Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sat Nov 11, 2006 2:38 pm Post subject: Hot-Spark Ignition Kits |
Has anyone had any experience with Hot-Spark ignition kits? They sell electronic conversion kits for $39.95 for both 009 and SVDA distributors. They also sell a SVDA distributor with electronic ignition for $119.95.
They are a lot cheaper than Pertronix, so I'm wondering about the quality... |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sat Nov 11, 2006 2:42 pm Post subject: |
Points replacement?
All it does is trigger the coil. It won't make the spark any hotter with a new coil and/or box. _________________ Glenn
Member #1009
#BlueSquare |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Sat Nov 11, 2006 3:50 pm Post subject: |
Glenn"s correct (as usual). These units eliminate the points, and therefore create a perfect dwell, since point gap is no longer an issue.
Hotter spark would have to come with a "box" such as an MSD or comperable. |
kubelmann Samba Member
Posted: Sun Nov 12, 2006 8:40 am Post subject: |
I have had good luck with the compufire electronic points. They go for $50 |
Thingggg Samba Member
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Thu Nov 16, 2006 8:25 am Post subject: |
alsehendo34 wrote: |
My next engine has this, it is not installed yet so thus the curve is not tuned yet. I will not be using TPS or map @ first. I will however have a fake TPS signal to move timming up and down on the fly without having to have my computer with me while I drive.
"Did you get the memo about using a coversheet on your TPS report?"
"I'll make sure you get another copy of that memo...."
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Posted: Fri Nov 17, 2006 2:12 am Post subject: |
Pointless--thats one of the ideas.
No map because, I never herd of it being used with a carb.
Here some pics of the crank trigger guy's turbo Thing.
http://home.earthlink.net/~beanbooger/id1.html |
