn't leak this week, it will next week.
You need to tape the trim into the seal with painter's tape before installing the glass, then, I usually use a thin electrical wire wrapped in the seal TWICE around for a thorough installation. The twice around trick is something that I actually learned from the Disciple- it's one of those "DUH! Why didn't I think of that!" things that's really a best practice... if things don't seat quite right the first time, you have a built in re-do- and where headlining or other coverings are involved in the edges, your second pass with the wire and the glass installed allows you to tuck the material in neatly.
The "installer error" thing that parts suppliers like to throw around doesn't sit with me- I'm installing probably five times as much Mercedes glass as VW easily... and most are on W111 Coupes/ Convertibles, W111 sedans/ W108 sedans, and W113 "Pagoda" SLs with very unforgiving trim and complex curves like this:
You'd think a little old Type 3 would be a walk in the park on a glass install beside this- but exactly the opposite is true- and it's 100% due to the seal quality. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Jun 13, 2014 11:21 am Post subject: |
Tram wrote: |
Bobnotch wrote: |
You need to tape the trim into the seal with painter's tape before installing the glass, then, I usually use a thin electrical wire wrapped in the seal TWICE around for a thorough installation. The twice around trick is something that I actually learned from the Disciple- it's one of those "DUH! Why didn't I think of that!" things that's really a best practice... if things don't seat quite right the first time, you have a built in re-do- and where headlining or other coverings are involved in the edges, your second pass with the wire and the glass installed allows you to tuck the material in neatly. |
I'll add in that here's Woreign's thread link (I did a quick search for it).
http://www.thesamba.com/vw/forum/viewtopic.php?t=577444&highlight=window+trim+install
He did finally get it to go in, but it was a bunch of work I don't think he planned on. On page 5 of that thread, is the install instructions from VW, but their seal is slightly different from the 1 you're using. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Jun 13, 2014 11:40 am Post subject: |
thanks for all the replies and i was reading the entire thread again while the repies were coming out.
the chrome isnt comeing out of the rubber it stands off the rubber like one person said the the other thread. He used a block of wood to flatten it out?! This rubber just doesnt seem to go to the corners for being molded rubber. I had read the other thred before and thats what made me buy all new molded rubber. I think its the chrome. its just not curved right. like taking a revered U and trying to bend it around corners at an angle doesnt work.
I just doent want to destroy the chrome by beating it with a block of wood. I guess I will keep trying.
I will say the best rubber i found was bug pack cal look rubber. had the most coverage than anything else out there. Havnet seen it in years though. |
Shaven Samba Member
Joined: September 17, 2006 Posts: 879 Location: Australia
Posted: Sun Jun 15, 2014 10:57 pm Post subject: |
thats... very very fookin sexy!!! _________________ the dc baggin is because its a well known fact that a restored sc will never be worth anywhere near what even a shitbox dc is |
Posted: Mon Jun 16, 2014 9:11 am Post subject: |
fathers day wash and cruise around the block.
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Jun 16, 2014 9:46 am Post subject: |
I put in a new windshield and seal in May, and I found I had to use a 12 oz. rubber mallet to fine-tune the fit of the trim before I put the windshield in the car:
The trim didn't want to lay totally flat all the way around, no matter what else I did. This was with ISP West seal and trim. It wasn't a big deal, though...I didn't have to use tape at all during installation. Also a tip I picked up from Woreign's thread, was to start the trim into the corners first and then work out from there.
If you haven't already, you might try spraying the window frame with soapy water so that the seal will slide all the way down in there before you pull the cord on installation. _________________ 71 Elm Green FI A/T Squareback |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Mon Jun 16, 2014 10:06 am Post subject: |
man that is a nice looking car |
Posted: Mon Jun 16, 2014 10:20 am Post subject: |
i left the rear window in and the rubber is laying better now. still not perfect or how i would like it. I will try and use some sort of mallet or block of wood to ge the trim to lay better. I have few odds and ends to put on but hopefully will send to the interior shop soon. next week or so.
it does look better washed. it was getting a bit of dust build up. driving it around the block was cool. it hasnt seen the street in long time and some of my nieghbors were coming out to look at it after i got back and parked in the driveway. got me a little motivated again. |
Posted: Mon Jun 16, 2014 10:40 am Post subject: |
I know you don't want to, but it might be easier to take the window back out and get the trim fitting right first. _________________ 71 Elm Green FI A/T Squareback |
Posted: Mon Jun 16, 2014 10:59 am Post subject: |
Donnie strickland wrote: |
I know you don't want to, but it might be easier to take the window back out and get the trim fitting right first. |
Haha damn right I dont. But we will see how it goes. If its not easy I will pull it out just to protect the paint. |
