krewe01 Samba Member
Joined: December 04, 2006 Posts: 49 Location: Abita Springs LA
Posted: Tue Dec 19, 2006 7:17 pm Post subject: Headlight Question |
I just purchased a 73 Thing and when I turn on the headlights the lights on the speedo turn off also I see some sparks by the switch is this normal (I Hope Not)any suggestions
Thanks in advance |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Tue Dec 19, 2006 8:29 pm Post subject: |
Well, I don't know Things very well but sparks ain't normal! |
Posted: Tue Dec 19, 2006 8:51 pm Post subject: |
It doesn't always spark if that helps at all??? |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Tue Dec 19, 2006 8:59 pm Post subject: |
I've driven mly '73 on and off now for ten years. Sparking is not normal - I'd look into that... soon! Check the wiring, check to see if something has fallen back there too.
The one time my dashboard sparked, the turn signal relay had fallen and grounded against the body and caused a HUGE spark. I immediatly turned off the key, didn't notice any fire, so (like an idiot) turned the key back on and burned out the keyswitch with another HUGE spark. |
Posted: Tue Dec 19, 2006 9:33 pm Post subject: |
I just got the car on Sat I guess I will take a look behind the dash.The wierd part is that everything works great but the dash lights...
Thanks for the advice so far |
7thing3 Samba Member
Joined: April 05, 2003 Posts: 473 Location: Cleveland, OH
Posted: Wed Dec 20, 2006 10:01 am Post subject: |
I had a similar problem that was caused by the + light wire going to the red heat/def light in the center of the dash rubbing against the metal. Seems that if the tab gets bent to close to the metal it will short.
Look for something similar. There are only a few things that get lit up when you turn on the lights--the speedo lights and the 2 lights related to the heating system (I think). |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Thu Dec 21, 2006 9:08 am Post subject: |
7thing3 wrote: |
+1 on this recommendation.
In my youth I had a 1958 Austin Healy. Endowed with the world-renowned Lucas electrics, that poor little car suffered from frequent under-dash electrical fires. The first time it happened I freaked out, of course. After the third or fourth time, I wouldn't even pull over. I'd just reach under the seat for one of a pair of leather work gloves I kept in the car, and tamp the fire out.
While you're inside the dash looking for bent spade connectors that might be shorting against something, check for cracked or rotten insulation.
It doesn't take much tinkering by a previous owner to get the wiring behind the dash looking like a rat's nest. Ideally it would be best to clean up the wiring, but as a stop gap, just wrapping the spade connections with Super 33 tape will do wonders. |
mattt Samba Member
Posted: Thu Dec 21, 2006 1:09 pm Post subject: |
It could also be something as simple as a bad headlight switch. I had a Thing in the past that would do something similar. Turning on the running/headlights killed the interior dash lights Jiggling and/or turning of the dimmer on the headlight switch would normally cure it......for a little while. Seems like the dimmer{reostat} goes out before the whole headlights switch. You might just try replacing the headlight switch, they arent too expensive. |
Posted: Thu Dec 21, 2006 4:31 pm Post subject: |
I was told by a couple other people that it might be the headlight switch I am going to take a look this weekend and see if i cant figure it out.I apprieciate all the help and suggestions |
Posted: Thu Dec 21, 2006 7:22 pm Post subject: |
Matt or anyone else who may know??
Maybe this is the problem you said the reostat may be bad, Im assuming that if I turn the headlight switch that its supposed to dim or brighten the dash lights??? It doesn't do anything, it just turns and turns. Also one of the contacts on the headlight switch is not being used maybe this is my problem or maybe a combination of both???? Should I buy a new harness, switch ... both??? Im Lost |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Thu Dec 21, 2006 7:23 pm Post subject: |
It is the dimmer for the dash lights that is your problem. The coil part has gone bad.
Pull the coil part out and continue to use it or change the whole switch. |
Posted: Thu Dec 21, 2006 7:40 pm Post subject: |
I am going to try and change the switch(I have to order one) When I get the switch do I use all connections? One of the connections is not being used at this point??? When I have more light I will find out which one maybe someone can tell me what to do. Also one of the dash lights is just kinda just floating around behind the dash. Does amyone know exactly which part of the dash is supposed to light up???? so that I can put it in its proper place??
Thanks for all the help |
mattt Samba Member
Posted: Thu Dec 21, 2006 7:50 pm Post subject: |
From what I remember, not all the terminals on the headlight switch have a wire going to them.
The speedo has two bulbs sockets in it, roughly at 10 & 2. The only other lit up things on the dash are hazard and heater controls IIRC. The dimm-able dash lighting wiring is white w/ red stripe. I think its a daisy chained continuous wire. |
