ecsnsmb Samba Member
Joined: June 30, 2014 Posts: 11 Location: United States
Posted: Fri Jan 16, 2015 9:14 am Post subject: |
I have a line on some nice Mercedes CLK wheels, 16x7 et37 that have been drilled to fit 13mm lugs and used on a Vanagon. If I am reading it right, I need 8mm spacers all around to fit them on my stock 2wd Vanagon? Thanks for your time everyone! |
cmarino929 Samba Member
Joined: August 16, 2009 Posts: 257 Location: Central NJ
Posted: Tue Jan 20, 2015 7:24 am Post subject: |
Anyone know what wheel/tire combo this could be? Would this be too much for an aircooled van?
steve_hoge Samba Member
Joined: October 22, 2009 Posts: 42 Location: Boulder CO
Posted: Tue Jan 20, 2015 9:09 am Post subject: |
cmarino929 wrote: |
Anyone know what wheel/tire combo this could be? Would this be too much for an aircooled van? |
BFG's on 15" steelies?
But what really popped out at me in this pic is that rear window with the inset slider - too cool! Wonder where it was taken? |
Posted: Tue Jan 20, 2015 9:34 am Post subject: |
steve_hoge wrote: |
cmarino929 wrote: |
Is that wheel setup is too much for an aicooled engine? Even if the engine is tuned and in tip top shape? |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jan 20, 2015 11:25 am Post subject: |
cmarino929 wrote: |
Is that wheel setup is too much for an air cooled engine? Even if the engine is tuned and in tip top shape? |
I don't think you have nearly enough power to run those, especially with the 4.57 R&P in the stock air cooled transaxle.
They look cool, though! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
nydubber Samba Member
Joined: December 08, 2014 Posts: 2 Location: Richmond, VA - United States
Posted: Tue Jan 20, 2015 1:39 pm Post subject: |
1990 Vanagon GL - was wondering about specs in general. New to Vanagons and running them on my mkii GTI is a completely different ball game than on the Van.
MSR style 228 and 229 - here is the spec sheet for the 228 and 229, they DO come in 5 lug and have a load rating of 1400
228
229
Posted: Tue Jan 20, 2015 1:44 pm Post subject: |
cmarino929 wrote: |
steve_hoge wrote: |
cmarino929 wrote: |
Like the others have said, that exact combination isn't going to perform well on a your aircooled, but remember that you could still run 15" or 16" steel wheels as long as you keep the diameter of the tires to a reasonable size. In other words, you could run those exact same wheels if the tires were not quite that tall. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Jan 20, 2015 1:48 pm Post subject: |
nydubber wrote: |
Great looking wheels, but I don't see that they are available in 5x112 to match the Vanagon's bolt pattern. In addition, the offsets listed are kind of questionable for use on a Vanagon. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Tue Jan 20, 2015 2:01 pm Post subject: |
Christopher Schimke wrote: |
cmarino929 wrote: |
steve_hoge wrote: |
cmarino929 wrote: |
Like the others have said, that exact combination isn't going to perform well on a your aircooled, but remember that you could still run 15" or 16" steel wheels as long as you keep the diameter of the tires to a reasonable size. In other words, you could run those exact same wheels if the tires were not quite that tall. |
Awesome, thank you both for that info. I figured it would turn my westy into more of a slug than it is so i will prob stick to getting the bfg ta's on my 14" stock steel wheels. |
Posted: Tue Jan 20, 2015 2:14 pm Post subject: |
Great looking wheels, but I don't see that they are available in 5x112 to match the Vanagon's bolt pattern. In addition, the offsets listed are kind of questionable for use on a Vanagon. |
I was going to run the smallest possible spacer/adapter combo to offset that and take it into consideration with the ET (if at all possible). I know some people shudder at the thought of spacers of any sort, but I've never had any issues so long as they are high quality and installed properly.
Thanks for the quick reply. |
Posted: Tue Jan 20, 2015 3:57 pm Post subject: |
nydubber wrote: |
The problem that you will run into is that say you choose a 15x7 ET20 in a 5x4.5 bolt pattern. The thinnest adapters that I can make are 15mm. That gives you a final offset of 5mm. You could run narrow (stretched) tires, but the package will still poke out of the fender openings and the sliding door will not open all the way.
If you were going to run a set of adapters, you are better off choosing a wheel that has a higher offset, like ET45, so that there is room for the adapter thickness without moving the wheels too far outboard. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Wed Jan 21, 2015 12:31 am Post subject: |
nydubber wrote: |
If you were going to run a set of adapters, you are better off choosing a wheel that has a higher offset, like ET45, so that there is room for the adapter thickness without moving the wheels too far outboard. |
And the wheels' max load is still too low... _________________ '84 Vanagon GL 1.9 WBX
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Sun Jan 25, 2015 9:49 pm Post subject: |
I picked up those wheels today at Burning Van.
they are 16" and it says on it Ronal 13/10/00. The seller stated that they are 5x112.
I test fit one and they won't fit as is - the holes need to be enlarged and I would need longer studs front and rear (on a 2WD).
It says Ronal on it but could someone confirm that those are R28s? I thought that I read earlier in this thread that Ronal R28 fits as-is…that's not case.
Also does anyone know where i can find center caps for those?
thank you!
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Mon Jan 26, 2015 9:18 am Post subject: |
I have put those stock Mercedes wheels on a couple vans. 5 x 112mm, ET37
I am using 215/65/16 XL tires. No spacers, slight clearancing of upper arms for 2wd.
Mine are drilled and countersunk so stock lugs and nuts fit.
Mark |
Posted: Mon Jan 26, 2015 10:12 am Post subject: |
Mark
Thanks for the answer - could you elaborate on the countersunk part? I like the idea of being able to use the stock lugs but I am not sure I understand how to achieve that as there was no thread left at all on the back when I test fit one that had had the holes enlarged
Thank you in advance |
Posted: Mon Jan 26, 2015 11:23 am Post subject: |
If you look at closely at a stock 14" alloy the lug holes are drilled deep with a 60 degree counter sink. Use a counter sink bit to drill the lug holes of the Mercedes alloys to match the same thickness and angle as the stock 14" alloys. Then the stock studs will stick through the same as they do with stock alloys and the stock nuts will fit the same as they did with the stock alloys.
Mark |
bluefirefly Samba Member
Joined: March 16, 2011 Posts: 438 Location: Calgary, Ab
Posted: Mon Jan 26, 2015 12:49 pm Post subject: |
crazyvwvanman wrote: |
Mark |
Looks really nice! _________________ 86 Syncro Tintop G60
work in progress ...as always! |
Posted: Mon Jan 26, 2015 3:37 pm Post subject: |
thanks Mark for the additional information. I guess I would just need to find the proper bit now.
I also received more info from Christophe this morning who suggested to use spacers.
I did another test at lunch today. One of the 4 wheels had already been drilled by the previous owner so I was able to mount it.
The clearance in the front is really tight. I am not 100% certain that it would fit when there is a tire on the wheel.
They do appear to come from a 2001-2003 Mercedes CLK so that may help finding a center cap, although I would prefer to find one that does not have the Benz logo. |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Mon Jan 26, 2015 5:13 pm Post subject: |
SyncroChrick wrote: |
The clearance in the front is really tight. I am not 100% certain that it would fit when there is a tire on the wheel. |
Double check the wheel widths. I have a set of similar wheels that I picked up to put on my Vanagon and they are a staggered set...the rear wheels are wider. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
Posted: Wed Jan 28, 2015 4:48 pm Post subject: |
That is why I mentioned slight clearancing of the upper arms.
Mark
.....The clearance in the front is really tight. I am not 100% certain that it would fit when there is a tire on the wheel..... |
