63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Mon Nov 13, 2006 5:23 pm Post subject: Body Lift Sources |
I have seen some forum discussions on Thing Body lifts. However, I do not see any advertisements on web sites or magazines. What sources are out there?
Thanks in advance. |
mattt Samba Member
Posted: Sun Nov 19, 2006 10:43 pm Post subject: |
There is a company that sells Thing body lifts. It is called Up Yer Bug. I will try to find contact info. |
saddlesore1 Samba Member
Posted: Mon Nov 20, 2006 5:24 pm Post subject: |
Good luck getting a hold of Up Yer Bug. I found my lift kit last week at an off road shop in Corona CA. I cannot find my reciept right now but I will dig it up if you want. It is the "Old" Up Yer Bug one with Boxed beams. I paid $400 without the bolts, spacers or steering spacer. They have 3 left. otherwise. McKenzies in Fullerton can order you a new one with all of the bolts, spacers and steering spacer for $500. Good Luck. It is easy to install.
Regards,
Saddlesore |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
mattt Samba Member
Posted: Mon Nov 20, 2006 11:38 pm Post subject: |
On the Thing it is not all tubing. There are 3 cast aluminum pieces for the front curved area. The Thing pan is shaped different, so to make all the curves with rect. tubing would be difficult to say the least.
I'd like to know the shop in Corona, CA that had Thing body lifts in stock. I never knew there was a shop in Corona that is trying to cater to Things. Thanks in advance. |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Mon Nov 20, 2006 11:51 pm Post subject: |
mattt wrote: |
Same here, Corona is only 30 miles away. I even work there from time to time. |
ztnoo Samba Member
Posted: Tue Nov 21, 2006 3:42 am Post subject: |
I found this info in my Thing files in a jpg. file of an ad I saw somewhere along the line in the last couple of years.
I have no idea if the data is current or not, but I thought I'd pass it on.
Up Yer Bug
Andy Felix
1069 So. Santa Fe
Vista, CA 92083
760-726-0130 |
Posted: Tue Nov 21, 2006 11:37 am Post subject: Thing Body Lift |
Appreciate all the info so far. I have thought about fabricating one. Deciding whether worth the effort. Years ago I installed several body lifts on 4x4 trucks. A little different since that was only poly? blocks at all mount points.
Still have some time. I pulled the body the other week and cut out the passenger pan last week. About ready to be welded back inplace and then on to the left side. Still time to figure out body lift.
I am considering having the spindles cut and raised by Blind Chicken Racing. I have seen their name mentioned a few times and appears they do nice work. From there would be to re-index the rear a notch or two.
Looking for some clearance for tires and an offroad look. |
Posted: Tue Nov 21, 2006 4:43 pm Post subject: |
The shop in Corona I beleve is call Karco. 909 area code. They do not specilize in Thing they are a full blown off road shop that happens to have a few lift kits. They have all the other off road stuff as well. I tried the number posted for Up yer Bug a while ago and got no response. As for "yust a couple of beams and bolts" Not even close. There are 3 aluminum peices and and a curved rear piece. Good lick making one. Attached is a link of one I saw long ago. http://www.thesamba.com/vw/forum/viewtopic.php?t=105910&highlight=body+lift |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Tue Nov 21, 2006 5:01 pm Post subject: |
Just a thought - since the pan of a Thing is the same as a Karmann Ghia, you may want to explore those sources as well.
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
Posted: Wed Nov 22, 2006 9:30 pm Post subject: |
saddlesore1 wrote: |
The link in your post confirms that to build your own, it's just a bunch of "beams and bolts".
Your link says the ones that you buy are cheap thin crap.
There was even a guy that bought one and wished he hadn't.
In this link there is a better description of why you can't just use the same size metal on the front tunnel area that you would on the sides.
http://www.thesamba.com/vw/forum/viewtopic.php?t=173098&highlight=body+lift |
mattt Samba Member
Posted: Wed Dec 13, 2006 12:09 am Post subject: |
Kartek......Holy Cow!! That is amazing to me that Kartek had Thing body lifts in stock. They must have been around for a long time. Kartek has been veering away from the VW end of off road for a long time now as desert racing in general goes the same direction. Sure, most off road racing was VW based in the past, but no longer. I wonder how long they have had those body lifts??? |
