Posted: Mon Jan 23, 2017 8:27 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
vanonimous wrote: |
Forged Audi URS4 (Fuchs) 16x8 ET40
Man, that looks really, really good! Nice job! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Mon Jan 23, 2017 8:28 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
That's some mighty clean looking parts there. Nice!!! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
86scotty Samba Member
Posted: Tue Jan 24, 2017 7:03 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
New owner here, sorry
I'm upgrading my 14's on an 86 2wd Vanagon GL to black 16" steelies and am confused about what offset will work. Here's what I'm looking at, which have an offset of 41, 2.283 hub bore. I'm hoping to run them with 215/70r16 tires. Does anyone have any idea if I can run this offset (41) without spacers?
http://www.ebay.com/itm/U-S-Wheel-62-Series-Snow-B...7675.l4066
I'm hoping to run 215/70r16 BFGs with them at stock until I can lift it an inch or two.
Thanks |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Tue Jan 24, 2017 8:18 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
I sure hope ChrisToph3r has a clue on the rims. AND... I know this isn;t the place to talk tires, mod's will whack me for it.... but, that rubber is somewhere around 27.9" and that will make some funny things happen... Better to have the LAST thing you do to your van be the wheels and tires.. [Well... actually, the very last thing would be an alignment] _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Jan 24, 2017 8:35 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
bobbyblack wrote: |
I sure hope ChrisToph3r has a clue on the rims. AND... I know this isn;t the place to talk tires, mod's will whack me for it.... but, that rubber is somewhere around 27.9" and that will make some funny things happen... Better to have the LAST thing you do to your van be the wheels and tires.. [Well... actually, the very last thing would be an alignment] |
Funny things? Can you elaborate? Do you mean gearing and speedo or physical fitment/useability issues?
Thanks |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Tue Jan 24, 2017 8:56 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
The center bore is too small. Machining needed.
The offset is too large. Spacers needed.
Tire size too large, rubbing on some bumps.
215/65/16 is better fit.
Mark
86scotty wrote: |
Thanks |
Posted: Tue Jan 24, 2017 9:39 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
crazyvwvanman wrote: |
Mark
86scotty wrote: |
Thanks |
Thanks. I have no problem running slightly smaller tires. I have searched and searched and can't find the minimum center bore for a 2wd Vanagon. Does anyone know what it is? |
Posted: Tue Jan 24, 2017 9:43 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Christopher Schimke wrote: |
.... You will also have to have the center bore opened up to 66.56mm ...... |
Posted: Tue Jan 24, 2017 10:10 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
What they all said, plus "Spare won't fit in clamshell" _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Jan 24, 2017 4:52 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Thanks. I've read through most of this thread but I missed that.
@ bobbyblack, Thanks. I knew that. I'm planning on building a rear spare rack.
I have read many posts on wheels and will continue but still trying to figure out what steelies will mount right up. I'm hoping for 16"s but may have to resort to 15"s.
I know the 2000ish Passat and Jetta wheels will supposedly work but they're 15"s. I'm not sure about the center bore on those.
Thanks all |
Posted: Tue Jan 24, 2017 5:13 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Quote: |
I have read many posts on wheels and will continue but still trying to figure out what steelies will mount right up. I'm hoping for 16"s but may have to resort to 15"s. |
Mercedes 16x7 ET37 steel wheels (part #2034000302 and 2084000102) and Mercedes 15x6.5 ET37 steel wheels (part #2024000102) will bolt up (with the correct lugs of course), but you will be limited to a 205 or narrower tire if you don't want to run spacers.
Quote: |
I know the 2000ish Passat and Jetta wheels will supposedly work but they're 15"s. I'm not sure about the center bore on those. |
Almost all Audi or VW wheels will need their center bores opened up since they are too small to fit otherwise. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
warezdog Samba Member
Joined: November 24, 2016 Posts: 25 Location: Southwest Florida
Posted: Tue Jan 24, 2017 6:37 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
[quote="Christopher Schimke"]
warezdog wrote: |
That's some mighty clean looking parts there. Nice!!! |
Thanks! Lot of work but you only do this once right?!
They started like this!
Wirebrush and kero
wiped down after kero bath
sand blasted and finally almost ready for paint.
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jan 24, 2017 7:49 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
[quote="warezdog"]
warezdog wrote: |
Very nice! Sending you mine... _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Italjohn Samba Member
Joined: October 29, 2016 Posts: 193 Location: Molde, Norway
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Wed Feb 01, 2017 2:00 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
This seems like a great place to post this:
this was recently listed in the classifieds, 3 CLK 16" rims at $100/ea.
http://www.thesamba.com/vw/classifieds/detail.php?id=2018081
Wheels located in Florida.
cheers (not associated w/ seller etc) _________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
UngaWunga Samba Member
Posted: Sat Feb 04, 2017 1:58 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Want steel rims and don't mind working a little bit?
Passat rims. Welder. Hole saw and drill.
Fits fine on a Syncro. Now to sell the tires the rims came with and get some 205 or 215 tires.
Weld a short piece of metal across as a guide for the hole saw. Drill from the inside of the rim out.
toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 596 Location: Great White North
Posted: Sat Feb 04, 2017 2:03 pm Post subject: Re: "What wheels fit?" The ultimate wheel post. |
Would be handy to have a syncro only or 2wd only post, the blend makes it harder to sort through the info.
Found some 10 hole Benz wheels on CL 16x7.5 et42 and trying to find if I will have issues with my syncro.
TIA. |
Timwhy Samba Member
Posted: Wed Feb 08, 2017 3:34 am Post subject: |
There is also a 15x6 ET37 Passat steel wheel with a 57.1mm centerbore, part number 3B0601027D. These will fit the Syncro and 2wd without spacers, but again, the centerbore needs to be opened up and 205/215 tires are required on a 2wd.
All of the wheels above are designed for small ball seat lugs. |
Can you elaborate on the 205/215 tires?
I am trying to figure out what tires will work with my 91 Tin Top using the Passat Steel Wheels 15 x 6 ET 37. So far I have been able to buy two wheels and had their center bores opened to 66.56mm as you suggest.
The tires I am looking at are the General Grabber AT2 205/75r15 or the 215/75r15.
Thanks for the help...........Tim _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Wed Feb 08, 2017 4:49 am Post subject: Re: "What wheels fit?" The ultimate wheel post. |
UngaWunga wrote: |
while I applaud your "go to" mentality, I do have to wonder about balance issues. Is it an optical illusion or is there more "meat" taken off the one side of the bore than the other? |
