Posted: Mon Feb 24, 2003 9:57 pm Post subject: Body off pan |
I'm in the process of building my 1302s into a german look. I want to do this properly and take the body off the pan but should I have all my rust work done while it's still on or off i have heard stories of the body twisting a being a prolem to refit any help with the best method for this would be helpfull. |
mixedup59 Samba Member
Joined: August 07, 2002 Posts: 704 Location: Tacoma Washington
Posted: Wed Feb 26, 2003 8:51 am Post subject: Body off pan |
not really unless its a convertible or really rusted through the heater channels.
If its a vert.....we usually weld a rod towards the top of the doors in the jams.
That usual will keep it from flexing. good luck. |
tacky Samba Member
Joined: April 21, 2004 Posts: 577 Location: highways of agony, va.
Posted: Sat Oct 30, 2004 3:56 pm Post subject: |
could you be more specific about the bracing required to firm up the vert body for removal? _________________ "Everyone reading this is a PO." |
Orange65Turbo Samba Member
Joined: September 12, 2004 Posts: 195 Location: So Cal
Posted: Thu Nov 04, 2004 3:25 pm Post subject: |
I've taken several non-vert bodies off the pan over the years. I never had a problem with structural integrity and re-alignment. I'll have to say; the bodies I've worked with never had major amounts of rust. There was some rust in the pillars and wells. However, a body would have to be REAL rusty to twist and remain in that position. Are you replacing heater channels?
Scott |
tacky Samba Member
Posted: Thu Nov 04, 2004 3:33 pm Post subject: |
yes, heater channels are bad. i have heard it is best to do this repair before removing the body. is this true? also do you brace the vert body at all before removal? _________________ "Everyone reading this is a PO." |
HotRodedXXX Samba Member
Joined: April 23, 2004 Posts: 205 Location: Pensacola, FL
Posted: Sat Nov 06, 2004 5:55 am Post subject: |
Pick up the Bug Me video on channel replacement. They do a vert and show how its done in very high detail. |
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2045 Location: 41.77 | -83.56
Posted: Sat Nov 06, 2004 7:29 am Post subject: |
Ditto on the Bug Me Video. It's extremely helpful and may save you a ton of headaches. |
tacky Samba Member
Posted: Mon Nov 08, 2004 7:03 am Post subject: |
great advice! thanks everyone. next step, air chisel. _________________ "Everyone reading this is a PO." |
jackq Samba Member
Joined: July 03, 2003 Posts: 210 Location: Clovis New Mexico
Posted: Wed Nov 10, 2004 7:48 am Post subject: verts/pans |
Last conv. body off we did, we removed the doors and built an X type frame that bolted across the door opening to the hinge connectors and the striker plates. Then rolled the car under the overhead electric hoist , used our sling for lifting and carefully lifed bit by bit. Did our cleaning, cutting and welding and all was great. I know most people don't have the space and overhead hoist..I'm just fortunate to have a shop big enough to handle about twenty at a time. The door frames are simple to build, get a few big pals to lift the body...and cover it up if you have to leave it outside, do the pan and swap places. |
