Turbo/EFI on a budget **NOVEMBER UPDATE!!!!**
Goto page 1, 2, 3 ... 13, 14, 15  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Mon Jan 08, 2007 5:43 am    Post subject: Turbo/EFI on a budget **NOVEMBER UPDATE!!!!** Reply with quote
I've gotten a few PM's now about the engine I intend to run in my 58 Beetle, so I figured I'd better spill the
beans before my fingers get tired of typing. Very Happy
Basically, people want to know how to get a Turbo/EFI system into their vehicle for a low price, which is also what I wanted to do. There are many different ways to skin the proverbial cat, mine is just one way to do it, so take from this what you can.
O.K., so you are thinking about going Turbo/EFI, but don't know where to start? Well, I'm posting this in the hopes that more people will realize that it's not as hard as it seems, that there are alternatives to carburators, and also that it's not that expensive either.
In my case, high fun-to-dollar ratio was a prime concern, therefore I started shopping for a budget EFI system, and got a rude awakening. Turns out most of the systems out there are more than $900 out the door (my entire budget!); that is until my brother told me about Megasquirt. Long story short, I ended up with the version 2.2 ECU from the MS website in kit form for somewhere around $175.
That includes the parts kit, and the stim board to test it, once assembled. I also aquired various support electronics that I felt were going to be useful down the road, and ended up getting a laptop for tuning, an Apex digital boost controller, and a HKS turbo timer all for $200 from some ricer that maxed out his credit cards ricing out his Evo. Twisted Evil He had to sell me his stuff to pay his credit card debt. Anyway, I assembled the ECU, cleaned the porn and viruses off the laptop, and reloaded the software, and there's the EFI electronics for $375. Other small things will still be needed, like a pump, regulator, injectors, throttle body, and the lines, but all that stuff can be had for less than $50 at the junkyard. Now I'm at $425.
Also, I ended up buying a Techedge wideband oxygen sensor. Not a required item, but very useful, and it's been paying for itself anyway due to being rented out to my friends on occasion.
Next, I got a turbo header from CB Perf ($280), dual port end castings for EFI with fuel rails ($181), and a couple turbo's and intercoolers from the junkyards (in all about $100).
That brings the running total to $986, so I'm a little over budget, but not by much. Assuming you already have a running engine that is suitable for this kind of conversion, I'm positive anyone can build an EFI system like this even for less than I have. There are cheaper alteratives to some of the parts, like using VW FI end castings (FI Beetle), and welding your own header. Very Happy
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
mark tucker wrote:
make up your own##s.that way you will still sound like an exspert.
miniman82
Samba Swamp Donkey
PostPosted: Mon Jan 08, 2007 6:00 am    Post subject: Reply with quote
Shown below are the Techedge wideband at left, the laptop, and the MS brain at right.
Next, a mockup of the engine. I decided to run the TB and turbo stuff behind the shroud, so I can close the decklid, and also so nobody can see what I have under there even if they looked. Twisted Evil
The header and turbo will be hidden behind the firewall, the only visable parts will be the injectors and intakes.
Behind the engine. The intercooler will be mounted somewhere above the passenger axle tube, with ducting to direct air thru it. Same goes for the oil cooler, but on the other side.
The turbo housing was clocked to point down into the intercooler, but it may change later due to unseen design changes. I may have to mount the intercooler horizontally for clearance, for example.
Also, as you can see in the photo, the rear exhaust tubes will need to be modified to go under the engine. The mid engine header was designed for buggies, but can easily be modified to work in a Beetle with some cutting and welding.
Mr. Loaf
Mr. Loaf is offline
PostPosted: Mon Jan 08, 2007 6:33 am    Post subject: Turbo Reply with quote
Looks like you are going in the right direction! I might be a little concerned though where your turbo is. Don't know what you are using this engine for, drags(?), but I would think that the excess heat from the turbo and exhaust is going to be used by your cooling fan and will cause your motor to run a lot hotter than if the turbo was mounted some where else.
Never drive faster than your Angel can fly
$24,100 was too hard to resist.................
vwdmc16
vwdmc16 is offline
PostPosted: Mon Jan 08, 2007 6:41 am    Post subject: Reply with quote
Scweet build mate. keep us imformed.
what is this beast going in?
"Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com
Kalen1970
Kalen1970 is offline
PostPosted: Mon Jan 08, 2007 6:47 am    Post subject: Re: Turbo Reply with quote
Same thoughts here. your pre\heating the air you are blowing over your cylinders. Sucking it over a really hot turbo.
1 1970 Beetle - Rejoined to the pan, attempting to work out electrical bugs, and carb troubles
miniman82
Samba Swamp Donkey
PostPosted: Mon Jan 08, 2007 3:04 pm    Post subject: Re: Turbo Reply with quote
The turbo system will be seperated from the engine by the firewall, it's compartmentalized. There will only be a hole big enough for the charge tube to fit through, and I'll seal that off with a grommit or something. The engine will draw cooling air in the normal way, from the vents above the lid. If it ends up getting hot, I'll run standoffs.
This will be my daily driver, BTW. Twisted Evil
I'm betting there will be a good amount or heat shielding required to help guard against heat soak, we'll see what happens. The oil cooler has a dedicated fan, but at the moment, the intercooler does not.
shegel
shegel is offline
PostPosted: Mon Jan 08, 2007 7:15 pm    Post subject: Reply with quote
just wondering, is this the kit that you got?
MS122-K_BL
MS122-K
from this site
http://www.diyautotune.com/catalog/megasquirt-kits-c-27.html
miniman82
Samba Swamp Donkey
PostPosted: Mon Jan 08, 2007 8:22 pm    Post subject: Reply with quote
I have the MS122-K kit, the _BL one has a black case.
Looks like prices have gone down quite a bit since I bought mine. Wink
Urnge74
Urnge74 is offline
PostPosted: Mon Jan 08, 2007 11:14 pm    Post subject: Reply with quote
what type of throttle bodies/injectors are you using?
Baton Rouge Aircoolers
miniman82
Samba Swamp Donkey
PostPosted: Tue Jan 09, 2007 12:14 am    Post subject: Reply with quote
I'm using CB Performance dual port end castings that have injector bosses in them, they will be plumbed to a single throtle body. I have Ford 2.3T 370cc/min low Z injectors, but depending on how far I decide to take it, I may need bigger. Laughing
turboedbug
turboedbug is offline
PostPosted: Tue Jan 09, 2007 4:04 am    Post subject: Reply with quote
What kind of fuel pump and regulator you planning on running?
View user's profile Send private message Send e-mail MSN Messenger Classifieds Feedback
miniman82
Samba Swamp Donkey
PostPosted: Tue Jan 09, 2007 3:06 pm    Post subject: Reply with quote
I'm not sure on the pump yet, but I'm confident the Ford Econoline pump recommended by the MS guys will be enough. If it doesn't have enough volume, I'll have to step up to something like an Aeromotive.
As for the regulator, I got one from CB when I bought the header. It's a Malpassi boost referenced reg, but I'm unsure about the ratio. CB's info sheets don't say if they are rising rate or not, but it should work fine.
turboedbug
PostPosted: Wed Jan 10, 2007 3:00 am    Post subject: Reply with quote
Awsome, keep us posted. I am currently building something simular
dereke
dereke is offline
PostPosted: Mon Jan 22, 2007 9:43 am    Post subject: Reply with quote
mmm... sure it will sucked hot air by any means
seabeebuggy
seabeebuggy is offline
PostPosted: Tue Feb 13, 2007 12:14 pm    Post subject: Reply with quote
Why would you use a boost referenced regulator? with EFI? carbs yes. but the boost pressure would not affect the injectors right? asking because I dont know.
Soon to be 3.3 turbo seabee buggy 500hp
Seabee turbo buggy build
(Quote Runslikeapenguin said)
so to everyone else whos not a retarded butt pirate marine with an tacky ugly ass car covered in auto zone bolt and stick on s**t. (end quote)
A better place to talk offroad
Rude-e
Rude-e is offline
PostPosted: Tue Feb 13, 2007 4:20 pm    Post subject: Reply with quote
Rissing rate regulators are used on FI engines also - as a cheap alternative for fuel management(boost increases, so does fuel). With programable EFI it is not a necessity because you can adjust Fuel injector pulse width and other parameters.
miniman82
Samba Swamp Donkey
PostPosted: Wed Feb 14, 2007 5:17 am    Post subject: Reply with quote
It might appear on the surface that a regulator is not necessary with FI, because as was said, you can just add more fuel. In reality, this is not the case. Even factory FI systems are referanced to vacuum, the reason is it increases the resolution of the injectors.
Without the reg referanced to vac/boost, you would hit 100 percent duty cycle quickly, because the only way to add more fuel, would be to increase pulsewidth. You could compensate with bigger injectors, but at some point, the injectors would get so big you would be unable to control them at idle, leading to poor running (you can only shorten the pulewidth to a point). On the flip side, if you had injectors that ran well at idle, it is entirely possible that without being boost referanced you could end up with the injectors being always on!
Either way, the reg makes the injectors easier to control because now you have more than one way to increase the fuel flow through the injectors, it's just that you don't see what the regulator does on your laptop.
Without one, your fuel map would be pretty wild, I bet.
You need a boost reg on blow-through carb because without it, the boost pressure would force the fuel entering the float bowl back to where it came from, and the engine would starve.
66 Käfer
66 Käfer is offline
PostPosted: Wed Feb 14, 2007 12:44 pm    Post subject: Reply with quote
I like where you are going with this, Megasquirt would be my choice also to do an EFI set-up but why did you go with the mid-engine header? If it is for a daily driver why didn't you go with the hide-away header? They are only $245 and a lot less modifiyng to make it work.
Just wondering, that's all. Over all it is pretty much the same direction I would take, using a single throttle body simplifies things a bit.
miniman82
Samba Swamp Donkey
PostPosted: Thu Feb 15, 2007 5:44 am    Post subject: Reply with quote
I went mid-engine header because I didn't want anyone to see what I had, and the hideaway one didn't really appeal to me because it's a little too cluttered. Don't get me wrong, it works good for a lot of people, it's just that I wanted a clean looking engine bay. The only way I could do that, was by swapping the end castings around, and running the entire system behind the firewall with the mid-engine header.
The only thing visible in my engine bay will be the engine.
I don't mind cutting the package tray, it's my POS car, it'll probably end up primer grey. Rolling Eyes
66 Käfer
66 Käfer is offline
PostPosted: Thu Feb 15, 2007 5:52 am    Post subject: Reply with quote
That's cool, I see what you mean, but you have to admit that it is a lot better then the blow-through set-up...
Keep the picture coming, I'd like to see how it comes out.
I can see it...
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 1 of 15
