honky Samba Member
Joined: August 10, 2006 Posts: 149 Location: Connecticut, USA
Posted: Sun Nov 26, 2006 7:17 pm Post subject: air intake connection |
My 74 Thing with the original 1600dp motor seems to be missing the lower connection point for the air intake hose off the carburator. The hole in the tin is there but nothing below it. It has had a new non stock muffler put on before I got it. Is that connection off the heater box, part of the stock muffler or where. Anyone seen a picture of it anywhere. |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sun Nov 26, 2006 7:24 pm Post subject: |
My 73 is missing the same part. I read somewhere that it is a tubular elbow that helps direct warm air from the heads into the carb. I stuck the end of the air hose into the hole for now... |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Sun Nov 26, 2006 7:30 pm Post subject: |
The part you are missing?:
Also should have this part of cylinder shrouding:
Pipe connects to elbow like this (view from underneath):
(apron not installed in this photo) |
ztnoo Samba Member
Posted: Mon Nov 27, 2006 3:46 am Post subject: |
I believe the stock piece you refer to looks like this:
http://www.thethingshop.com/images/products/largerimages/113129519g.jpg
This one is very close to what we have here on three stock Things.
They all have a 90 degree bend and are not the straight pipe shown in the post before.
I've heard it referred to as the "stove pipe". |
bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Mon Nov 27, 2006 5:15 am Post subject: |
This piece in the photos above allowed the snorkle part of the air cleaner to draw hot air off of the cylinder for cold start/cold idle conditions, aiding in faster engine warm up times. Many folks here in the north that use their Things to get back and forth to work in the cold outside temps will benefit from this overlooked piece.
Another point to look at is the weighted flapper inside the snorkle. After engine warmup, the flapper is supposed to open, allowing the somewhat cooler air to enter into the air cleaner. I took my air cleaner off, and found that the flapper was not opening, and therefore constant hot air from the cylinder was only entering the air cleaner. After using a toothbrush and some carb cleaner, this was resolved, and now the engine idled better both during warm up (engine cold), and after it was warmed up (approx 3 to 5 minutes the flapper should open up). |
honky Samba Member
Posted: Mon Nov 27, 2006 6:17 am Post subject: Stove pipe |
I assume this just catches a shroud screw somewhere to attach ? |
bciesq Samba Member
Joined: April 13, 2005 Posts: 495 Location: Orlando, FL
Posted: Mon Nov 27, 2006 7:54 am Post subject: Re: Stove pipe |
honky wrote: |
I have this part:
and it attaches to one of the screws in the rear engine tin (aka, breast plate). _________________ '73 Thing -- making 45 mph exciting again. |
