Posted: Fri Nov 13, 2015 7:36 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
iraniancowboy wrote: |
The mercedes wheels stamp On the backside is #1244001802, and 6.5Jx15 H2 and the offset 5.25
Will they work? |
In order to run those wheels, you will need spacers front and rear, new front lug bolts, new rear wheel studs and new rear lug nuts. You will also need to drill the lug holes out to 37/64”. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
cypor Samba Member
Posted: Wed Dec 02, 2015 9:05 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Hi, i want to buy a set of alloy for my T3 Magnum and im unsure wich one to chose. I like AZEV A look on t3 but also mercedes rims.
i found a set mercedes for sale
8j
17
et35
And im not sure if it will fit. I did find tho' different charts, in one i did find same dimensions and they say i need 10 mm adapters and 20 mm on the rear wheels. Is it correct?
Im going for this look.
https://www.facebook.com/vw.t3.ro/photos/a.5253423...mp;theater
Any advice? TY |
Posted: Wed Dec 02, 2015 9:26 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
cypor, for those particular wheels, I would run 5mm front spacers and I would modify the tip of the front upper control arms slightly for a bit more clearance. For the rear, I would run 10mm spacers. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
cypor Samba Member
Posted: Wed Dec 02, 2015 10:09 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Many thank's for the prompt advice. |
pantone149 Samba Member
Joined: August 19, 2004 Posts: 1018 Location: Mt. Shasta
Posted: Wed Dec 02, 2015 5:30 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
This may have been answered before but I can't find anything. Alloy wheels from a 2014 Jetta 1.8 SE. 16 x 6, ET 50. 5x112 pattern. I'm fairly sure the bolts are 14mm. Any idea what I need to make these fit? |
Posted: Wed Dec 02, 2015 5:41 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
oops. Not a synchro. In fact it's a 73 bay window. |
Posted: Wed Dec 02, 2015 5:44 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
pantone149 wrote: |
On a Bus, I would recommend opening up the center bores of the wheels to 66.56mm, custom spacers front and rear, longer studs front and rear and a full set of small ball seat lug nuts. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
igarrett Samba Member
Posted: Thu Dec 03, 2015 3:40 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks everyone for all the great info on this thread. I couldn't find (maybe missed it) info on what I am trying to do.
I wanted to see if these wheels Mercedes 16x7.5, 5x112, et51
Here is link to Wheels
http://www.thesamba.com/vw/classifieds/detail.php?id=1716736
I have a 1985 Westfalia Weekender currently 14" stock. But I just put in a 2.2 subie and want to upgrade the wheels too.
Thanks
[img]https://www.thesamba.com/vw/gallery/pix/[/img]
Posted: Thu Dec 03, 2015 4:02 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
igarrett wrote: |
Hello,
You have two different options for mounting those wheels: Spacers, studs and new lugs or a set of bolt-on spacers and lugs. Either way works great. Depending on the part number of the wheels, you may or may not need to drill the lug holes. It just depends on which car and year they came from. The part number would tell me though. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Fri Dec 04, 2015 10:21 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks
Here is the part number
A1404001402
Let me know what you think and also where I could buy it as well.
Much thanks!!! |
Posted: Mon Dec 07, 2015 8:10 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
igarrett wrote: |
Thanks
Here is the part number A1404001402
Those wheels will require small ball seat lugs. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
cypor Samba Member
Posted: Tue Dec 08, 2015 12:36 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Christopher Schimke wrote: |
cypor, for those particular wheels, I would run 5mm front spacers and I would modify the tip of the front upper control arms slightly for a bit more clearance. For the rear, I would run 10mm spacers. |
So i bought those rims, and i wonder what lowering springs to use -40 -45 to obtain this look?
Maybe not so low in front, i need the cars for a bit of "soft-offroad".
And what tires should i use on that particular rims to be in between comfort and look?
Ty |
cypor Samba Member
Posted: Thu Dec 10, 2015 7:08 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Front no spacers yet, close call...i think im gonna go with 5mm i will need longer bolts tho.
Rear: i think i will need abit longer studs i forgot to check if not those two 10mm headed bolt on the drum are keeping the to not stay flat on the drums.
Shall i still go with 10 mm spacers here in the rear axle?
Sry for the large photos. |
Posted: Thu Dec 10, 2015 7:43 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
cypor wrote: |
Don't forget that the tip of the upper control arm swings upward toward the tire as the suspension compresses, so just because a wheel will bolt on doesn't mean that you will necessarily have enough clearance one the tire is installed and the suspension position is back at ride height.
I would definitely suggest 10mm spacers on the rear. They will improve the aesthetics greatly. If you want to tell me the thickness of the wheels as measured from the base/bottom of the lug seat area down to the wheel/hub mating surface, I can tell you the exact length for the studs.
And don't forget that those wheels will require the small ball seat lugs. The stock T3 large ball seat lug nuts don't fit the wheels properly. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
cypor Samba Member
Posted: Fri Dec 11, 2015 4:21 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
And don't forget that those wheels will require the small ball seat lugs. The stock T3 large ball seat lug nuts don't fit the wheels properly. |
If i understood correctly then that distance is 10 mm thick until the cone of the rim begins for the lug seat. And about the tires shall i go for the 50 or 55 with -45 on the lowering springs for the look in that picture? 3 posts ago. Ty
cypor Samba Member
Posted: Fri Dec 11, 2015 2:02 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
From the manufacturer of the studs here in Ro i got asked what is the dimension of the knurled on the studs. Any idea? in mm.
They make custom studs, any dimensions. |
TheFop Samba Member
Joined: February 03, 2014 Posts: 302 Location: Auckland - New Zealand
Posted: Mon Dec 28, 2015 2:24 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Hi Folks, I bought a set of Mercedes C300 alloys for my 2WD 85 Vanagaon, they are 16x6.5 ET37 12mm lug holes, and a 20mm wall thicknes, they have 195/65/116 tires. Has anyone fitted this combo before? I'm about to order new bolts and studs which is a mission here in New Zealand, I'd love to order from Christopher but the shipping cost kills it.
As a sanity check I'm ordering 40mm bolts with small ball seats and 50mm studs and nuts as I don't believe I need spacers based on posts for similar size wheels, does this sound right?
[/img] _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
Stock 69 LHD Karmann Ghia Coupe - Driver
67 New Zealand Spec Beetle - Being rebuilt
63 New Zealand Spec Beetle - Going Baja!
86 T25 Westfalia - Family Fun car |
Posted: Mon Dec 28, 2015 2:30 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Yep, your assessment of the parts is right on. And no, you don't need spacers with 16x6.5 ET37 wheels. Be aware that the center caps will not fit though. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
TheFop Samba Member
Posted: Mon Dec 28, 2015 3:37 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks for the confirmation Christopher, I'll be ordering some "VW" caps off you soon to finish the "transformation", also looking to drop it by 2" to improve the handling. _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
TheFop Samba Member
Posted: Tue Dec 29, 2015 9:43 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I was wrong, its cheaper to order bolts from the very helpfull Christopher and ship them half way around the world than buy them in New Zealand, I visited two auto suppliers today and both looked at me like I was insane, then pointed towards trailer bolts, then looked through the generic "NICE" catalog which doesn't list a Vanagon, T25, T3, Eurovans or anything to do with these cars then came up with the wrong thing and priced a set of 11 (one spare) at $135.....I'm glad I bought them off Christopher also.
Other case and point is from CIP1 I can buy wheel studs for $9.59 for a set of 5, here they are $59 for exactly the same thing with the same part number, hows that for mark up?
New Zealand is an awesome place to live but we suffer from terrible parts supplies for cars and pay through the nose for everything. _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
