My Notch... going Turbo EFI
Goto page Previous  1, 2, 3 ... 27, 28, 29 ... 36, 37, 38  Next
Tram Premium Member
Samba Socialist
Tram is offline
PostPosted: Sun Mar 18, 2012 12:25 am    Post subject: Reply with quote
vwfye wrote:
Talked with some folks that have more knowledge than me (that's most everyone Laughing ) and they suggested I remove the wastegate and block off that outlet and see if I get any boost. If so, we know the problem. If not, they we eliminate a possible problem. Oh joy...
Is your wastegate adjustable?
Give A Pal a Hand!
www.happytrailsfarm.org
May 4, 1970... Never Forget.
RIPRW
"Hell is- other people."- Jean- Paul Sartre
vwfye
vwfye is offline
PostPosted: Sun Mar 18, 2012 12:35 am    Post subject: Reply with quote
spring pressure adjusted by a nut at the top. even with the most pressure, it produced almost no boost. the gate was used and i have no idea if it is even functioning. this should tell me quickly!
http://www.thesamba.com/vw/forum/viewtopic.php?t=269496&highlight=speedster <--Notch Speedster
http://www.thesamba.com/vw/forum/viewtopic.php?t=214907&highlight=speedster <--Piece o' Crap
http://www.thesamba.com/vw/forum/viewtopic.php?p=5494415#5494415 <--Beige & POR
supaninja
supaninja is offline
PostPosted: Sun Mar 18, 2012 8:08 am    Post subject: Reply with quote
The diaphram inside of the WG could be torn, what brand is it? Have you done a boost leak test on the charge piping/IC (search the internet for how to do that).
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
vwfye
vwfye is offline
PostPosted: Sun Mar 18, 2012 9:57 pm    Post subject: Reply with quote
Today was full of hail, rain, sleet and snow... no test drive with the blocked off wastegate today... Going to try again tomorrow.
supaninja
PostPosted: Sun Mar 18, 2012 10:00 pm    Post subject: Reply with quote
bad things can happen when block the wastegate closed Confused
Nick
vwfye
vwfye is offline
PostPosted: Sun Mar 18, 2012 10:03 pm    Post subject: Reply with quote
all we are looking for is any sign of boost. if so, then the wastegate gets torn apart.
supaninja
PostPosted: Sun Mar 18, 2012 10:05 pm    Post subject: Reply with quote
Have you did a boost leakdown yet? Are you running a BOV, if so is it working right/plumbed correctly? What turbo exactly are you using, brand too?
Nick
vwfye
vwfye is offline
PostPosted: Sun Mar 18, 2012 10:09 pm    Post subject: Reply with quote
No BOV on a draw through car.
supaninja
PostPosted: Sun Mar 18, 2012 10:17 pm    Post subject: Reply with quote
That's right, on a draw thru, the throttle plates are on the intake side of the turbo. I've never run that style but doesn't the turbo need carbon seals. You should still do a boost leak test to verify there are no leaks. I stay away from all the "overseas" parts when it comes to turbo's, WG, and BOV's, that's why I'm not boosted yet.
Nick
vwfye
vwfye is offline
PostPosted: Sun Mar 18, 2012 10:21 pm    Post subject: Reply with quote
this has a carbon seal and the turbo is from a friend that ran the it on his car.
last year when i tried to run it, i had lots of intake leaks and you could hear it and it ran like crap/wouldn't idle below 2200rpm. now it runs smoothly, idles at 800rpm and the only thing it isn't doing is build boost.
it's all part of the learning curve.
supaninja
PostPosted: Sun Mar 18, 2012 11:57 pm    Post subject: Reply with quote
it's all a learning curve, it was a very expensive one for me Crying or Very sad
Nick
vwfye
vwfye is offline
PostPosted: Mon Mar 19, 2012 10:56 am    Post subject: Reply with quote
Well, using used parts effect things... seems I didn't have all the needed parts and didn't know they were missing. The WG needs a ring between the WG and the flange. Not there...
supaninja
PostPosted: Mon Mar 19, 2012 10:58 am    Post subject: Reply with quote
That should be an easy fix Wink
Nick
vwfye
vwfye is offline
PostPosted: Mon Mar 19, 2012 4:41 pm    Post subject: Reply with quote
Wasn't the wastegate... so, next up: redo the up pipe...
vwfye
vwfye is offline
PostPosted: Thu Mar 22, 2012 10:57 am    Post subject: Reply with quote
I'm hoping tomorrow (Friday) will bring the end of my saga with the up pipe. If so, maybe I will actually see some boost Exclamation If we still have boost issues, I will go after a new wastegate next.
vwfye
vwfye is offline
PostPosted: Fri Mar 23, 2012 12:45 pm    Post subject: Reply with quote
Well, do to circumstances beyond my control, I have to wait on the completion of the up pipe.
vwfye
vwfye is offline
PostPosted: Fri Apr 06, 2012 9:55 am    Post subject: Reply with quote
Looks like we will finish up the pipe early next week! It will be good to get back to it again Very Happy
vwfye
vwfye is offline
PostPosted: Thu Apr 12, 2012 1:56 pm    Post subject: Reply with quote
Alright... I pick up the up pipe tonight. Then, I need to turn the flange for the wastegate a bit for a better fit of the WG exhaust pipe. Then I finally get to attempt boost again!!!!
vwfye
vwfye is offline
PostPosted: Wed Apr 18, 2012 9:33 pm    Post subject: Reply with quote
Can't find a cheap commuter car to replace the squareback, so I have decided to press the notch back into daily driver status. So, the carbs will go back on the car again.
This will give me a solid car that I can transport my kids in!
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 19, 2012 6:21 am    Post subject: Reply with quote
Sounds like you need to put the turbo motor into the late Notch you have. Then it won't need to come back out, as that car isn't going anywhere soon. Then you could gut the inside of it (to lighten it), and basically turn it into the drag car you've always wanted, while still having a reliable car around for daily driving. Shocked
Oh wait, that would make sense. We can't have that. Wink
Bob 65 Notch S with Sunroof
71 Notch ...aka Krunchy; build pics here; http://www.thesamba.com/vw/forum/viewtopic.php?t=240540 -tear down
Page 28 of 38
