junichi Samba Member
Joined: September 12, 2005 Posts: 749 Location: brentwood bay, bc
Posted: Thu Jan 30, 2014 5:53 pm Post subject: 15x7 |
I guess I can still hope that they turn out to be 15x7 then...
I still don't understand all this, but I am glad there is somebody that does. Thanks again, Chris.
EDIT: the wheels turned out to be 15x 6 so i didn't buy them. Once i add sandblasting and powder coat, spacers, lugs, i may as well buy new ones.. _________________ 1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf |
KDI_CUSTOMS Samba Member
Joined: November 07, 2009 Posts: 91 Location: Maryland
Posted: Fri Jan 31, 2014 6:37 pm Post subject: |
Would there be any fitment issues with 17x7.5 et32 & 17x8 et37? Had someone offer me a set as payment for work. _________________ KDI CUSTOMS AUTOMOTIVE UPHOLSTERY
www.kdicustoms.com
Full interior services and sales of rare imported material. |
Posted: Sat Feb 01, 2014 8:53 am Post subject: |
KDI_CUSTOMS wrote: |
Would there be any fitment issues with 17x7.5 et32 & 17x8 et37? Had someone offer me a set as payment for work. |
Judging simply by the widths and offsets (ignoring any possible issues that could arise from the centerbore diameter, center cap fitment issues, lug and stud fitment issues), those wheels could be bolted on without the use of spacers. However, in order to achieve the best look, I would recommend running rear spacers to push the rears outward a bit. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
mrshrimp Samba Member
Posted: Wed Feb 05, 2014 1:10 pm Post subject: |
Is there a big break kit that fit 15" Rhein south african rims?
-Keith |
syncroluvr Samba Member
Joined: October 11, 2010 Posts: 200 Location: Trois Rivieres,QC
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
OMcComis Samba Member
Joined: December 22, 2013 Posts: 46 Location: United States
Posted: Fri Feb 21, 2014 3:08 pm Post subject: Vanagon Wheel Adapters rim size |
These are Chrysler Pacifica Rims with 1.25 spacer/adapters. First let me say that I did not set out to put 19" rims on my Vanagon. I started looking for 16" like GoWesty article recommends. After pricing a few sets from the local shops, I ran across this kid that assured me these would be fine, just remeasure and redrill the lug holes and you sure couldn't beat the price. Now I can't attest to the state of my unhighness at the time........but when I got home, I was the proud owner of a set of 19" rims and tires for 300 dollars. A month or two later and with the help of a custom shop in California, 180.00, new tires: 400.00, I'm quite pleased with the result. The tires are 245/40.
Neptuno Samba Member
Joined: March 23, 2004 Posts: 141 Location: DelCo, PA
Posted: Tue Feb 25, 2014 9:20 pm Post subject: |
I wondered if anyone has seen these before. The seller does not know the bolt pattern but I have this information from the back of the wheel per a picture sent to me 7jx16h2. So I know they are 7 wide and 16
In diameter.
No et that he knew but a 447 stamped in back
As well as a backward k followed by a 17
He bought them for his Volvo but did not fit. Do I guess that rules
These out as 5x108's
I keep finding out information. These are called Sport Edition Fox 5's
new pics for reference:
_________________ Lonely Vanagon running up and down Delco
joetiger wrote: |
Also, if you look closely, the drapes in the house match the Vanagon, illustrating outstanding thematic continuity. |
Posted: Thu Feb 27, 2014 1:33 pm Post subject: |
Anyone? _________________ Lonely Vanagon running up and down Delco
joetiger wrote: |
Posted: Thu Feb 27, 2014 1:47 pm Post subject: |
Neptuno -
As you stated, the wheel are 16x7. The H2 is the shape of the lip that holds the tire to the rim (not really important information to know). We still don't know the bolt pattern or the offset though. The 47 that is cast into the wheel could be the offset, but I highly doubt it. Most generic wheels like those usually have the bolt pattern stamped into the wheel somewhere, not cast in like you showed. This is because they use the same casting for each bolt pattern, but then they machine it to fit various applications within that bolt pattern. I would scrub the inside of the wheel nice and clean to see if you can spot this stamping. Otherwise, if you want to measure the overall width of the wheel EXACTLY ad then measure from the wheel/hub mating surface out to the inside edge of the wheel rim (using a straight edge across it), then I can tell you the offset.
The bolt pattern is usually not included in the information on the wheel. You can measure this by measuring between the lug holes. Start in the exact center of one lug hole, skip one hole and measure to the exact center of the next hole. Then add 5.5mm. This will give you the bolt pattern. You have to measure this exactly because the difference between 5x114.3 and 5x112 isn't much and it would be easy to mistake the two if the measurements aren't done carefully. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
euro911 Samba Member
Joined: May 20, 2007 Posts: 162 Location: So. Cal, So. Bay
Posted: Thu Feb 27, 2014 3:28 pm Post subject: |
I was having dinner with some old high school buds last night and raised the subject of Mercedes wheels for my Westy.
One friend said Mercedes wheels had the same bolt pattern as Chevrolet 5-lug wheels, at least older Chevys. I'll have to check this out.
??? _________________ Mark S.,
So. Cal, So. Bay
'70 Karmann Ghia Coupe
'84 Vanagon Westfalia Camper ("Eileen") |
Posted: Thu Feb 27, 2014 3:32 pm Post subject: |
euro911 wrote: |
Your friend owes you dinner! Five lug Chevy's were either 5x100, 5x5 (127mm) or 5x4.75 (120.65mm). The Vanagon is 5x112. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sat Mar 01, 2014 10:57 am Post subject: |
I'll be sure to let him know _________________ Mark S.,
So. Cal, So. Bay
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Tue Mar 04, 2014 2:44 am Post subject: Ronal rims from Audi 5000 |
Picked these up thanks to some advice from T3 (thx Chris!), Ronal 15x6 rims off of an Audi 5000 (last install):
Not my pic, but picture is about accurate Need to do the center-bore, and voila - will use as winter rims+tires on my 2WD full westy. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Mar 04, 2014 1:10 pm Post subject: Re: Ronal rims from Audi 5000 |
luVWagn wrote: |
Not my pic, but picture is about accurate Need to do the center-bore, and voila - will use as winter rims+tires on my 2WD full westy. |
I don't think so, Tim... those are four bolt wheels! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Tue Mar 04, 2014 2:17 pm Post subject: Re: Ronal rims from Audi 5000 |
Jake de Villiers wrote: |
luVWagn wrote: |
I don't think so, Tim... those are four bolt wheels! |
Sorry, stole the wrong pic Yes, the ones I got are 5x112, this is the only picture that looked similar enough. ***EDIT: Corrected***
Brian. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Fri Mar 07, 2014 5:29 am Post subject: |
Wheel cool:
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Sat Mar 08, 2014 6:08 am Post subject: |
Nice! Are those T3technique center caps?
Just gotta scrape off the old wheel weight residue _________________ 91 CARAT |
Posted: Sun Mar 09, 2014 7:51 am Post subject: |
SteveVanB wrote: |
Just gotta scrape off the old wheel weight residue |
I got those a long time ago from a Vanagon list member who was prototyping some. Chris from T3Technique machined them down to clearance grease caps.
I love those wheels - lightweight and strong! With 215/65 tires the combination is 6lbs per wheel lighter than stock steelies with 195R14 Kumho RA08. I'm now running 225/60 16 tires. |
djsixbillion Samba Member
Joined: January 15, 2013 Posts: 71 Location: Sacramento, CA
Posted: Sun Mar 09, 2014 4:15 pm Post subject: |
I've searched, and apologize if this info is floating out there already, but I couldn't find it.
Can someone point me to a good, cheap 15x7 or 15x6.5 wheel (steel preferably) that will work as a spare for my Syncro? I've got a set of four South African Carat 2 wheels that will be going on soon with 215/75-15 Yokohama's, and would like to have a size-matching spare. Don't really care about the appearance, just as long as it fits well with minimal modification.
Looks like Van-Cafe is out of stock on the Mefro wheels, and Gowesty doesn't seem to have them anymore? If it matters, I'm also planning on a big brake kit down the road, and have read that some of the 15" steelies interfere. _________________ 1990 Syncro Westy 1.8T
1996 Land Cruiser - Locked/Supercharged/Intercooled - RIP! |
