I have to jack clamp peices, the numbers don't match
FreakCitySF
FreakCitySF is offline
PostPosted: Fri Nov 10, 2006 5:22 pm    Post subject: I have to jack clamp peices, the numbers don't match Reply with quote
I have two each of 5 and 6.
I just want the original. Is that the right part # in the microfiche?
The 2 top latches I have
part #
111809378
211801647
What are these from?[/url]
kubelmann
kubelmann is offline
PostPosted: Fri Nov 10, 2006 10:59 pm    Post subject: Reply with quote
These two parts that you list are the car jack retainer assembly. On our things they are located under the front hood and are used to hold the car jack in place. The reason for the 211 part number on the one part is that it comes from the type-2 bus (bay window 68 on) originally used as a jack clamp or retainer. The other part for rearward part is common to all type1 VWs as a jack clamp retainer that is found under the hood of bugs, ghias and most other air cooled VWs.
