tko Samba Member
Joined: September 30, 2008 Posts: 152 Location: summerset Sd
Posted: Thu Dec 30, 2010 9:33 am Post subject: |
[quote="melensdad"]
wyobuggy wrote: |
The tracks were just as described. I rember thinking there were about 1000 bolts per side. I had a long chunk of conveyer belting that I was going to use. Nice thick 2or 3 ply stuff. Guess the cowboys had fun punching holes in it. |
I'm lucky, when I bought mine the tracks were in pretty good condition. But I don't look forward to the day that I have to replace all the belting. Conveyor belting would probably work, but there is specialized belting that is designed for the water, temperature and sunlight exposure these snowcats have to deal with so I suspect that conveyor belting would not last as long as specialized belting. Still, it would probably be a lot more economical to use conveyor belting!!!
Conveyor beting is a lot stronger than you think. most crush plants use several hundered of belting per unit to move 500+ ton of rock, gravel, sand, ect per hour. One of the conveyors we had was a 225' so it had a little over 550 foot of belting moving at one time That was a bunch of material on the belt. _________________
neanders wrote: |
I have a *very* friendly cat that I tell people is like my ex: she likes to sleep with the neighbors. |
bajamike560 Samba Member
Joined: December 11, 2009 Posts: 544 Location: Vancouver WA
Posted: Thu Dec 30, 2010 10:15 am Post subject: |
Bajacowboy,
I was looking at the photos of the shift knobs, do you make them?
Mike |
BajaCowboy Samba Member
Joined: February 15, 2007 Posts: 130 Location: Ashland Oregon
Posted: Sun Jan 02, 2011 12:46 pm Post subject: |
bajamike560 -
I used to when I had time. I used to have full access to cnc lathes and 4th axis mills, but now I barely have time to work on my track assembly as I'm to busy running the machines for other jobs. _________________ Chuck
Ashland, Oregon |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Jan 02, 2011 1:15 pm Post subject: |
PBS Nature show did a Christmas special, about Christmas in Yellowstone.
The showed a couple Snow Trax. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sun Jan 02, 2011 1:19 pm Post subject: |
onlyn8v wrote: |
Sorry to dig this up but I was at that show.... Hey Glenn, do you remember what that guy was selling that for? |
It's owned by Joe Gunyun and was not for sale. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Jan 02, 2011 9:30 pm Post subject: |
BajaCowboy wrote: |
bajamike560 -
I used to when I had time. I used to have full access to cnc lathes and 4th axis mills, but now I barely have time to work on my track assembly as I'm to busy running the machines for other jobs. |
Thanks for the reply.
I guess you have a "good" problem then, having to much work and all.
Mike |
onlyn8v Samba Member
Joined: August 13, 2010 Posts: 11 Location: Terryville, NY
Posted: Mon Jan 17, 2011 1:25 pm Post subject: |
Glenn wrote: |
onlyn8v wrote: |
It's owned by Joe Gunyun and was not for sale. |
Cool thanks! |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Thu Nov 29, 2012 12:15 pm Post subject: |
Well I recently discovered these and for some crazy reason, I had to have one. I searched high and low, far and wide, for a whole month.... and then this came up about 5 hours away. It's now in my driveway.
Needs some tlc but otherwise I think it's a good start to some winter fun with a VW powered unit.
Feel free to chime in on this as I have never seen one in the flesh until I picked this up. It runs and moves but needs some adjusting here and there.
_________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 986 Location: Shawnee, KS
Posted: Thu Nov 29, 2012 4:58 pm Post subject: |
What a find!! That thing is awesome! |
cmiller95 Samba Member
Joined: August 04, 2010 Posts: 1232 Location: Illinois
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Tue Sep 04, 2018 8:26 am Post subject: Re: Snow Trac - the VW with tracks instead of tires. |
I recently came across the following air-cooled VW based tracked vehicle in need of restoration, for sale on British Ebay in late-June 2018, which I suspect might be a Snow Trac. It sold for £4,100.
https://www.ebay.co.uk/i/113070038373?ul_noapp=true
https://www.ebay.co.uk/itm/VW-BEETLE-BASED-SNOW-CA...l10137.c10
_________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Thu Sep 06, 2018 4:47 am Post subject: Re: Snow Trac - the VW with tracks instead of tires. |
I’d like to see how the belt drive track control works, that could probably adapt to other air cooled horizontal shaft engines... such as for garden tractors. _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
jjackson0890 Samba Member
Posted: Fri Nov 06, 2020 10:04 am Post subject: Re: Snow Trac - the VW with tracks instead of tires. |
Where have you found parts for your snow trac? i just got one last week that i am going to start restoring |
