Brian Samba Moderator
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
alex77 Samba Member
Joined: November 08, 2006 Posts: 346 Location: Tijuana
Posted: Mon Nov 10, 2014 8:04 pm Post subject: |
Great post.
A lot of usefull info.
Im building a tranny for street/off road baja
The RGB's would be mainly for lift.
Do any of you guys have run a setup like these one.
1st gear 3.78
2nd gear 2.06
3rd gear 1.26
4th gear .82
R&P 3.88
RGB 1.26
Tires 235/75/15
Want to run the 3.88 to 1 R&P
To see if it reduces torrque at the wheels to make the wheel hop less.
Also just tryint to figure out if anyone has doneany rear brake update on the RGB's
Cause i want to run rear vanagon self adjusting brakes or any other setup that could be retrofited. _________________ 91 mexibeetle |
Posted: Mon Nov 10, 2014 8:33 pm Post subject: |
brettsvw wrote: |
Great find Joe. I have been searching for a set of Brazilian baywindow RGB's
for awhile now. |
That's a brilliant find. I want a swing axle car to do this too. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
alex77 Samba Member
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Tue Sep 13, 2016 5:46 am Post subject: Re: Ultimate redux swap thread |
Looking to install RGB in a tub buggy.
I have a Type I and Bus rear torsion housing and like the simple solution from Ian http://www.thesamba.com/vw/forum/viewtopic.php?t=538730
The Bus Torsion is 3" wider (44 1/2") than the Beetle. The bus plates are both thicker (0.2" vs 0.155") and taller (or wider) than the Beetle.
Would the added beef from the bus arms reduce or eliminate the need for a no hop kit?
I have also read about adding brittleness to the spring plates from welding, any thoughts?
Thank you, Jeff[img][/img][img][/img] _________________ If I knew what I was doing; I wouldn't be building a buggy!
joescoolcustoms Samba Member
Posted: Tue Sep 13, 2016 8:33 am Post subject: Re: Ultimate redux swap thread |
The Wheel hop is because of the orientation of the gears being lined up vertically. Bus or Beetle will wheel hop unless a different geometry is established, like a no hope kit or laying them down in a horizontal position.
The only advantage of using the bus torsion housing is the spring plates are already set up for it, and you will use the thicker/stronger spring plates.
For welding spring plates, all that is needed is a reversal treatment. Heat up and slow the cooling to get the metal back to being flexible. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
oldschool5er Samba Member
Posted: Tue Sep 13, 2016 8:56 am Post subject: Re: Ultimate redux swap thread |
In restricted Score racing before after market spring plates were allowed, we were doubling up stock spring plates and welding the additional plate at the hub only full circle and welded the back edges just even with the hub. The donuts had to be modified for the extra wide blades. I am not sure what would happen if you actually fully welded the two together. The theory at the time was to still allow flexibility (or to keep iit looking stock under tech inspection) . I do know we went from breaking and fracturing stock springplates to never having the issue again. They lasted multiple B1k and 500k Baja races with no issues. Were transferred to a recreational Baja and lasted another 20 years. _________________ HRE in Westerville,Ohio
Full machine shop with all types of CNC. Rapid prototyping available, CNC Plasma cutting, 3D printing and Laser engraving. |
Posted: Tue Sep 13, 2016 9:36 am Post subject: Re: Ultimate redux swap thread |
JoeCool,
The alignment of the gears and the fact that the torque is being applied off axis of the plates and tubes is the likely culprit of the hopping. This is why the laydown kits have less issues with hopping.
I am thinking the wheel hop is due to flexing of spring arms in the lateral direction causing the spring arm to bow (and increased toe-in). This bowing reaches a maximum and flexes back and forth giving rise to hopping.
The JJ No Hop kit prevents this by adding a second link to prevent the hopping and associated toe-in.
OldSchool,
Thanks for the input, I was worried about the change in plate properties from welding. _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Tue Sep 13, 2016 9:52 am Post subject: Re: Ultimate redux swap thread |
The buses that have the RGB's wheel hop like crazy. It is the climbing that the gears in the vertical position create. It is not a spring plate position issue. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Sep 13, 2016 9:59 am Post subject: Re: Ultimate redux swap thread |
JoeCool,
That is interesting, I had never read about the issue in busses (but I have never owned one either).
I will think about this.
How has the no hop kit worked? Have you had a chance to work it out?
Thanks, Jeff _________________ If I knew what I was doing; I wouldn't be building a buggy! |
Posted: Tue Sep 13, 2016 10:51 am Post subject: Re: Ultimate redux swap thread |
The top gear rotates backward, or like it was in reverse. Which it trys to wrap itself around the lower gear when the tire is in contact with the pavement. It creates a awkward movement on the gear box. Most buses with RGB's have low powered engines compared to their weight. They will only hop when spinning or going up gravel roads.
I put a larger engine in my '59 SCab and it hopped like a madman when power was applied. They will hop so violent under increased power, it will actually split the transaxle case into two pieces like this one did on a bus owner who ran his off road a lot.
I did not finish the Oval Baja, but sold the body 1 1/2 weeks ago to a fellow in Dayton Ohio who wanted the body to build a Pro Mod Drag Car with. I still have the completed chassis and will be putting a Sand Flea Truggy on it this winter. I did build another transaxle for it that has a 3.88 Ring and Pinion with a 0.82 welded 4th gear. This will allow me to run 70 MPH with a 31 inch tall rear tire at 3150 RPM. The Sand Flea has heat, so it will be my Winter buggy.
thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Wed Sep 14, 2016 6:40 am Post subject: Re: Ultimate redux swap thread |
I have reduction boxes on my Baja Bug. I've had them mounted upright and laydown style.
Wheel hop is more severe in the upright position. It still exists in the laydown position, but is not as extreme. _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
Posted: Wed Sep 14, 2016 7:03 am Post subject: Re: Ultimate redux swap thread |
TheFladge,
Do you still have the buggy with the GRB?
I looked at your picture gallery and it appears that you used the stock (and improved sway away) spring plates.
Is this the JJ laydown kit? What is the thickness of the offset? ~1 1/2"
Posted: Thu Sep 15, 2016 8:09 pm Post subject: Re: Ultimate redux swap thread |
Yes I do. It has Sway-A-Way spring plates and torsion bars.
It's a vintage John Johnson laydown kit. I fabricated the shock mounts and the brace bars for the axle tubes. _________________ 1957 Vintage Baja Bug.
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
alex77 Samba Member
Posted: Thu Dec 29, 2016 12:15 am Post subject: Re: Ultimate redux swap thread |
Bringing this back from the dead.
I have a 94 mexiveetle bj/swing axle
And already have front end with adjusters and type181 spindles.
Also the ring and pinion are flipped and have everything except the rear brake drums for the large nut rgb.
So my million dollar question is:
Have any of you guys ever used al late model bay bus drums and hubs on the large nut rgb or even use self adjusting rear brakes.
I could imagine that its compatible with some slight modification. _________________ 91 mexibeetle |
syncrogreg Samba Member
Joined: November 08, 2009 Posts: 742 Location: USA (Nashville TN)
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
Posted: Sun Jul 30, 2017 12:48 pm Post subject: Re: Ultimate redux swap thread |
Been collecting parts for a lifted stock sedan bug for a few years. Scored a -56 splitbus transmission that had been modified and fitted into a splitbug way back in late 50's...
Full project can be seen here in the Readers rides section. Wife's -66
Long story short, I swapped the driveaxles into a type-1 transmission and flipped the ring gear.
As the original shockmounts had been cut of by original builder 50 years ago I made a jig from type-1 axletubes so I could get the lower mount as close to original as possible..
_________________ ~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD |
Babyblue60 Samba Member
Joined: April 18, 2012 Posts: 49 Location: Puyallup,wa
Posted: Thu Aug 03, 2017 8:25 am Post subject: Re: Ultimate redux swap thread |
Does anyone know the spacer thickness between the adapter and spring plate? |
