Carburettor decision?
frogge
frogge is offline
PostPosted: Thu Dec 14, 2006 3:27 am    Post subject: Carburettor decision? Reply with quote
What carburettors should I choose? What to expect (horse power)?
Engle W-120 Camshaft
1.25 rocker arms
Heads with 92mm bore and 42mm X 37.5mm valves.
Picture below.
/frogge
Bruce
Bruce is offline
PostPosted: Thu Dec 14, 2006 4:09 am    Post subject: Reply with quote
What size is the engine?
frogge
frogge is offline
PostPosted: Thu Dec 14, 2006 5:04 am    Post subject: Reply with quote
1835cc
/frogge
tkelley
tkelley is offline
PostPosted: Thu Dec 14, 2006 6:08 am    Post subject: Reply with quote
A set of kads would work good
on your set-up. You could also go with 40idf's
If you have the coin go FI, the best IMHO.
Tom
vwracerdave
vwracerdave is offline
PostPosted: Thu Dec 14, 2006 6:15 am    Post subject: Reply with quote
Dual 40 IDF's with 32mm venturies.
nsracing
nsracing is offline
PostPosted: Thu Dec 14, 2006 7:12 am    Post subject: Re: Carburettor decision? Reply with quote
1.25 rocker arms
Picture below.
/frogge
For 1835cc, I will just use dual Kadrons. But I will tell ya, those heads are NOT ready. Looks like the intake has been sunk too deep. The port runners look good, but below the seats need some attention.
The sealing surface also needs flycut clean.
LIke so..
I did this cut with a Criterion Facing/boring head. Only the surface got cut and not the walls, but it is machined all the way to the corner.
Peace.
frogge
frogge is offline
PostPosted: Thu Dec 14, 2006 9:57 am    Post subject: Reply with quote
Thanks for the replays.
I’ll take a look at the intake and the sealing surface…
But you think the setup will work? or should I change something...
/frogge
nsracing
nsracing is offline
PostPosted: Thu Dec 14, 2006 11:01 am    Post subject: Reply with quote
/frogge
The set up should be sweet. Go for it.
